What are the possible values of 1/a + 1/b when a^3+3a^2b^2+b^3 = a^3b^3?
  • MHB
  • Thread starter anemone
In summary, the equation that represents the possible values of 1/a + 1/b is a^2 + b^2 - (a + b) = 0. It has an infinite number of solutions and the values of a and b can be negative. There are no restrictions on the values of a and b, as they can be any real numbers. This equation is derived from the original expression a^3+3a^2b^2+b^3 = a^3b^3 by using the algebraic identity (a + b)^3 = a^3 + 3a^2b + 3ab^2 + b^3 and substituting a^3 + b^3 = a^
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $a$ and $b$ be non-zero real numbers such that $a^3+3a^2b^2+b^3=a^3b^3$.
Find all the possible values of $\dfrac{1}{a}+\dfrac{1}{b}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Hello, MHB Community! (Wave)
anemone has asked me to fill in for her while she is away on holiday. :D
Congratulations to to following users for their correct submissions:
  • kaliprasad
  • castor28
Honorable mention goes to lfdahl for a partially correct solution.
castor28's solution follows:
By dividing by $a^3b^3$, the original equation can be written as:
$$\frac{1}{a^3}+\frac{3}{ab}+\frac{1}{b^3} = 1$$
On the other hand, with $u=\dfrac1a+\dfrac1b$, we have:
$$\begin{align*}
u^3 &= \frac{1}{a^3} + \frac{3}{a^2b} + \frac{3}{ab^2} + \frac{1}{b^3}\\
&= \frac{1}{a^3} + \frac{3u}{ab}+ \frac{1}{b^3}
\end{align*}$$
Subtracting, we get:
$$u^3-1=\frac{3(u-1)}{ab}$$
This already shows that $u=1$ is a solution. If $u\ne1$, we have:
$$\begin{align*}
u^2 + u + 1 &= \frac{3}{ab}\\
\frac{1}{a^2} + \frac{2}{ab} + \frac{1}{b^2} + \frac{1}{a} + \frac{1}{b} + 1 &= \frac{3}{ab}\\
\frac{1}{a^2} - \frac{1}{ab} + \frac{1}{b^2} + \frac{1}{a} + \frac{1}{b} + 1 &= 0\\
x^2 - xy + y^2 + x + y + 1 &=0
\end{align*}$$
with $x=\dfrac1a$ and $y=\dfrac1b$. Multiplying by 4 and completing the squares, the last equation gives:
$$(2x-y+1)^2 + 3(y+1)^2 = 0$$
Since both squares are non-negative, the only real solution of that equation is $y=-1$, $x=-1$, giving $u=x+y=-2$.
To summarize, the only possible values of $u=\dfrac1a+\dfrac1b$ are $1$ and $-2$.
FAQ: What are the possible values of 1/a + 1/b when a^3+3a^2b^2+b^3 = a^3b^3?
What is the equation that represents the possible values of 1/a + 1/b?
The equation that represents the possible values of 1/a + 1/b is a^2 + b^2 - (a + b) = 0.
How many possible solutions does the equation have?
The equation has an infinite number of solutions.
Can the values of a and b be negative?
Yes, the values of a and b can be negative.
Are there any restrictions on the values of a and b?
There are no restrictions on the values of a and b. They can be any real numbers.
How does the equation relate to the original expression a^3+3a^2b^2+b^3 = a^3b^3?
The equation is derived from the original expression by using the algebraic identity (a + b)^3 = a^3 + 3a^2b + 3ab^2 + b^3. By substituting a^3 + b^3 = a^3b^3 into the identity, we get a^3 + b^3 = (a + b)^3 - 3ab(a + b). Then, dividing both sides by ab(a + b), we get the equation representing the possible values of 1/a + 1/b.
