What Are the Possible Values of k Given Specific Conditions?
  • MHB
  • Thread starter Albert1
In summary: N)$(1)$a,b,k\in\mathbb{N}$(2)$a>b$(3)$k=\dfrac {a^2+ab+b^2}{ab-1}$In summary, $k=\dfrac {4(m^2+mn+n^2)}{(4mn-1)}=4x (x\in N)$.
Albert1
1,221
(2)$a>b$
please find :
(i) $\max(k)$
(ii) all possible values of $k$
Mathematics news on Phys.org
I am getting nowhere with this, but [sp]there are solutions for $k=4$ (for example $(a,b) = (10,4)$) and $k=7$ ($(a,b) = (2,1)$). I think that those are the only values of $k$ for $k\leqslant 20$, but I do not see how to exclude higher values of $k$. (Headbang)[/sp]
(2)$a>b$
please find :
(i) $\max(k)$
$k>\dfrac{\sqrt[3]{3a^3b^3}}{ab}=3---(1)$(AP >GP)
if a,b both are odd numbers then k does not exist
if a,b both are even numbers then k is also a even number (ex:a=4,b=2 then k=4)
so min(k)=4
let a=2m, b=2n,here $m,n \in N$
then :
for all a,b being even numbers ,we want to prove k=4 then we must prove x=1,that is to prove :
$x=\dfrac{(m^2+mn+n^2)}{(4mn-1)}=1$------(2)(if $x\in N)$
if a odd and b even then k must be odd (ex:a=11 ,b=2 then k=7)
also if a even and b odd then k must be odd
let a=b+d (here b:even and d odd ,so a must be odd)
$k=\dfrac {3b^2+3bd-3+d^2+3}{b^2+bd-1}=3+\dfrac{d^2+3}{b^2+bd-1}$
here $\dfrac{d^2+3}{b^2+bd-1}$ must be even
now we must prove :
$y=\dfrac{d^2+3}{b^2+bd-1}=4$-----(3)(if $y\in N)$
if (2) and (3) can be proved then all is done ,that is min(k)=4 ,and max(k)=7
all the possible valus of k=4 and 7
the proof (2) and (3):I am still thinking ----
By using a program (10001>a>b>0) the possible valus of k=4 and 7
I know (2) and (3) must be true , but how to prove it ?:confused:
(2)$a>b$
My approach was to write this as $a^2+ab+b^2 = k(ab-1)$ and to solve it as a quadratic in $a$, namely $a^2 - b(k-1)a + (b^2+k)$, with solutions \(\displaystyle a = \tfrac12\Bigl(b(k-1) \pm\sqrt{b^2(k-1)^2 - 4(b^2+k)}\Bigr).\) For integer solutions a necessary condition is $b^2(k-1)^2 - 4(b^2+k) = c^2$ for some $c\in\mathbb{N}.$ So we need the Diophantine equation $(k-3)(k-1)b^2 - 4k = c^2$ to have solutions. I could find solutions when $k=4$ or $7$ but not for other values of $k\leqslant20$. That was as far as I could get.
I would approach this problem by first analyzing the given conditions and finding any restrictions on the values of $k$. From the given information, we can see that $a$, $b$, and $k$ are all natural numbers (positive integers). Additionally, $a$ is greater than $b$.
Next, we can look at the equation for $k$ and see that it involves the variables $a$ and $b$ in both the numerator and denominator. This means that the value of $k$ will change depending on the values of $a$ and $b$.
To find the maximum value of $k$, we can use the given condition that $a>b$. This means that $a$ must be at least one more than $b$, so we can set $a=b+1$. Substituting this into the equation for $k$, we get:
$$k=\dfrac {(b+1)^2+(b+1)b+b^2}{(b+1)b-1}=\dfrac{3b^2+3b+1}{b^2+b-1}$$
To find the maximum value of $k$, we want to maximize the numerator and minimize the denominator. The maximum value of the numerator will occur when $b$ is the largest possible value, which is when $b=1$. The minimum value of the denominator will occur when $b$ is the smallest possible value, which is when $b=2$. Substituting these values into the equation for $k$, we get:
$$\max(k)=\dfrac{3(1)^2+3(1)+1}{(1)^2+(1)-1}=\dfrac{7}{1}=7$$
To find all possible values of $k$, we can start by listing out some values for $a$ and $b$ that satisfy the given conditions. For example, we could have $a=3$ and $b=2$, which gives us:
$$k=\dfrac {3^2+3(2)+(2)^2}{(3)(2)-1}=\dfrac{13}{5}$$
We could also have $a=4$ and $b=3$, which gives us:
$$k=\dfrac {4^2+4(3)+(3)^2}{(4)(3)-1}=\dfrac{25}{
FAQ: What Are the Possible Values of k Given Specific Conditions?
How do I find all possible values of k?
In order to find all possible values of k, you will need to have a specific equation or problem that involves k. From there, you can manipulate the equation or plug in different values for k to determine all possible solutions.
Can there be an infinite number of possible values for k?
Yes, it is possible for there to be an infinite number of values for k. This can occur when there are multiple variables and equations involved, or when there are no constraints on the values of k.
How do I know if I have found all possible values of k?
If you have exhaustively tested different values for k and have found no other solutions, then you can be confident that you have found all possible values. However, it is always important to double check your work and make sure you have considered all possible scenarios.
Are there any strategies or methods for finding all possible values of k?
Yes, there are various strategies and methods that can be used to find all possible values of k. Some common techniques include substitution, elimination, and graphing. It is also helpful to have a strong understanding of algebra and mathematical concepts.
Can I use a calculator or computer program to find all possible values of k?
Yes, calculators and computer programs can be very useful in finding all possible values of k. They can quickly perform calculations and help identify patterns or solutions. However, it is important to understand the underlying mathematical concepts and not solely rely on technology.
