What are the practical limits of constructive interference?
In summary, the conversation revolves around the concept of wireless power and how it relates to microphone arrays and other sources of waves. There is a discussion about the interference patterns generated by in-line sources and the limitations of using a triangle or ring arrangement to create spatially constrained Maxima. The topic also touches on directed energy weapons and the consequences of diffraction in directing energy in a specific direction. The use of Supergain Arrays is mentioned as a potential solution, but it is noted that this technique has limited effectiveness.
rumborak
706
154
The "wireless power" thread made me think of this, but I have pondered it before when it comes to microphone arrays etc
You can easily find documentation on the interference patterns N in-line sources of waves generate. E.g.
The annoying thing here is that you have infinitely extending lobes, which would be undesirable for something that tries to pinpoint delivery of (acoustic/EM) energy.
It would seem to me that for example a source arrangement in a triangle would allow some spatially constrained Maxima inside it; but are there simple rules of thumb for this type of thing that constrain the patterns? I can imagine that with a complete ring of sources you could probably reverse engineer any pattern with a Fourier analysis, but that's also overkill on the other end.
Science news on Phys.org
This is a consequence of Diffraction. To direct energy in a specified direction with a certain required beam width you need an extended source. The narrower the required beam θ, the wider the necessary Aperture, d. (roughly θ = λ/2d) There are techniques for doing a bit better than the diffraction limit with 'Supergain Arrays' but there is not a lot of juice in that lemon. This is one of the reasons why Radiotelescopes are so enormous.
Related to What are the practical limits of constructive interference?
What is constructive interference?
Constructive interference is a phenomenon that occurs when two or more waves meet and combine in such a way that their amplitudes add together and result in a larger amplitude. This occurs when the crests and troughs of the waves align, reinforcing each other.
What are the applications of constructive interference?
Constructive interference has various practical applications, such as in the fields of optics, acoustics, and radio communication. For example, it is used in optical interferometry for precise measurements, in noise-cancelling headphones for better sound quality, and in radio antennas for stronger signals.
What are the factors that affect constructive interference?
The factors that affect constructive interference include the wavelength, amplitude, and phase of the waves involved. The distance between the sources of the waves and the medium through which they travel also play a role in determining the degree of interference.
What are the limitations of constructive interference?
One limitation of constructive interference is that it can only occur under specific conditions, such as when the waves have the same frequency and are coherent. Additionally, constructive interference can only increase the amplitude of a wave up to a certain limit, known as the superposition limit.
How is constructive interference different from destructive interference?
Constructive interference and destructive interference are two opposite phenomena. While constructive interference results in an increase in amplitude, destructive interference causes a decrease in amplitude when waves meet and cancel each other out. They also have different applications, with destructive interference being used in fields such as noise reduction and soundproofing.
  • Astronomy and Astrophysics
  • Classical Physics
  • General Discussion
  • STEM Academic Advising
