What are the reagents in an iodoform reaction
  • Thread starter lioric
  • Tags
    Reaction
In summary: If you want to make propanoic acid, you need to combine 2-butanone, sodium propanoate, and iodine in water. Right. So now just put it all together. If you want to make propanoic acid, you need to combine 2-butanone, sodium propanoate, and iodine in water.
lioric
306
this question is about the organic reactions shown in the diagram. ( diagram shows that butan2one is reaction with a reagent P and Q and then reagent R and forms propanoic acid and iodoform)
a)name the reagents P and Q used in reaction 1.
b) identify the reagent R used in reaction 1 and explain why it is needed
I do know that for iodoform reaction you need sodium hydroxide in iodine solution
But I'm wondering what the Reagent R is
What are the products you get if you just put in sodium hydroxide and iodine in water?
Edit: and of course 2-butanone.
NaI and NaOI and water
What are the organic products?
Edit: maybe my edit in post 2 wasn’t clear. When you combine 2-butanone, sodium hydroxide, and iodine in water, what are the organic products?
Iodoform and sodium propanoate
So if you want to end up with propanoic acid, what do you have to do?
I have seen two versions of this
1) In a haloform reaction with iodine, bromine, or chlorine, methyl ketones are converted into the corresponding carboxylic acid and haloform. (from site chemgapedia
http://www.chemgapedia.de/vsengine/...ik/c_acid/synthese_von_carbonsaeuren.vlu.html
2) the other from McMurry organic chemistry textbook saying that in if we use excess halogen and base than it will form the carboxilic acid
And this link shows it too
https://goo.gl/images/miAQfp
You’re overthinking things. If you have sodium propanoate and you want propanoic acid, what do you need to do?
Add a strong acid like HCl or H2SO4
Salt + acid makes a weaker acid and another salt
Related to What are the reagents in an iodoform reaction
1. What is an iodoform reaction?
An iodoform reaction is a chemical reaction in which the compound iodoform (CHI3) is produced. This reaction is commonly used to test for the presence of methyl ketones in a given compound.
2. What are reagents?
Reagents are substances that are added to a chemical reaction in order to bring about a desired change. In the case of an iodoform reaction, the reagents are typically iodine and a base such as sodium hydroxide.
3. Why are iodine and base used as reagents in an iodoform reaction?
Iodine and base are used as reagents in an iodoform reaction because they help to convert methyl ketones into iodoform. Iodine acts as an oxidizing agent, while the base helps to deprotonate the methyl ketone, making it more susceptible to oxidation.
4. Are there any safety precautions to consider when using reagents in an iodoform reaction?
Yes, there are some safety precautions to consider when using reagents in an iodoform reaction. Iodine can be corrosive and irritate the skin and eyes, so proper protective gear should be worn. The reaction should also be carried out in a well-ventilated area to avoid inhaling any fumes.
5. Can the iodoform reaction be used for other purposes besides testing for methyl ketones?
Yes, the iodoform reaction can also be used for other purposes, such as synthesizing iodoform for use in other chemical reactions. It can also be used to produce other compounds, such as chloroform and bromoform, by using different halogens as reagents.
