What are the real numbers that give positive integer roots for a cubic equation?
  • MHB
  • Thread starter MarkFL
  • Tags
    2017
In summary, a cubic equation is a polynomial equation of the form ax^3 + bx^2 + cx + d = 0 with a highest degree of 3. Positive integer roots are whole numbers greater than 0 that satisfy the equation. To find these roots, we can use the rational root theorem which states that the roots will be in the form of p/q. Examples of cubic equations with positive integer roots are x^3 - 6x^2 + 11x - 6 = 0 and x^3 + 3x^2 - 4x - 12 = 0. A cubic equation can have at most three positive integer roots, as it has a highest degree of 3.
MarkFL
MHB
13,288
Hello, MHB Community! (Wave)
anemone has asked me to fill in for her this week. :)
Here is this week's POTW:
Find all real numbers $k$ that give the three roots of the cubic equation $5x^3-5(k+1)x^2+(71k-1)x-(66k-1)=0$ are positive integers.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
I would like to give a vote of thanks to MarkFL for standing in for me while I was unavailable to handle my POTW duties. (Handshake) (Smile)
Congratulations to the following members for their correct solution: (Smile)
1. castor28
2. Opalg
Solution from Opalg:
One solution is always $x=1$, because $$5x^3-5(k+1)x^2+(71k-1)x-(66k-1) = (x-1)(5x^2 - 5kx + 66k-1).$$ So we are looking for integer solutions to the equation $5x^2 - 5kx + 66k-1 = 0.$ Notice that the sum of the roots is $k$. So if the roots are integers then $k$ must also be an integer.
The quadratic formula gives the roots as $$\frac{5k \pm\sqrt{25k^2 - 20(66k-1)}}{10}.$$ Thus $25k^2 - 20(66k-1)$ must be a square, say $25k^2 - 1320k + 20 = n^2.$ Complete the square to write that as $(5k - 132)^2 - 17404 = n^2$. Then factorise the difference of two squares to get $$(5k - 132 - n)(5k - 132 + n) = 17404 = 4\cdot 19\cdot 229.$$ So we are looking for a factorisation $17404 = ab$ (with $0<a<b$) such that $$5k - 132 - n = a, \qquad 5k - 132 + n = b.$$ Then $n = \frac12(b-a)$, so that $a$ and $b$ must be either both odd (clearly impossible) or both even. The only possibilities are therefore $17404 = 2\cdot 8702$ and $17404 = 38\cdot 458$.
If we take $a=2$ and $b = 8702$ then $n = 4350$, and the corresponding value of $k$ is given by $5k - 132 - 4350 = 2$, or $5k = 4484$. But that does not give an integer value for $k$.
However, if we take $a=38$ and $b = 458$ then $n = 210$, and the equation for $k$ is $5k - 132 - 210 = 38$, giving $5k = 380$ and therefore $\boxed{k = 76}$. That is the only allowable value for $k$. The original equation then becomes $5x^3 - 385x^2 + 5395x - 5015 = 0$, with solutions $x = 1,\,17,\,59.$
FAQ: What are the real numbers that give positive integer roots for a cubic equation?
What is a cubic equation?
A cubic equation is a polynomial equation of the form ax^3 + bx^2 + cx + d = 0, where a, b, c, and d are constants and x is the variable. It is called a cubic equation because it has a highest degree of 3.
What are positive integer roots?
Positive integer roots are values of the variable in an equation that satisfy the equation and are whole numbers greater than 0. In the context of a cubic equation, these would be values of x that make the equation equal to 0.
How do we find the real numbers that give positive integer roots for a cubic equation?
To find the real numbers that give positive integer roots for a cubic equation, we can use a method called rational root theorem. This theorem states that if a polynomial has rational roots, then those roots will be in the form of p/q, where p is a factor of the constant term and q is a factor of the leading coefficient. By testing all possible combinations of p and q, we can find the real numbers that give positive integer roots.
What are some examples of cubic equations with positive integer roots?
One example of a cubic equation with positive integer roots is x^3 - 6x^2 + 11x - 6 = 0. The positive integer roots for this equation are x = 1, 2, and 3. Another example is x^3 + 3x^2 - 4x - 12 = 0, which has positive integer roots of x = 2, 3, and 4.
Can a cubic equation have more than three positive integer roots?
No, a cubic equation can have at most three positive integer roots. This is because a cubic equation has a highest degree of 3, meaning it can have at most three distinct solutions. If a cubic equation has more than three positive integer roots, then it must have repeated roots, which would change the equation into a quadratic or linear equation.
