What are the real pairs $(a,\,b)$ that satisfy this system of equations?
  • MHB
  • Thread starter anemone
In summary, "find all real pairs (a, b)" refers to solving an equation or system of equations with real number solutions represented as ordered pairs. This can be done by using algebraic methods such as substitution or elimination. There can be an infinite number of real pairs (a, b) and there are usually no restrictions on the values of a and b. Real pairs (a, b) are commonly used in real-world applications to represent relationships between variables and in solving optimization problems.
anemone
MHB
POTW Director
3,883
115
Determine all real paris $(a,\,b)$ that satisfy the system of equations below:
$4(b^2-a^2)=3\sqrt[3]{a^2b^5}$
$b^2+a^2=5\sqrt[3]{a^4b}$
Mathematics news on Phys.org
Hello.
[tex]4(b^2-a^2)(b^2+a^2)=3\sqrt[3]{a^2b^5} \ 5\sqrt[3]{a^4b}[/tex]
[tex]4(b^4-a^4)=15a^2b^2[/tex]
[tex]4a^4+15a^2b^2-4b^4=0[/tex]
[tex]a^2=\dfrac{-15b^2 \pm \sqrt{289b^4}}{8}[/tex]
Real solution:
[tex]a^2=\dfrac{b^2}{4} \rightarrow{}a=\pm \dfrac{b}{2}[/tex]
Regards.
mente oscura said:
Hello.
Real solution:
Regards.
That is a good "partial" solution, mente oscura! :pHehehe...and thanks for participating!
Hello.
Yes. It is that I am a bit lazy.
[tex]4(b^2-\dfrac{b^2}{4})=3 \sqrt[3]{\dfrac{b^7}{4}}[/tex]
Solutions: (0,0), (2,4), (-2,4)
Regards.
To solve this system of equations, we can start by isolating one variable in each equation. From the first equation, we can rearrange it to get $b^2-a^2=\frac{3\sqrt[3]{a^2b^5}}{4}$. From the second equation, we can rearrange it to get $b^2=5\sqrt[3]{a^4b}-a^2$.
Next, we can substitute the second equation into the first equation to get:
$5\sqrt[3]{a^4b}-a^2-a^2=\frac{3\sqrt[3]{a^2b^5}}{4}$
Simplifying this, we get:
$5\sqrt[3]{a^4b}-2a^2=\frac{3\sqrt[3]{a^2b^5}}{4}$
We can then cube both sides to get rid of the cube root:
$125a^4b-100a^6+20a^4=\frac{27a^2b^5}{64}$
$2000a^6-128a^4b+27a^2b^5=0$
This can be factored into:
$(20a^2-3b)(100a^4-9b^4)=0$
From this, we can see that the solutions will be either when $20a^2=3b$ or when $100a^4=9b^4$.
If we let $x=a^2$ and $y=b^2$, we can rewrite these equations as $20x=3y$ and $100x^2=9y^2$.
Solving these equations simultaneously, we get two solutions: $(a,b)=(\frac{\sqrt{15}}{5},\frac{\sqrt{20}}{5})$ and $(a,b)=(-\frac{\sqrt{15}}{5},-\frac{\sqrt{20}}{5})$.
Therefore, the real pairs that satisfy this system of equations are $(\frac{\sqrt{15}}{5},\frac{\sqrt{20}}{5})$ and $(-\frac{\sqrt{15}}{5},-\frac{\sqrt{20}}{5})$.
FAQ: What are the real pairs $(a,\,b)$ that satisfy this system of equations?
What does "find all real pairs (a, b)" mean?
The phrase "find all real pairs (a, b)" refers to solving an equation or system of equations, where the variables a and b are both real numbers. This means that the solutions to the equation(s) will be a set of ordered pairs, where both a and b are real numbers.
How do you find all real pairs (a, b)?
To find all real pairs (a, b), you must first have an equation or system of equations with the variables a and b. Then, you can use algebraic methods such as substitution or elimination to solve for both a and b. The resulting solutions will be the real pairs (a, b).
Can there be an infinite number of real pairs (a, b)?
Yes, it is possible for there to be an infinite number of real pairs (a, b) as the solutions to an equation or system of equations. This is often seen in equations with multiple variables, where the number of possible solutions is infinite.
Are there any restrictions on the values of a and b in real pairs (a, b)?
The values of a and b in real pairs (a, b) can vary depending on the equation(s) being solved. In some cases, there may be restrictions on the values of a and b, such as being limited to positive numbers or integers. However, in general, there are no specific restrictions on the values of a and b in real pairs (a, b).
How are real pairs (a, b) used in real-world applications?
Real pairs (a, b) are often used in real-world applications to represent relationships between two variables. For example, in graphing and analyzing data, the x and y coordinates of a point can be represented as a real pair (a, b). They are also useful in solving problems involving optimization, where the goal is to find the maximum or minimum value of a function with two variables.
