What Are the Real Solutions for This Equation?
  • MHB
  • Thread starter anemone
In summary, "Solve For Real Solution(s)" refers to a mathematical process of finding the value or values of a variable that make an equation or inequality true. This method is used when encountering equations or inequalities that require finding unknown values. There are several methods for solving, including substitution, elimination, graphing, and the quadratic formula. Some common mistakes include forgetting to perform the same operation on both sides, making calculation errors, and not checking the solution(s) in the original equation. To check if a solution is correct, one can plug it back into the original equation or use a graphing calculator.
anemone
MHB
POTW Director
3,883
115
Solve for real solution(s) for \(\displaystyle x^2− x + 1 = (x^2+ x + 1)(x^2+ 2x + 4)\).
Mathematics news on Phys.org
My solution:
If we expand and collect like terms, we have:
\(\displaystyle x^4+3x^3+6x^2+7x+3=0\)
Let's assume the LHS factors in the form:
\(\displaystyle x^4+3x^3+6x^2+7x+3=(x^2+ax+1)(x^2+bx+3)=x^4+(a+b)x^3+(ab+4)x^2+(3a+b)x+3\)
Equating coefficients selected to result in a linear 2X2 system, we have:
\(\displaystyle a+b=3\)
\(\displaystyle 3a+b=7\)
From this we find:
\(\displaystyle (a,b)=(2,1)\)
Hence:
\(\displaystyle x^4+3x^3+6x^2+7x+3=(x^2+2x+1)(x^2+x+3)=(x+1)^2(x^2+x+3)=0\)
The discriminant of the second factor is negative, thus the only real solution is:
\(\displaystyle x=-1\)
FAQ: What Are the Real Solutions for This Equation?
What is the meaning of "Solve For Real Solution(s)"?
When do we use "Solve For Real Solution(s)"?
We use "Solve For Real Solution(s)" when we encounter equations or inequalities that require us to find the unknown value or values that make the statement true.
What are the methods for solving "Solve For Real Solution(s)"?
There are several methods for solving "Solve For Real Solution(s)", including substitution, elimination, graphing, and the quadratic formula.
What are some common mistakes when solving "Solve For Real Solution(s)"?
Some common mistakes when solving "Solve For Real Solution(s)" include forgetting to perform the same operation on both sides of the equation, making calculation errors, and not checking the solution(s) in the original equation.
How can one check if their "Solve For Real Solution(s)" is correct?
To check if a "Solve For Real Solution(s)" is correct, one can plug the solution(s) back into the original equation and see if it results in a true statement. Additionally, one can use a graphing calculator to plot the equation and see if the solution(s) align with the point(s) of intersection.
