What Are the Scientific Names for These Physical Movements?
  • Thread starter aoede
In summary, the conversation discusses various concepts related to physics and mechanics, including the strain created by abductor muscles, the different positions and movements that can affect strain, and the optimal design for a fishing pole.
aoede
I have three questions. I don't know if any of these questions have "physics" answers:
1) With all five fingers together, wave bye bye. Now abduct them (spread them out) and wave bye bye. The addition of the abductor muscles creates a strain on the flexors. What is that secondary disrupting force called?
2) If you lie your arm flat on a table and poke the table, you could strain your tendons but if you poke the table from above, you won't strain. What is the flat position called? Like, a crane lying on the ground can't swing a wrecking ball but, in the upright position it can.
3) A fishing pole is thick at the base and thin at the tip so that the flexibility can cast the lure most efficiently. What is that construction called . . . where the base is stronger? The base moves the least so the tip moves the most causing the lure to go the furthest. For instance, swatting a fly, the shoulder moves a little but the hand travels two or three feet.
(1) Just describes separate actions .
(2) Mechanical advantage .
(3) Optimal design of a device used for a specific purpose .
Related to What Are the Scientific Names for These Physical Movements?
1. What is the purpose of naming movements in science?
Naming movements in science helps to categorize and organize different phenomena or processes, making them easier to study and understand. It also allows scientists to communicate more efficiently with each other when discussing specific movements.
2. How are movements typically named in science?
Movements are typically named based on the action or behavior they describe, using descriptive terms or Latin words. They may also be named after the scientist who first discovered or studied them.
3. Are there any guidelines for naming movements in science?
Yes, there are guidelines set by various organizations, such as the International Union of Pure and Applied Chemistry (IUPAC) and the International Code of Zoological Nomenclature (ICZN). These guidelines help to ensure consistency and accuracy in naming movements.
4. Can movements have more than one name?
Yes, movements can have multiple names, especially if they are discovered or studied by different scientists or in different fields of science. In these cases, the most commonly used name is typically adopted.
5. How do scientists decide on a name for a new movement?
Scientists may consider various factors when deciding on a name for a new movement, such as the characteristics or behavior of the movement, the context in which it occurs, and previous names or terminology used by other scientists in the field. They may also consult with other experts and follow established guidelines for naming movements.
10K
  • General Discussion
9K
