What are the solutions for (a,b) if 5a^2+5ab+5b^2=7a+14b?
  • MHB
  • Thread starter Albert1
In summary, we are given the equation $5a^2+5ab+5b^2=7a+14b$. The task is to find all solutions for $(a,b)$. The correct solution is $a=4, b=5k$ with $k$ being an integer. However, the incorrect solution is $x=4, y=5k$ with $k$ being an integer. To get the correct solution, we need to use the AM-GM inequality.
Albert1
1,221
$a,b$ are all integers
(1) $if : \,\, 5a^2+5ab+5b^2=7a+14b$
please find all solutions of $(a,b)$
Mathematics news on Phys.org
My solution:
Applying the quadratic formula, we find:
\(\displaystyle b=\frac{(14-5a)\pm\sqrt{14^2-3(5a)^2}}{10}\)
Now we require:
\(\displaystyle 14^2-3(5a)^2\ge0\)
which implies:
\(\displaystyle a\in\{-1,0,1\}\)
Case 1: \(\displaystyle a=-1\)
\(\displaystyle b=\frac{19\pm11}{10}\)
The integral value is \(\displaystyle b=3\)
Hence, $(a,b)=(-1,3)$ is a solution.
Case 2: \(\displaystyle a=0\)
\(\displaystyle b=\frac{14\pm14}{10}\)
The integral value is \(\displaystyle b=0\)
Hence, $(a,b)=(0,0)$ is a solution.
Case 3: \(\displaystyle a=1\)
\(\displaystyle b=\frac{9\pm11}{10}\)
The integral value is \(\displaystyle b=2\)
Hence, $(a,b)=(1,2)$ is a solution.
MarkFL said:
My solution:
Now we require:
which implies:
thanks ,your answer is quite right(Yes)
my solution:
let x=2a+b,and y=a+2b
$ \therefore a=\dfrac {2x-y}{3},\,\,b=\dfrac {2y-x}{3}$
$5(a^2+ab+b^2)=7a+14b,\,\,becomes:$
$5(x^2-xy+y^2)=21y$
and we get :$y=5---(1),\,\, x^2-xy+y^2=21---(2)$
from (1)(2) (x,y)=(1,5)and (4,5)
and the corresponding (a,b)=(-1,3) and (1,2)
of course the third solution of (a,b)=(0,0)
Albert said:
my solution:
$ \therefore a=\dfrac {2x-y}{3},\,\,y=\dfrac {2y-x}{3}$
$5(x^2-xy+y^2)=21y$
not correct as below
$5(x^2−xy+y^2)=21y$
and we get :y=5−−−(1),$x^2−xy+y^2=21$−−−(2)
is not strictly correctit could be
y=5k−−−(1),$x^2−xy+y^2=21k$−−−(2)
$5(x^2−xy+y^2)=21y$
$5(x^2−xy+y^2)=21y----(@)$
we get :$21y\geq 5xy$ $(AP\geq GP)$
$\therefore x\leq 4$ (x,y being integers)
if x=4 ,y=5k
from (@) :$16-20k+25k^2=21k$
$16+25k^2=41k$
k must =1
if x=4 ,y=5k
$16+25k^2=41k$
k must =1
could you explain me how
we get :21y≥5xy (AM≥GM) AM and GM of what ?
I an sorry that I could not understand
$21y=5(x^2-xy+y^2)\geq 5(2xy-xy)=5xy$
$ for: \,\, x^2+y^2\geq 2xy \,\, (AM\geq GM) $
FAQ: What are the solutions for (a,b) if 5a^2+5ab+5b^2=7a+14b?
What does "find all solutions" mean?
"Find all solutions" refers to finding all possible combinations or values of a and b that satisfy a given equation or problem. It involves determining the range of values for a and b that would make the equation or problem true.
How do you find all solutions of an equation?
To find all solutions of an equation, you can use algebraic manipulation, substitution, or graphical methods. You can also use trial and error by plugging in different values for a and b until you find the correct solution.
Are there any limitations to finding all solutions of a problem?
Yes, there can be limitations to finding all solutions of a problem. Some equations may have an infinite number of solutions, making it impossible to list all of them. Additionally, some solutions may be complex numbers, which may not be relevant to the given problem.
Can there be more than one set of solutions for a given problem?
Yes, there can be multiple sets of solutions for a given problem. This means that there can be more than one combination of values for a and b that satisfy the equation or problem. It is important to carefully consider all possible solutions before concluding that a problem has only one set of solutions.
How do you know if you have found all solutions of a problem?
If you are confident that you have considered all possible combinations of values for a and b and have found a solution for each one, then you can be sure that you have found all solutions of the problem. However, it is always a good idea to double check your work and make sure that you have not missed any potential solutions.
