What are the solutions for t=1 in the given log equation?
  • MHB
  • Thread starter Chipset3600
  • Tags
    Log
In summary, we are trying to solve the equation $\sqrt{\log_{a}\sqrt[4]{ax}+\log_{x}\sqrt[4]{ax}}+\sqrt{\log_{a}\sqrt[4]{\frac{x}{a}}+\log_{x}\sqrt[4]{\frac{a}{x}}}=a$. After applying the rules for logarithms, simplifying and substituting $t = \log_a(x)$, we get two possible solutions: $x=a^{a^2}$ for $t>1$ and $x=a^{\frac{1}{a^2}}$ for $0<t<1$. However, we must consider the restrictions for
Chipset3600
79
Hi guys, please help me solving this =/
\[\sqrt{\log_{a}\sqrt[4]{ax}+\log_{x}\sqrt[4]{ax}}+\sqrt{\log_{a}\sqrt[4]{\frac{x}{a}}+\log_{x}\sqrt[4]{\frac{a}{x}}}=a\]
Mathematics news on Phys.org
Re: Solve the equation
I haven't had time to actually solve the equation for x, but have you made any progress using the properties of logs?
https://www.physicsforums.com/attachments/546
Hey Chipset3600!
Long time no see.
Can you apply the rules for the log?
That is:
$\log(p^q) = q \log p$
$\log(pq) = \log p + \log q$
$\log_g{p} = {\ln p \over \ln g}$​
Using that, you should be able to simplify your expression quite a bit.
Looking good! ;)
You do seem to have lost a "+1" in the left square root... (it should be "+2").Next step is to apply $\log_g p = {\ln p \over \ln g}$.
You'll get ${\ln x \over \ln a}$ and its inverse.
Next, I suggest you substitute $y={\ln x \over \ln a}$.
Then solve for y.
Afterward back substitute $y={\ln x \over \ln a}$, and then solve for x.
ILikeSerena said:
Looking good! ;)
Then solve for y.
You mean this?:
[TEX]\sqrt[]{2+\frac{\ln x}{\ln a}+\log_xa }+\sqrt[]{\frac{\ln x}{\ln a}+\log_xa-2}=2a[/TEX]
[TEX]Doing: \frac{\ln x}{\ln a}=y[/TEX]
[TEX]\sqrt[]{2+y+\log_xa }+\sqrt[]{y+\log_xa-2}=2a[/TEX]
Chipset3600 said:
You mean this?:
Also replace $\log_xa$ by $\ln a \over \ln x$, and after that, substitute $1 \over y$.
[tex]\frac{1}{2}\sqrt{\log_{a}(ax)+\log_{x}(ax)}+\frac{1}{2}\sqrt{\log_{a}(\frac{x}{a})+\log_{x}(\frac{a}{x})}=a[/tex]
[tex] \frac{1}{2}\sqrt{\log_a (a)+\log_a (x)+\log_x (a)+\log_x (x)}+\frac{1}{2}\sqrt{\log_{a}(x)-\log_{a}(a)+\log_{x}(a)-\log_{x}(x)}=a[/tex]
[tex] \frac{1}{2}\sqrt{\log_a (x)+\log_x (a)+2}+\frac{1}{2}\sqrt{\log_{a}(x)+\log_{x}(a)-2}=a[/tex]
[tex] \frac{1}{2}\sqrt{\log_a (x)+\frac{\log_a (a)}{\log_a (x)}+2}+\frac{1}{2}\sqrt{\log_{a}(x)+\frac{\log_{a}(a)}{\log_a (x)}-2}=a[/tex]
Now let $t = \log_a(x) $[tex] \sqrt{t+\frac{1}{t}+2}+\sqrt{t+\frac{1}{t}-2}=2a[/tex]
[tex] \sqrt{\frac{t^2+1+2t}{t}}+\sqrt{\frac{t^2+1-2t}{t}}=2a[/tex]
[tex] \sqrt{\frac{(t+1)^2}{t}}+\sqrt{\frac{(t-1)^2}{t}}=2a[/tex]
[tex] \frac{|(t+1)|}{\sqrt{t}}+\frac{|(t-1)|}{\sqrt{t}}=2a[/tex]
here we can remove the absolute value since we are choosing
$t=\log_a(x) $ and t must be positive this is for x>1 then t>0
[tex] \frac{(t+1)}{\sqrt{t}}+\frac{\pm (t-1)}{\sqrt{t}}=2a[/tex]
for t>1
[tex]\frac{2t}{\sqrt{t}}=2a[/tex]
[tex]2\sqrt{t}=2a [/tex] since t can't be negative $t=a^2$
Now substitute back for $t=\log_a(x) $
$\log_a(x) =a^2 \, \, \Rightarrow \,\, x=a^{a^2}$
for 0<t<1
[tex] \frac{(t+1)}{\sqrt{t}}+\frac{-t+1}{\sqrt{t}}=2a[/tex]
[tex] \frac{2}{\sqrt{t}}=2a[/tex]
[tex] \sqrt{t}=\frac{1}{a} \, \, \Rightarrow \,\, t=\frac{1}{a^2}[/tex]
I hope I am making no mistakes >>> (Happy)
What do you think chipset3600?
Are there any mistakes?
Btw, the solution is incomplete.
For which values of $a$ should we pick the one solution, and for which the other?
And what if t=1?
That possibility seems to have been skipped...
And what if t=1?
I found the same result, with a a litle different way, but i guess "t" most be different than 1 and > 0. But I'm not sure witch the other...
Yes, t>0, because otherwise you would not be able to divide by its square root.
When t>1, we get the solution $t=a^2$.
What does that mean for $a$?
Same thing if 0<t<1...?
And you "guess" t must be different from 1... but why?
The problem with t=1 is the following :
we have our equality $\log_a (x) =t \,$ setting t=1 we get $\log_a(x)=1 $ and this is
correct iff a=x now solving for our solutions we get a=x=1 but here is a problem
$\log_1 1=1$ or $\log_1 1 =0$ , according to Wolfram this is an indeterminate form .
So we have no solutions when t=1 .
True.
To elaborate: the definition of the log is $\log_a x = y$ iff $a^y = x$.
With $a = 1$, this is:
$1^y = x$​
But for any $y$ this is:
$1 = x$​
It can only be true if $x = 1$, and then it is true for any $y$.
So $\log_1 x$ does not exist if $x \ne 1$, and is indeterminate if $x = 1$.
FAQ: What are the solutions for t=1 in the given log equation?
What is a log equation?
A log equation is an equation that involves logarithms, which are mathematical functions that represent the inverse of exponential functions. In other words, a log equation has the form logb(x) = y, where b is the base of the logarithm and x and y are variables.
How do I solve a log equation?
To solve a log equation, you can use the properties of logarithms, such as the power rule, product rule, and quotient rule. You can also use the definition of a logarithm to rewrite the equation in exponential form and solve for the variable.
What are the common mistakes when solving log equations?
Some common mistakes when solving log equations include forgetting to apply the properties of logarithms, using the wrong base for the logarithm, and incorrectly simplifying the expression. It is important to carefully follow the steps and double-check your work to avoid these mistakes.
Can a log equation have more than one solution?
Yes, a log equation can have more than one solution. This is because logarithms are not one-to-one functions, meaning that multiple inputs can result in the same output. It is important to check your solutions to make sure they are valid and satisfy the original equation.
What are some real-life applications of log equations?
Log equations are commonly used in science and engineering to model exponential growth and decay, such as population growth, radioactive decay, and compound interest. They are also used in data analysis and signal processing to compress and represent large amounts of data.
