MHB What are the solutions for the geometric sequences in a given pair of problems?
  • Thread starter Thread starter chisigma
    Interesting
The discussion focuses on solving two problems involving geometric sequences. In the first problem, the sequence 4, 20.4, 104.04, 531.6444 is analyzed, revealing that the formula $a_{277}= 4 \cdot 5.1^{276}$ is incorrect due to discrepancies in the third term. A revised difference equation is proposed, leading to a characteristic equation with solutions that inform the correct formula for the sequence. The second problem involves finding the value of x in sequences defined as either arithmetic or geometric, with solutions provided for both cases. The discussion concludes with the identification of specific values for x and the terms of the sequences.
chisigma
MHB
An interesting pair of problems has been proposed in…
http://mathhelpforum.com/pre-calculus/203756-geometric-sequences.html
Now we try to solve #74 that looks like a ‘yellow roman’…
Consider the sequence…
4 , 20.4 , 104.04 , 531.6444 , …
What is the error in using $a_{277}= 4 \cdot 5.1^{276}$ to findthe 277 th term?...
The hypothesis that the sequence is the solutionof the difference equation...
$\displaystyle a_{n+1}= 5.1\ a_{n}\ ,\ a_{0}=4$(1)
... is true for n=1 and n=2 but not for n=3because is $4 \cdot 5,1^{3} = 530.604 \ne 531.6444$. That suggests that thesequence is solution of the difference equation...
$\displaystyle a_{n=1}= 5.1\ a_{n}\ + .2601\ a_{n-3}\ , a_{0}=4\ ,\ a_{1}=20.4\ ,\ a_{2}=104.04$ (2)
The characteristic equation corresponding to(2) is…
$\displaystyle x^{3} – 5.1\ x^{2} - .2601=0$(3)
… and its solution are $x \sim 5.10996$ and $x\sim -.00498053 \pm i\ .225557$, so that the solution of (2) is…
$\displaystyle a_{n}= c_{0}\ 5.10996^{n} +(-.00498053)^{n}\ (c_{1}\ \cos .225557\ n + c{2}\ \sin .225557\ n)$ (4)
The constants $c_{0}$ , $c_{1}$ and $c_{2}$ canbe found from the initial conditions and that is left to the reader. Apreliminary valuation of the error however can be made observing the ratio…
$\displaystyle r =(\frac{5.10996}{5.1})^{277}\sim 1.71$
Kind regards
$\chi$ $\sigma$
Very interesting is the second problem too...
Consider the sequence...
$x+3\ ,\ x+7\ ,\ 4x-2\ ,...$
a) if the sequence is arithmetic find x and then determine each of the terms and the 4-th term...
b) if the sequence is geometric find x and then determine each of the terms and the 4-th term...
a) if the sequence is arithmetic is $\displaystyle a_{n+1}=a_{n}+y$ and we can find x and y solving the pair of equations...
$\displaystyle x+7-x-3=y \\ 4x-2-x-7=y$
... that means $x=\frac{13}{3}\ ,\ y=4$...
b) if the sequence is geometric is $\displaystyle a_{n+1}=a_{n}\ y$ and we can find x and y solving the pair of equations...
$\displaystyle \frac{x+7}{x+3}=y \\ \displaystyle \frac{4x-2}{x+7}=y$
In this case we have two solutions and one of them is $x=5\ ,\ y= \frac{3}{2}$...
Kind regards
$\chi$ $\sigma$
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
