What are the solutions if h+k=2016 and the roots of x^2+hx+k=0 are integers?
  • MHB
  • Thread starter Albert1
In summary, "f(x)=0" in mathematics is an equation where the function f has an input, represented by the variable x, that results in an output of 0. To find the solution of f(x)=0, one can use methods such as algebraic manipulation, graphing, or numerical approximation. There can be more than one solution to f(x)=0, and it is possible for there to be no solution. Finding the solution of f(x)=0 has various real-world applications in fields such as engineering, economics, and science. It can be used to solve problems and make predictions in areas such as business and medicine.
Albert1
1,221
$if$ $ h+k=2016$
and all roots of $ x^2+hx+k=0$ are both integers
find its solutions
Mathematics news on Phys.org
Albert said:
$if$ $ h+k=2016$
find its solutions
let the roots be - a and - b and |a| <= |b| so we get
$(x+a)(x+b) = x^2+hx + k$
or $x^2 + (a+b) x + ab = x^2 + hx + k$
so $a+ b = h,ab = k$
hence $(1+a)(1+b) = (1+ a + b + ab) = 1 + h + k = 2017$
it is a prime so 1 + a = 1 and 1 + b = 2017 so a = 0 and b = 2016 and roots are 0 and - 2016. h = 2016 and k = 0 one solution
or 1 + a = - 1 and 1+b = - 2017 giving a = -2 and b = - 2018 another solution so 2 solutions
FAQ: What are the solutions if h+k=2016 and the roots of x^2+hx+k=0 are integers?
What is the meaning of "f(x)=0" in mathematics?
In mathematics, "f(x)=0" refers to an equation where the function f has an input, represented by the variable x, that results in an output of 0. This is also known as finding the root or solution of the equation.
How do you find the solution of f(x)=0?
To find the solution of f(x)=0, you can use various methods such as algebraic manipulation, graphing, or numerical approximation. The most common method is to use algebraic manipulation to isolate the variable x and solve for its value.
Is there more than one solution to f(x)=0?
Yes, there can be more than one solution to f(x)=0, depending on the complexity of the equation. For example, a quadratic equation can have two solutions, while a cubic equation can have three solutions. These solutions can be real or complex numbers.
Can there be no solution to f(x)=0?
Yes, it is possible for f(x)=0 to have no solution. This means that there is no value of x that can make the equation true. In other words, the graph of the equation does not intersect the x-axis.
How does finding the solution of f(x)=0 relate to real-world applications?
Finding the solution of f(x)=0 is a fundamental concept in mathematics and has various real-world applications. It is used in engineering, economics, and science to solve problems and make predictions. For example, it can be used to find the break-even point in business or to determine the optimal dosage of a medication.
