MHB What are the solutions to this absolute value equation?
The discussion focuses on solving the absolute value equation |1/2x + 1| = |x|. The correct solutions identified are x = 2 and x = -2/3, with a clarification on the interpretation of the equation's format. Two cases are derived: one leading to a quadratic equation with real solutions, and the other resulting in complex solutions. Participants emphasize the importance of clarity in mathematical notation to avoid confusion. Overall, the conversation highlights both the correct solutions and the need for precise expression in mathematical equations.
Alexstrasuz1
I have trouble solving this equation
|1/2x+1|=|x|
My answers are x=2 and x=-2/3
Mathematics news on Phys.org
corrected mistake in (2) as pointed out by MarkFL in the successive post...
|1/2x+1|=|x|
An easy way is to find the solution of the equations...
$\displaystyle \frac{1}{2 x} + 1 = x \implies 2\ x^{2} - 2\ x - 1 =0 \implies x = \frac{1 \pm \sqrt{3}}{2}\ (1)$
$\displaystyle \frac{1}{2 x} + 1 = - x \implies 2\ x^{2} + 2\ x + 1 =0 \implies x = \frac{- 1 \pm i}{2}\ (2)$
Kind regards
$\chi$ $\sigma$
P.S. MarlFL has 'discovered' a mistake in (2) and I corrected it... sorry!...
$\displaystyle \frac{1}{2 x} + 1 = - x \implies 2\ x^{2} + 2\ x - 1 =0 \implies x = \frac{- 1 \pm \sqrt{3}}{2}\ (2)$
Kind regards
$\chi$ $\sigma$
The second equation should be:
$$2x^2+2x+1=0\implies x=\frac{-1\pm i}{2}$$
|1/2x+1|=|x|
Yes, your answers are correct.
Other posts were solving...
|1/2/x+1|=|x|
|1/2/x+1|=|x|
Just to be clear, I was solving:
$$\left|\frac{1}{2x}+1\right|=|x|$$
More often than not, when someone uses 1/2x, they mean 1/(2x) as opposed to (1/2)x.
This is why is is better to use bracketing symbols (or even better, use $\LaTeX$) to remove doubt. :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
