MHB What Are the Steps to Find the Horizontal Asymptote of f(x) = (x^2 - 9)/(x - 3)?
To find the horizontal asymptote of the function f(x) = (x^2 - 9)/(x - 3), it's important to note that the degrees of the numerator and denominator must be compared. The function has no horizontal asymptote because the numerator's degree (2) is greater than the denominator's degree (1). For functions where the degrees are the same, such as y = (x^2 + 3)/(x^2 + 5), the horizontal asymptote can be determined by the leading coefficients, resulting in y = 1. As x approaches infinity, the lower-order terms become negligible, confirming the horizontal asymptote. Understanding these principles is crucial for analyzing rational functions.
mathdad
Find the horizontal asymptote of f(x) = (x^2 - 9)/(x - 3). I need the steps not the solution.
Mathematics news on Phys.org
The given function has no horizontal asymptote
Standard Rule: Numerator and Denominator have the same "Degree". THAT will get you an Horizontal Asymptote.
Good to know but why?
- - - Updated - - -
By "Degree" you mean POWER or EXPONENT, right?
What about y = (x^2 + 3)/(x^2 + 5)?
Can we say the horizontal asymptote is y = 1?
The coefficient of x^2 is 1 for the numerator and denominator.
y = (x^2)/(x^2)
y = 1
True?
Observe that:
$$\frac{x^2+3}{x^2+5}=\frac{x^2+5-2}{x^2+5}=1-\frac{2}{x^2+5}$$
As $x\to\pm\infty$, the rational term vanishes (gets smaller and smaller), and the entire expression therefore approaches 1. :)
In general, you are correct...it can be shown that:
$$\lim_{x\to\pm\infty}\left(\frac{\sum\limits_{k=0}^n\left(a_kx^k\right)}{\sum\limits_{k=0}^n\left(b_kx^k\right)}\right)=\frac{a_n}{b_n}$$
Good to know.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
