MHB What Are the Values of a and b for a Cubic Curve's Tangent Line?
The tangent line y = 16x - 9 touches the curve y = 2x^3 + ax^2 + bx - 9 at the point (1, 7). To find the values of a and b, the conditions a + b = 14 and 2a + b = 10 are established from the curve's equation and its derivative. Solving this system yields a = -4 and b = 18. The calculations confirm that the tangent line's slope matches the curve's gradient at the specified point. The discussion effectively demonstrates the process of determining parameters for a cubic curve's tangent line.
MarkFL
MHB
Here is the question:
Curve Tangent Question?
Hello,
The line y = 16x - 9 is a tangent to the curve y = 2x^3 + ax^2 + bx - 9 at the point (1, 7).
Find the values of a and b.
Thanks in advance.
-Covert
Here is a link to the question:
Curve Tangent Question? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Re: Covert's question at Yahoo! Answers regarding a line tangent to a cubic and fnding parameters
Hello Covert,
Let's define:
$f(x)=2x^3+ax^2+bx-9$
We are given that the point (1,7) is on the curve, so we must have:
$f(1)=2(1)^3+a(1)^2+b(1)-9=2+a+b-9=a+b-7=7\,\therefore\,a+b=14$
We also know that at the point (1,7), $f(x)$ must have a gradient of 16, the same as the line. Hence, we may compute the derivative of $f(x)$, and then set $f'(1)=16$:
$f'(x)=6x^2+2ax+b$
$f'(1)=6(1)^2+2a(1)+b=6+2a+b=16\,\therefore\,2a+b=10$
We now have the linear system:
$a+b=14$
$2a+b=10$
Subtracting the first from the second, we eliminate $b$ to obtain:
$a=-4$
Substituting for $a$ into the first equation, we find:
$b=18$
Here is a graph showing the function and its tangent line at the given point:
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
