What are the values of A and B for the given trigonometric expressions?
  • MHB
  • Thread starter Albert1
In summary, to find the values for A and B, you will need to gather information about the problem or experiment and use mathematical methods such as substitution, elimination, or graphing. These are common methods used to solve for unknown variables. A calculator can also be used, but it is important to understand the underlying concepts. To ensure the correctness of the values, you can plug them back into the original equations or compare them to known values. Tips for finding values include clearly defining the problem, organizing information, using multiple methods, and double-checking calculations.
Albert1
1,221
find the following values:
$(1) A=cos^3\dfrac {\pi}{8}+cos^3\dfrac {3\pi}{8}+cos^3\dfrac {5\pi}{8}+cos^3\dfrac {7\pi}{8}=?$
$(2) B=cos^4\dfrac {\pi}{8}+cos^4\dfrac {3\pi}{8}+cos^4\dfrac {5\pi}{8}+cos^4\dfrac {7\pi}{8}=?$
Mathematics news on Phys.org
Two questions. let me find A first
as $ cos \dfrac{\pi}{8}=-\cos \dfrac{7\pi}{8}$
so $ cos^3 \dfrac{\pi}{8}=-\cos^3 \dfrac{7\pi}{8}$
hence $ cos^3 \dfrac{\pi}{8} +\cos^3 \dfrac{7\pi}{8}=0\cdots(1)$
similarly $ cos^3 \dfrac{3\pi}{8}+\cos^3 \dfrac{5\pi}{8}=0\cdots(2)$
adding above 2 we get
$ cos^3 \dfrac{\pi}{8}+\cos^3 \dfrac{3\pi}{8}+cos^3 \dfrac{5\pi}{8}+\cos^3 \dfrac{7\pi}{8} =0$
now for B
we have
$ \cos(\dfrac{7\pi}{8}) = -\cos(\dfrac{\pi}{8})$
hence $ \cos ^4(\dfrac{7\pi}{8}) = \cos^4(\dfrac{\pi}{8})$
similarly
$ \cos(\dfrac{5\pi}{8}) = -\cos(\dfrac{3\pi}{8})$
hence $ \cos ^4(\dfrac{5\pi}{8}) = \cos^4(\dfrac{3\pi}{8})= \sin ^4 (\dfrac{\pi}{8})$
so we get
$ \cos^4 (\dfrac{\pi}{8}) + \cos^4(\dfrac{3\pi}{8})+ \cos^4(\dfrac{5\pi}{8})+ \cos^4(\dfrac{7\pi}{8}) $
= $2(\cos^4 (\dfrac{\pi}{8}) + \sin^4 (\dfrac{\pi}{8}))$
= $2(\cos^2 (\dfrac{\pi}{8}) + \sin^2 (\dfrac{\pi}{8}))^2- 2\cos^2 (\dfrac{\pi}{8})\sin^2 (\dfrac{\pi}{8}))$ using $a^4+b^4 = (a^2+b^2)^2 - 2a^2b^2$
= $2 ( 1- \dfrac{1}{2} \sin ^2 \dfrac{\pi}{4})$
= $2 ( 1- \dfrac{1}{2} (\dfrac{1}{\sqrt{2}})^2)$
= $\dfrac{3}{2}$
very good , both are correct
FAQ: What are the values of A and B for the given trigonometric expressions?
How do I find the values for A and B?
To find the values for A and B, you will need to gather information about the problem or experiment you are studying. This information can include data points, equations, or other known variables. Once you have this information, you can use mathematical methods such as substitution, elimination, or graphing to solve for the values of A and B.
What are the common methods to find values for A and B?
Some common methods to find values for A and B include substitution, elimination, and graphing. Substitution involves replacing one variable with an expression containing the other variable and then solving for that variable. Elimination involves adding or subtracting equations to eliminate one variable and solve for the other. Graphing involves plotting data points and finding the line of best fit, which can then be used to determine the values of A and B.
Can I use a calculator to find the values for A and B?
Yes, you can use a calculator to find the values of A and B. Many scientific or graphing calculators have built-in functions that can help you solve for unknown variables. However, it is important to understand the mathematical concepts behind finding values for A and B instead of solely relying on a calculator.
How do I know if my values for A and B are correct?
To determine if your values for A and B are correct, you can plug them back into the original equations or data points and see if they produce the expected results. You can also compare your values to any known or expected values, such as those from previous experiments or theoretical calculations.
Are there any tips for finding values for A and B?
Some tips for finding values for A and B include clearly defining the problem, organizing and understanding the given information, and using multiple methods to check your solutions. It is also helpful to double-check your calculations and make sure you are using the correct units and significant figures.
