xyz_1965
- 76
Let theta be 15 degrees.
Here is my set up.
To find x, use tan (15°) = x/200.
To find y, use cos (15°) = 200/y.
The equation for finding the values of x and y when theta is 15 degrees is x = r cos(theta) and y = r sin(theta), where r is the length of the hypotenuse.
To determine the values of x and y when theta is 15 degrees on a graph, you can plot the point (x,y) on a coordinate plane where x = r cos(theta) and y = r sin(theta), with r being the length of the hypotenuse.
Yes, the values of x and y can be negative when theta is 15 degrees. It depends on the quadrant in which the point (x,y) lies on the coordinate plane.
The length of the hypotenuse can be calculated using the Pythagorean theorem, where c is the length of the hypotenuse and a and b are the lengths of the other two sides. The equation is c = sqrt(a^2 + b^2). In this case, a = x and b = y.
Yes, the values of x and y can be fractions or decimals when theta is 15 degrees. The values of x and y will depend on the length of the hypotenuse and the angle theta, which can result in fractions or decimals.
