What are unified theories trying to match at lower energies?
In summary, the phenomenologists of unified theories, such as strings and loops, aim to match certain features at lower energies, including chiral matter and three generations. However, there are still many unresolved issues, such as the existence of right-handed neutrinos and the GUT gauge group. F-theory is one approach to creating viable theories at low energies, but there are conflicting models and it is difficult to determine which features are necessary for a compactified model. The three main points to consider in unified theories are post-dicting well-known results of the Standard Model, predicting new physics beyond the Standard Model, and explaining the assumptions and axioms of the Standard Model. Currently, there are no experimental results beyond the Standard Model, making
crackjack
120
What do the phenomenologists of unified theories (strings, loops etc) try to match at lower energies when there are so many conflicting theories lying around at these energies?
I understand that certain things should be there in any model - like chiral matter, three generations etc - but a lot of things still remain unsettled (like right-handed neutrinos, the GUT gauge group etc).
I know about two approaches regarding unification, string/M theory and non-commutative gravity (a la Connes). LQG is certainly not an approach to unification but to quantum gravity "only".
Regarding strings: I guess that F-theory model building tries exactly what you have in mind, namely to tailor low-energy effective and phenomenologically viable theories. You should have a look at http://arxiv.org/find; try author = "Vafa", title = "F-theory".
I have looked at papers on string model building but I get confused as to the phenomenology that is matched at low energies, since I see a lot of conflicting (partially, if not fully at loggerheads) models at low energies.
So, to rephrase my question:
What are the 4-dim low energy phenomenological features (other than the experimentally verified ones of the SM) which any compactified model should satisfy at the bare minimum, in addition to making new predictions?
crackjack said:
... What are the 4-dim low energy phenomenological features (other than the experimentally verified ones of the SM) which any compactified model should satisfy at the bare minimum ...
I do not understand. As there are (to my knowledge) no experimental results beyond the standard model, I do not see what we can expect from unified theories.
There are three important points:
1) post-dict well-known SM results
2) predict new physics beyond the SM
3) predict assumptions / axioms of the SM
Regarding 1) alternative theories still have problems to derive all known results / not to run into conflicts.
Regarding 2) there are a "predictions" like SUSY, unfortunately rather unspecific (at which energy scale? how to break it? ...)
Regardig 3) there are a lot of assumptions in the SM that I would like to see as a result of a new theory: 3 spatial dimensions, 3 fermion generations, U(1)*SU(2)*SU(3) gauge group of the SM, gravity, Higgs, ... to mention a few.
My expectation is that sooner or later we will be able to understand at least some of these inputs of the SM as the results of a more fundamental theory; but currently I do not see any candidate at the horizon (personally I don't believe that it's string theory).
Tom
Thanks Tom. Few more questions on the three points...
1: The number of independent well-known (aka experimentally verified) results of SM depend on the model used in GUTs etc. And the higgs mechanisms and the scales at which they occur have also not been decided conclusively (like SO(10) might break via the Pati-Salam model or not and so on). Even the particles predicted in different GUTs differ (like right handed neutrinos in SO(10), differing lifetimes of proton decay and so on). In such a situation, what can the unified theory's phenomenologists target at low energies?
2: If there had been concrete features that the unified theories had to have at the very least at low energies, we could then say that the rest of the spectrum are new predictions. But lacking concrete features (except maybe a general SUSY-GUT scale of 1016GeV, three families of quarks and leptons, the GUT scale higgs/yukawa etc), the rest of the spectrum of the compactified theory will not be taken seriously as new predictions. As for SUSY breaking scale and mechanism, it is again something that SM phenomenologists should worry about right?
3: Three spatial dimensions are not hard to get and so are the three generations and gravity (at least SUGRA).
The U(1) x SU(2) x SU(3) gauge group of the SM is probably not what compactified models should aim for - I would expect them to aim for the SUSY-GUT gauge group (which, at the moment, is undecided).
Higgs/Yukawa - at least the one that is responsible for the GUT break at 1016GeV - is something that can indeed be a potential target for compactified theories.
And LQG is not aiming for unification? I thought they were vying for the same pie as string theorists! So, is their idea something like quantize gravity for now and later try for a gauge group that would include the SM and the quantized gravity?
If a "candidate" theory makes predictions different from the SM and disproved by experiment you can either modify it - or throw it away
Why do you thing that it's easy the get three dimensions? I know of no theory which predicts three dimensions. If you theory produces a SUSY-GUT, there's still the problem tobreak it down to SM in a realistic way. Eventually this has to be understood as well; deriving SUSY does not help in a world w/o SUSY.
LQG is not aiming for unification. It is compatible with all known gauge symmetries and perhaps even with SUGRA. It provides something like "unification" as it implements gravity as a gauge theory, so at least the framework is harmonized.
1- if LHC does not find evidence of SUSY, nor other experiments, is there a physics reason to continue researching it?
2- if the braiding scheme via Bilson Thompson does work using framed graphs, would you regard this as LQG unification?
Regarding 1) I would say both yes and no. Yes because maybe SUSY exists (unbroken) at higher energies. No because it makes no sense to search for SUSY at 10, 20, 30, ... TeV.
Regarding 2) I would say it's wishful thinking - but YES, that would be the deepest unification I can think about. It's not that you use higher and higher symmetry groups, dimensions, SUSY etc.You just quantize ordinary space-time, braid it - and all particles and forces emerge from it! Are there any new results in the last month?
@ tom.stoer
Pardon me, I did not mean predicting 3 dim or 3 families, but meant engineering them from a predicted higher dim. I think the requirement for a unified theory to predict the axioms of SM can be put on hold for now - will first look for 'how' and then think about 'why'.
The problem of how SUSY-GUT reaches SM is far down from the realm of unification energies . So, I would expect them to be the subject of research of 'physics beyond SM' than 'unified physics' - in my earlier example, SO(10) breaking via Pati-Salam model or not is a question for SM phenomenologists than string phenomenologists.
In addition, as I have been saying, the SUSY-GUT is also undecided and there are a lot of proposals there. So, what would the model-builders of a candidate theory of unification aim for at the lower energies? In other words, till the time the 'why's are answered, what benchmark could be used in evaluating low energy models engineered from unification theories?
I am not so sure what you mean by engineering. Do you have something in mind like "take a stack of xyz branes + blablabla" and check something like "SM + abc" comes out AND "abc can be hidden somehow"? If this is what you mean then you are "only" looking for concepts how to engineer SM from something else.
First I would expect that the SM comes out (unfortunately this is not the case in F-theory so far,even if you are quite close to it)
Second I would like to understand how to hide abc; should be rather natural - whatever that means.
Third I would like to see some hidden / higher-order effects from xyz or abc. This could be something like the restriction regarding the Higgs mass coming from higher loops (at tree level the Higgs mass is completely arbitray, but at higer loops there are constraints which are subject to experiment at the LHC). Or you will find something like proton decay which killed SU(5) and SO(10) GUT. Or you will find long range forces (which basically kills many string-inspired models as they quite often predict SM * U(1) * U(1) * ... or SM plus massless scalars.
I don't see any generic prediction or something like that. It depends on the model you start from (e.g. xzy) - and it depends on abc, of course.
Hmm? I am not even sure if they are easy to engineer, nor to predict. Al least, in accepted peer reviewed theories :biggrin:
@ tom.stoer
ya, that's what I had in mind when I said engineering low energy models. I agree with your second point on hiding the exotic particles naturally and the third point on fixing the higgs mass, but not fully (or perhaps I have wrong ideas about what is expected) with first point:
Is it really expected of string theorists to be the first to come up with an undeniable GUT model and also a mechanism for breaking it down? I was expecting the GUT-scale and astroparticle phenomenologists to be the first to fully agree on a few (~ 2-3?) potential GUTs and their break down mechanisms (rather than the open endedness that I think I am seeing - even proton decay is not fully ruled out yet). Then string phenomenologists could aim for these few potential GUT models along with predictions in each case about GUT higgs mass, candidate dark matter/energy etc which could be the deciding factor in fixing one single GUT theory.
@ arivero
In intersecting brane models, for example, it boils down to engineering the two fractional 3-cycles in the 6 compact dimensions to intersect 3 times. Its surely not a prediction (yet or maybe never). I have seen 3 generations in other compactifications too, but I don't remember how they were engineered. And, sure, none of them had no unwanted/missing particles in them - if not, such a result would not have gone unnoticed.
From my limited exposure, I get the feeling that the theories at low energies (lower than string scale) are developed only to the extent of using them to classify 4D models constructed down from string theory as those that are obviously wrong and those that could potentially be right. I don't see this helping the "string or no-string?" discussion at all.
I am not an expert but I am expecting the following:
- try to get as closed to the SM as possible i.e. reduce the unwanted features (like in F-theory)
- understand what the essential features are to reproduce the standard model
- create similar models closed to the standard model and understand this local region of the "landscape"
I guess entering the second or third stage would be called the third superstring revolution; working on the first stage may by boring. I really cannot say whether it's worth to continue or better to give up.
@ tom.stoer
I still do not understand why SM is the target.
Let me put it this way: Even among GUTs, all the candidate theories have SM somewhere within them - it is just how they break themselves to reach that SM (eg. SO(10) reaching SM through Pati-Salam model or not? What energy scales at which these breakings occur? etc) and other new extra predictions (proton decay, neutrino masses etc) that differentiate them.
Similarly, for string theory, SM is contained in a ton of models - but, it is the new extra predictions that differentiates them and will even select The One among them. But, the problem is, there is still a debate as to the nature of these extra features (at lower ~ GUT scales). Till this is settled, there is really no one fixed criteria against which the string models can be matched and judged. So, the question of string theory being successful or not does not make sense.
So, instead of debating this, shouldn't the topic of debate be how much we should fund research at Planck scales when there is so much pending work at GUT scales?
IMO, I think this strategy risks missing some of the makeup of nature, and natures workings.
If some of the "how", is developed on the fly like evolutionary self-organizing progression, the why is almost more important. In the extreme reduction, the how could simply be an abstract random walk where the more important thing could be to understand the feedback and selection mechanism of the self-organising random walker.
The how is then a result of evolution, while the WHY amounts to understanding the mechanics of variation and selection.
I expect the how, to follow from first principles at least to a reasonable extent. At least in the sense of probably evolutionary paths, in analogy (an even an extension/generalisation of) to how we understand life on earth.
I want for something along the lines of what are the self-organising principles that could be responsible for the evolution of diversity we seen, given a starting point where differentiation of forces and 4 spacetime dimensions was no longer distinguishable to an inside observer? Could these principle explain what we see as an "expected outcome" out of such a self-organisation given enough time?
For string theory to come near this, also the origin of the strings and their background needs explanation. They why strings, has to be answered. I won't accept less.
/Fredrik
@ Fra
Sure that would happen.
But, we have to find out how this universe exists before answering why it exists - anything else would be philosophy, not physics. ;)
crackjack said:
@ Fra
Maybe I can clarify a bit.
Yes I think the "unification quests" by definition overlaps with philosophy in the first place :) Even thouhg physicistst may deny it. Why do we seek "unification" in the first place? Why is a coherent understanding better than a fragmented "collection" of a diversity of actual experimental results?
I hold the position that how and why are not really that different. If you take a more information theoretic approach to things (like I do), the why, as in "confidence in opinon or expectation" clearly conceptually realted to "how" information is processed and stored.
So when I ask "why" I do not mean it in the traditional philosophical sense, I rather mean to ask for a information measure of the confidence in a given expectation. So, why is spacetime 4D, translates to - how is information about the environment, processed and retained so as to yield a rational expectation of a 4D spacetime?
For me why and how are related in this sense. Then again, string theory is not an information theoretic framwork, it's more old style building on a sort of realist picture. I find this unmodern and not satisfactory.
/Fredrik
Fra said:
Yes I think the "unification quests" by definition overlaps with philosophy in the first place :) Even thouhg physicistst may deny it. Why do we seek "unification" in the first place? Why is a coherent understanding better than a fragmented "collection" of a diversity of actual experimental results? /QUOTE]
You seem to imple that the unification is an overlay of fragments. Point is, if we can not unify is because the fragments do not fit, a unification theory is really a quest for a pulishing of each fragment. It is because of this, that we seek unification. To correct and better each particular theory. In this sense it is a physics quest, not needing external motivation.
Hmm mybe I expressed myself poorly. No I do not think of unification as an overlay of fragments, it's the opposite.
I see it that we now have a set of pieces of a puzzle, each well motivated by specific sets of experiments, but where the pieces won't match to a big coherent picture. But if we try to see each piece of the puzzle in a context of inquiry and information processing, maybe it's easier to also see that the reason they don't fit may be because it's not possible to zoom in at all places at once. The context of a gravitational observation is clearly different than that of a particle experiment. So the pieces produces, lack common context. There is no a priori connection between the processes wherby the pieces has been carved - except for human science of course - but I envision that a better abstraction for the connection is the information theoretic one.
Here, ANY piece of ANY puzzle, is always the result of a physical inference process, including things like interaction histories, physical information storage etc. This is the connection I envision. But we need to imagine this physically, from the point of vie of a general matter system taking the role of observer, rather than human science.
(but all this still lives in under the umbrella of science, since this either leads to progress or it doesn't)
/Fredrik
crackjack said:
@ tom.stoer
I don't agree. I have not seen one single model (GUT, SUSY, string) which is not either completely unnatural (*) or simple wrong (**).
Let's start with (**). If a model predicts something similar like the SM (where similar means that the predictions do not match the experimental results) then this model is wrong and must be thrown away.
(*) is more difficult. If a model makes predictions A, B, C, ... which you really do like, and it makes predictions X, Y, Z, ... which are simple wrong in terms of (**) - but you can save the model by assuming this, hiding that ..., then I would call the model unnatural.
If a model allows for U(1)*SU(2)*SU(3) but w/o the correct chiral structure it is WRONG. If a model predicts this goup but in additions has unwanted U(1) factors it is WRONG. If you are able to hide these extra structures at higher energies etc., then you may be on the safe side. But if you look at attempts search for physics beyond the standard model the situation is really a mess: either the models are wrong in the sense of (**) (as proton lifetime is too short ...) or they are unnatural in the sense of (*) (because they essentially double physical objects like particles in a hidden sector).
Neither do I agree with your claim that "all the candidate theories have SM somewhere within them", nor do I agree with "SM is contained in a ton of models". It always "something similar to the standard model" or "closed to the standard model" or that "could be the standard model".
Because there is no physical evidence for one single experimental result beyond the standard model, the main focus must be reproducing the standard model; after this has been achieved (in a certain class of models) one can search for new physics beyond the standard model! Most candidate theories fail (failed) because they do (did) not reproduce the standard model . It is a waste of time to look for new physics beyond the standard model if you already know that the model in question is in disagreement with experiment.
I do not say that doing it the other way round is wrong, I say that its ineffective as you have lost your guiding principles
Recently I have become worried about this point. Are we really sure about which chiral structure, if any, must we match?
In the low energy, the standard model is not chiral, it is SU(3)xU(1). The chiral part is Fermi interaction, a non renormalizable object. And the Z0 boson has no role here, even.
At high energy, is is true that we have U(1)xSU(2)xSU(3), but we also have B-L, or at least no experiment has been found to violate B-L. So must we match the chiral structure of the gauge groups, or add the B-L to the play? I am not sure if it is the same matching, then.
Hmmm, I think we are pretty sure, right? Roughly speaking, from at least a few hundred GeV on down the world is pretty much described by the chiral gauge theory we all know and love. The fact that at even lower energies the chiral nature of the theory becomes arguably less important is, in my opinion, an unrelated issue.
Therefore what we should match to is the full standard model as we know it today modulo experimentally acceptable corrections from higher dimension operators.
We are! If you look at theories A => B, B', ... where A is "fundamental" and B, B', ... are low energy effective theories, it is clear that A is the theory that has to be derived from some other (speculative) "UV complete", "unified" theories.
In QCD you have similar approximations, e.g. chiral perturbation theory which is a low-energy effective theory respecting the chiral and flavor symmetry but "integrating ot" the color SU(3) degrees of freedom.
I am curious what physical meaning if any, you give to the implication arrow here. I suspect you mean the usual scaling/averaging in the mathematical sense?
The current understanding and vision I have suggests that the "old" reductionist idea that low energy physics is implied by an "infinite energy picture", as this information reduction is not illustrating the purest inside perspective, because this very process demands a very complex context/observer that can distinguish the microstructure, not only the macrostates, otherwise there is nothing to reduce.
There is the following duality.
From the observed systems point of view, the high energy particle physics limit, is that of simplicity, because all constitutients are disintegrated into minimal constitutients and the most pure interactions. ie. in a sense minimal complexity.
From the observers point of view, it's on the contrary a high energy expenditure to make such an observation, and there is a lot of information to encode and process. So from this view, we have "maximum complexity".
Now, the conflict is obvious - if we consider the consittutients of matter to be the inside observer, then we arrive at a constraint that prevents a finite observer from encoding and observer the ultimate unification scale, instead there is a maximum relation between the two scales. This is usually ignored, and to me it seems like it should be a basal requirement on any intrinsic measurement theory.
The usual problem I see here is that there can be no objective meaning to the smallest possible scale, and thus there is no objective meaning to the inference of low energy limit from the high energy limit, because those limits are not objective things.
Is the implication A => B a physical process (consider an object "cooling" or generally loosing energy/mass by radiation, EM or general hawking radiation), or is it just a mathematical implication?
If we just do mathematical reduction, are we gaining much long term physical insight?
/Fredrik
So, B-L too?
Yes, if A is experimentally verified. But A, to our regret, includes the Higgs.
The neat experimental result we call "the standard model" is the Z0 peak. It is evidence both for electroweak group and for the limit of three light neutrinos. The Higgs is only, as yet, a mathematical step, to unify the experimental inputs: SU(3)xU(1), G_F, M_Z0.
(Thinking on it, perhaps I got worried about this when I plotted mass_width_2006.csv from here http://pdg.lbl.gov/2006/html/computer_read.html using
set datafile commentschars “*”
set datafile separator “,”
set logscale xy
set key bottom Right
plot “mass_width_2006.csv” using 1:4
this was the result http://dftuz.unizar.es/~rivero/research/nonstrong.jpg and it shows that the "low energy", amazingly, scales to include the Z0)
SO theories showing SU(3)xU(1) or Z0 or Fermi, even without matching the full set, are still interesting. I'd say, they are more interesting that ones with a lot of extra fields and parameters...
"=>" has no precise meaning here. Deriving "B" = "Fermy model" from "A" = "GSW" is one example, deriving "B'" = "chiral perturbation th." from "A" = "QCD" is another one.
Regarding the Higgs: we are talking about low-energy phenomenology here. So if we derive from some theory "A" a model "B" which perfectly fits (experimentally!) to SM w/o Higgs this is fine. If "B" fits to the standard model w/ Higgs it's fine, too (besides the fact that we have one additional job, namely find the Higgs). If you derive "standard model + some extra structure at higher energies" the job is rather similar.
We must distinguish between experimental signatures and theoretical constructions. The Higgs is both. There are known signatures, namely one-loop calculations constraining the allowed mass range. There is in addition the possibility that the Higgs is an effective degree of freedom, e.g. a kind of condensate (top-quark, WW-self int.)
  • #31
I still don't see why you are placing SUSY, GUT and strings on the same platform. They hold at different energy scales. Ideally, a string theorist should explain SM, E&M, Newtonian gravity and all the way to fundamental biology etc. But, we can only expect them to relay the baton to GUT theorists and relativists who will then relay it further and so on to biologists etc.
Now my question is, when there is so much confusion at the GUT and SUSY scale, there is no clarity as to which of these theories should the string theory aim to pass the baton to. And lacking such a clarity, it cannot be unequivocally said that it is entirely strings fault for SM not having received the baton.
  • #32
crackjack said:
... when there is so much confusion at the GUT and SUSY scale, there is no clarity as to which of these theories should the string theory aim to pass the baton to
The situation is as follows:
There is not one single experimental result that forces you to abandon the SM or to look for new physics beyond the standard model. But there are theoretical reasons why you should do so (unification, UV-completion, why three families, why U(1)*SU(2)*SU(3), quantum gravity).
I see basically two different approaches (black and white, I know):
1) construct models (reproducing the SM at low energies) solving some of these problems: bottom-up approach
2) construct one unique theory from which the SM can be derived in some way: top-down approach
For both approaches the SM is the benchark. w/o reproducing its effects and accuracy a candidate theory is doomed to fail.
Now it makes no sense to say that there's no need for string theory to reproduce the standard model but only to reproduce some other low-energy effective theory - if at the same you know that there is only one single low-energy effective theory that describes the real world - namely the standard model. And it makes no sense to try to reproduce some SUSY-GUT (as an example) if you know that this SUSY-GUT does not describe the real world!
If you can give me a theory X that solves some problems of the standard model and that does not create new ones, then it's reasonable for string theory to try to reproduce this new candidate theory X. If you are not able to give me such a theory then string theory (or one of its solutions) must reproduce the standard model. In any case the other theory seems to be a stopover only.
crackjack said:
... it cannot be unequivocally said that it is entirely strings fault for SM not having received the baton.
Correct! Nobody has ever been able to provide something better than the SM, so you can blame everybody.
Look at the "old-fashioned" SU(10) GUT which failed because the proton lifetime came out too short. It failed because the proton lifetime was too short, not because it was not able to derive SU(5) or something else. You must blame SO(10), not SU(5); you cannot say that SO(10) could work theoretically and it's up to SU(5) to repair the defects of SO(10).
But I agree with you that a physically acceptable theory X beyond the SM which is formally closer to ST would help a lot.
  • #33
Apart from the lack of uniqeness, as far as I know there is not yet even _one_ known string model that reproduces correct SM physics to the extent known from experiment?
The lack of uniqueness itself might be curable if ST could complement their thinking with mechanisms for variation and selection and thus evolution. (I don't mean resorting to silly antrophic principles; I mean real statistical-like inferences of expected evolution scenarios, based on a unique minimal starting points of maximum possible symmetry - but there are no imagine mechanisms for this as far as I know.)
I'd persoanlly see (1) without vision of solving most serious issues as a waste of time due to beeing halfhearted. I also think several of the foundational questions are related, and I think it's harder, not easier, to try to solve them one by one rather than together.
/Fredrik
  • #34
Fra said:
The lack of uniqueness itself might be curable if ST could complement their thinking with mechanisms for variation and selection and thus evolution. ...
I am not sure if this is relevant in our discussion, but I agree that either string theorists have to identify a new (yet unknown) principle that is powerful enough to establish uniqueness or that that they are able to incorporate some (statistical) selection principle.
Fra said:
... I'd persoanlly see (1) without vision of solving most serious issues as a waste of time due to beeing halfhearted. I also think several of the foundational questions are related, and I think it's harder, not easier, to try to solve them one by one rather than together.
I tend to agree, but I am not sure. In the end you are right, if there's hope to identify a ToE then one must sooner or later - abandon the bottom-up approach, otherwise if you have discovered the ToE, you will not be able to know whether it really IS the ToE :-)
On the other hand if we are not yet at the stage where the ToE is at the horizon, perhaps another step in a bottom-up manner may be required. But if this is the case I doubt that it's string theory, simply because for a minor step it's much too complicated.
I am not sure who had the idea here in this forum: perhaps string theory will stay forever what it is: a collection of theories in a larger space of ALL consistent theories related by certain dualities. Compare it to manifolds: each low-energy effective theory may correspond to a local "chart", an element of a huge "atlas of theories". And perhaps the structure of the manifold does not allow for one unique chart ...
Interesting, but I don't think that it has much to do with model building.
  • #35
If someone could convince me that the string framework IS an exhaustive collection of all theories, then that would actually be a major point for me, but even this is far from clear to me since there are no plausible arguments. On the contrary do I see reasons that the starting from continuum objects can't be a minimal complexity starting point from the point of view of information.
Other than that, I am quite at peace with ideas that theories themselves, must evolve, since theories physically are encoded in physical systems. So some kind of population of theories, associated to a population of matter systems, with given properties in consistency with mentioned theories, in a democratic sense are IMO some loose generic predictions of some of the visions I have.
I think this relates to the current discussion indirectly since another "possibility" is that we may need to actually revise our understanding of what the physical basis of a theory is, in order to understand how one theory "implies" another one, at a different scale. It's not just semantics to question what we mean by theory and implication here. I think this involves understanding what a symmetry is, and how one system infers and encodes(internally) a symmetry of it's own environment to the point where the internal and external symmetries are dual to each other. Maybe there is simply no objective meaning to gigantic symmetry constructs simply because of the physical requirements of a system in terms of complexity, to with perfect confidence, infer a symmetry. If this is so, the "meaning" of TOE, would itself be context/observer dependent. So we seem to be lead to a idea of evolving theories nevertheless. I don't think that is wrong at all, I just thing ST has stumbled upon a problem, but are possibly far from the solution.
/Fredrik
  • Beyond the Standard Models
