What aspects of atom are discrete?
In summary, Zapper discovered that quantum spin precession is a rotation of spin vector around the axis of the external field H. Its a two-state system with energy difference E. Resonant frequency = delta E / h. After radio pulse at that frequency, some number of spins will flip to higher state.
giann_tee
133
Experiments in nuclear magnetic resonance for example, demonstrate that precessing atomic nuclei do it so smoothly. At the same time, atoms have discrete magnetic moments presumably associated with spins. Would anyone care to comment on the difference?
1. You are confusing the bulk magnetization of a material with the individual nuclear spins of atoms that make up the bulk material.
2. NMR also involves an application of another external magnetic field in another direction. In pulsed NMR, an 90 degree pulse can also be applied. This temporarily changes the direction of the net external field.
Zz.
I presume, precessing magnetic moments have random phases and then they can collectively precess smoothly. Except "random" means random moment in time to turn discretely. (Ok I'll shut up).
Zapper after 15000 posts its time for you to look back, because you already wrote everything, including the ULTIMATE ANSWER.
Zeeman effect lines (splitting of characteristic quantized atomic lines) vary smoothly (but not always linearly) with the magnitude of applied magnetic field. The splitting depends on J, L and S.
Very interesting. BTW, I encountered this tidbit about most precisely quantized thing...
"The quantization of the Hall conductance has the important property of being incredibly precise. Actual measurements of the Hall conductance have been found to be integer or fractional multiples of e2 / h to nearly one part in a billion. This phenomenon, referred to as "exact quantization", has been shown to be a subtle manifestation of the principle of gauge invariance. "
http://en.wikipedia.org/wiki/Quantum_Hall_effect
Huh?
What does the quantum Hall effect (which involves the supercurrent) have anything to do with your question on NMR, which involves the NUCLEAR magnetic moment?
Zz.
Zz.
Nothing I was just saying.
This is a little off-topic, but I just had to ask. Are you saying that QHE is analogous to supercurrent due to the fact that there is no backscattering in a conductor with Landau levels? I mean the situation in which the left and right-moving states are spatially separated.
Oh, I had a brain malfunction. I have no idea why I associated QHE with supercurrent. For some odd reason, I was thinking of SQUIDs.
Still, QHE has nothing to do with nuclear spins.
Zz.
Quantum spin precession I am reading, is a rotation of spin vector around the axis of the external field H. Its a two-state system with energy difference E.
<s_z> = hbar/2 * cos(delta E * t / hbar)
delta E = 2 * mu_Bohr * H_z
resonant frequency = delta E / h.
After radio pulse at that frequency, some number of spins will flip to higher state. That vector will point to a new lower angle (greater declination from z), a state not possible to imagine with a singe discrete spin, but okay with bulk magnetization vector.
It looks like you've answered your own question AND illustrated why I said you were confusing the individual nuclear spins with the bulk magnetism.
Zz.
I discovered one new book about magnetism, so good that I could study everything all over again. J. Stohr, H.C. Siegmann "Magnetism From Fundamentals to Nanoscale Dynamics". Its not specialized about spin lattices or MRI, but general.
Related to What aspects of atom are discrete?
1. What is the definition of a discrete atom?
A discrete atom is an atom that is composed of a nucleus, which contains protons and neutrons, and electrons orbiting the nucleus. This means that the atom is made up of distinct and separate particles, rather than being continuous or connected.
2. How are the components of an atom discrete?
The components of an atom, including the nucleus and electrons, are discrete because they are separated by empty space. The nucleus is composed of tiny particles called protons and neutrons, which are held together by strong forces. The electrons are then located in specific energy levels or orbitals around the nucleus, creating distinct boundaries between each component.
3. Are there any exceptions to the discreteness of atoms?
While atoms are generally considered to be discrete, there are some exceptions. In certain situations, such as at high temperatures or pressures, atoms can merge and lose their distinct boundaries. Additionally, in some molecules, the electrons are shared between atoms, blurring the lines between individual atoms.
4. Why is the discreteness of atoms important in chemistry?
The discreteness of atoms is important in chemistry because it allows us to understand and predict the behavior of atoms and molecules. The distinct boundaries between atoms determine the type of bonds they can form and the resulting chemical properties. Without this discreteness, it would be much more difficult to understand and manipulate the behavior of matter.
5. How do we know that atoms are discrete?
The discreteness of atoms was first proposed by ancient Greek philosophers, but it was not until the 19th century that scientists were able to prove it through experiments. In particular, the discovery of the electron by J.J. Thomson in 1897 provided strong evidence for the discreteness of atoms. Since then, advancements in technology, such as scanning tunneling microscopes, have allowed us to directly observe individual atoms and their discrete nature.
  • Atomic and Condensed Matter
  • Quantum Physics
