What can I investigate regarding the mechanics of bikes?
In summary, multiple threads on the same subject merged, Thread moved to the schoolwork forums, and the OP has been reminded to show more effort on their own schoolwork questions.
SwizzFizzicks
<< Multiple threads on the same subject merged, Thread moved to the schoolwork forums, and the OP has been reminded to show more effort on their own schoolwork questions >>
I want an investigation/research that is simple to experiment practically (I don't have fancy equipment. My main piece of equipment is my bike), but also complex enough that I can explore "theoretically" (meaning I can well beyond introductory mechanics principles). Can anybody list some ideas?
I know this is an open-minded question, but I just need ideas to get me started because coming up with an idea is excruciatingly difficult.
Thanks
Thanks
How about the effect of gears on maximum speed you can attain on a hill. Using various known gradients (up and down (and flat)) see what the maximum speed you can attain in each gear and thus see if you can find conditions for optimum speed. A fixed wheel bike would be good for the down grades, so that you don't merely roll off to the same maximum speed in every gear. Perhaps you need to restrict to flat and up-hill.
You can also answer the classical question: why does it work? In other words, what force will be needed to overcome the angular momentum in dependency of speed? What is it's (plus yours) drag coefficient, what it's friction (in dependency of tire pressure)? How long does it take to break?
I think on a bike (or bicycle?) you can explore almost the entire classical mechanics.
Likes OmCheeto
Welcome to the PF. :smile:
Your Profile page says that you are currently in high school. Is this a school assignment, or just a personal interest?
What kind of bike do you have? Road bike or MTB? What gearset / groupset are you running? What is your biking background? How many miles a week do you typically ride? Is the terrain mostly flat or mostly hilly where you ride? Do you clip in your biking shoes, use toe straps on the pedals, or just pedal on top of the pedals with regular shoes?
Also, do you have any background in electronics yet? Have you built any circuits (if so, what?)? Have you done any projects with a Raspberry Pi or similar microcontroller yet? What is your mechanical background? Do you have access to your school's machine shop? Does it have a CNC or 3-D printer that you can use to build things to use in your bike experiments?
Answers to all those questions will help us figure out some suggestions for experiments. :smile:
My current MTB ride (before the silly sidestand came off):
An excellent book to read that will very likely give you some ideas is: Bicycling Science, Third Edition, by David Gordon Wilson. Be sure to get the third edition because it has a lot more information than the previous editions.
Another book is Bicycles & Tricycles, An Elementary Treatise on Their Design and Construction, by Archibald Sharp. This book has many different ideas that have been tried, plus some of the physics.
Both of these books are still in print. Both are good reading for a person with the interests that you indicate.
Along with the bicycle, you can analyze body mechanics. You are after all, the bicycle's engine.
Back when I was at university, I once went to the gymnasium, and found that I could leg press 600 lbs.
Since I only weigh 150 lbs, what would be my new maximum velocity if I were able to utilize 600 vs 150 lbs of force?
I'm in high school, and I'm doing an Extended Essay for IB? I only have 1 bicycle and no fancy tools or measurement equipment, so it has be a pretty simple experiment, but complex enough that I can write 4000 words (lol, so many words xD) on it. What variables can I consider vs. stability of a bike?
P.S. I have a standard mountain bike (don't know the specific specs/model tbh)
This research essay/project is due in 10 days, and I'm pretty desperate lol.
Likes Binh Minh Duong
Multiple threads merged. Please do not create multiple threads on the same topic. Also, you never replied to all of the questions and suggestions in your first thread (the start of this combined thread). But you finally posted a few details in your second thread, which is of some help. It is concerning that you have not shown any effort on your part so far, though...
If you're still stuck on the assignment and haven't developed your stability theory, here's a project from childhood (meaning no $$):
Convert your bike for sound. Cheapest way is to find stiff but flexible small strips that can be clipped or attached to parts of the wheel (spokes perhaps) to strike the frame each revolution with enough noise you can hear to reach the mic on your phone. Collect sound data over several runs and process it with free apps you locate online or already in your phone/computer.
You should choose your variables depending on your measurements; what you are measuring. If your bike has a speedometer, compare sound data to speed? Record and match "peak speed" (if speedometer records highest speed each trip) to peak amplitude of the sound wave record of that trip. Also, record your bike estimated speed each trip. Graph and compare your data for each trip.
With no equipment you could compare sound from the front wheel to the rear. Do the sound files differ? On straight paths or turns?
[Compare sound graphs to your graphs by marking the time; say, on a flat known bike path Find position1 and position2 with phone keeping time. Many sound graphs have logarithmic vertical axis but time axis should allow you to roughly compare data. I'll leave any additional media such as pictures to you.]
Label everything neatly and include proper references in your essay (hint: the Wright brothers worked in and owned a bicycle shop...)
Sounds (no pun intended) incredibly intriguing! Thanks. May I ask what is the significance of an experiment such as this.
Sorry, I'm new to the forums :P
Will be more wary next time! Thanks for informing me.
I don't quite understand. Can you elaborate more please? What do you mean by "overcoming the angular momentum in dependency of speed?" What's drag coefficient? And what do you mean by "break"? Do you mean "brake"? I'm thoroughly confused lol.
Wait... So are you suggesting how does exerting force on the pedals while you're sitting on the bike vs. sitting on the bike without exerting any force on the pedals?
Would this experiment work with 1 bike? If so, explain ?
Significance of sound includes a real world (ontological) model of Doppler effect in one atmosphere (1atm), a sound example of principles of relativity. Meaning learning about sound helps learn physics.
Does a person you pass hear (the sound) of your bike the same as the rider hears the sound or (records a sound-wave)?
Say you ring a bike bell continuously (please don't!) or play music or a whistle as you pass?
Torque keeps the bike from falling over. The turning wheels provide stability, but how much?
I know it as ##c_W## value. It's air resistance. Wikipedia is has more details.
Sorry, yes, that was a mistake. Of course I meant brake.
SwizzFizzicks said:
... without exerting any force on the pedals?
Not much of a bicycle if there's no force on the pedals. I would call that, at the most, "art".
Haha I'm doing Physics HL IA. It's nice to see some IB Alum in here that are also interested in cycling lol.
Related to What can I investigate regarding the mechanics of bikes?
1. What are the main components of a bike and how do they work together?
The main components of a bike include the frame, wheels, brakes, gears, and pedals. The frame provides the structure and support for the bike, while the wheels allow it to move. The brakes help to slow down or stop the bike, and the gears allow for different levels of resistance and speed. The pedals provide the means for the rider to power the bike forward.
2. How does the size and shape of a bike's frame affect its performance?
The size and shape of a bike's frame can greatly impact its performance. A larger frame usually means a longer wheelbase, which can provide more stability and control while riding. However, a smaller frame can make the bike more agile and responsive. Additionally, the shape of the frame can affect the aerodynamics and overall efficiency of the bike.
3. How do different types of brakes affect the stopping power and handling of a bike?
There are several types of brakes commonly used on bikes, including rim brakes, disc brakes, and coaster brakes. Rim brakes use pads to grip the rim of the wheel, while disc brakes use a rotor and caliper system. Coaster brakes are built into the rear hub and are activated by pedaling backwards. Each type of brake has its own advantages and disadvantages in terms of stopping power and handling. Rim brakes are lightweight and easy to maintain, but may not perform as well in wet conditions. Disc brakes have better stopping power and can perform well in wet conditions, but are heavier and more complex. Coaster brakes are simple and low maintenance, but may not provide as much stopping power as other types of brakes.
4. How do gears work and what are the benefits of using them?
Gears on a bike allow the rider to adjust the level of resistance while pedaling, making it easier to ride up hills or go faster on flat terrain. Gears work by using a system of cogs and chainrings to change the ratio of pedal rotations to wheel rotations. The lower the gear ratio, the easier it is to pedal, but the slower the bike will go. The higher the gear ratio, the harder it is to pedal, but the faster the bike will go. By using gears, riders can conserve energy and ride more efficiently.
5. How can I improve the overall performance of my bike?
There are several ways to improve the performance of a bike. Regular maintenance, such as keeping the tires properly inflated and the chain lubricated, can help to improve the bike's efficiency. Upgrading components, such as the wheels or brakes, can also improve performance. Additionally, proper bike fit and riding technique can greatly impact the overall performance of the bike. Experimenting with different gear ratios and tire pressures can also help to optimize performance.
  • General Engineering
  • General Discussion
  • Quantum Physics
  • STEM Academic Advising
