seazal
- 119
- 3
This is serious question.
What knowledge can we gain by knowing or understanding the Higgs boson completely? What is the Higgs..
1. Easy problem?
2. Moderate problem?
3. Hard problem?
I need to see the complete lists of it that may be spread in many obscure papers in Arxiv. So kindly enumerate them.
Remember China would spend 5 billions dollars to create 100 TeV machine to probe the Higgs even if they seemed to realize no new particles could be detected. So there may be utmost importance mastering the Higgs.
Just in two months ago.
http://english.cas.cn/newsroom/news/201810/t20181023_199981.shtmlhttps://en.wikipedia.org/wiki/Higgs_boson
My interests in the Higgs is this part "The Standard Model leaves the mass of the Higgs boson as a parameter to be measured, rather than a value to be calculated. This is seen as theoretically unsatisfactory, particularly as quantum corrections (related to interactions with virtual particles) should apparently cause the Higgs particle to have a mass immensely higher than that observed, but at the same time the Standard Model requires a mass of the order of 100 to 1000 GeV to ensure unitarity (in this case, to unitarise longitudinal vector boson scattering).[162] Reconciling these points appears to require explaining why there is an almost-perfect cancellation resulting in the visible mass of ~ 125 GeV, and it is not clear how to do this. Because the weak force is about 1032 times stronger than gravity, and (linked to this) the Higgs boson's mass is so much less than the Planck mass or the grand unification energy, it appears that either there is some underlying connection or reason for these observations which is unknown and not described by the Standard Model, or some unexplained and extremely precise fine-tuning of parameters – however at present neither of these explanations is proven."
Would understanding the Higgs make us understand other stuff like dark matter, cosmological constant, etc. better? (what is the other "etc"?)
1. Easy problem?
3. Hard problem?
