What caused a rainbow near the setting sun?
  • I
  • Thread starter Buzz Bloom
  • Tags
    Rainbow Sun
In summary, I saw a partial rainbow that gradually faded out near the sun, along with a glory or 22° halo.
Buzz Bloom
467
About a half-hour before sunset I saw part of a rainbow extending upwards from the horizon about 10 degrees. All seven colors from red to violet were visible from left to right, but they were somewhat faded out. What caused this partial rainbow which I saw about 30 degrees north of the setting sun? As the sun set, the rainbow gradually faded out completely.
The setting sun itself was quite a sight also. Unfortunately I am not a photographer. I do not even know how to take a picture with my cell phone.
A red-golden sun started out about ten degrees above the horizon. Above was a dark gray cloud bank extending from abut 60 degrees south of the sun to about 20 degrees north of the sun. Below the dark clouds were lines of thin golden clouds extending out radially from the direction of the sun.
anorlunda said:
Did it look like a partial view of any of those?
Hi @anorlunda:
Thanks for your interesting post. What I saw did not resemble any of the photos in the article you cited. The odd characteristic of what I saw was the rainbow colors near the sun, only about 30 degrees away. All other rainbows I have ever seen had an azimuth about 160-180 degrees away from the sun.
Regards,
Buzz
It's hard to say for certain, but from your description it could have been a 22° Halo:
http://www.atoptics.co.uk/halo/common.htm
http://www.atoptics.co.uk/halo/mdisp6.htm
http://www.atoptics.co.uk/rainbows/notabow.htm
But there are other, less common, atmospheric effects as well- atoptics is a great site.
Likes Buzz Bloom
Hi @anorlunda and @Andy Resnick:
Thank you both for your responses. It seems likely that a partial 22 degree halo (the lower part near the horizon near sunset) is what I saw, except that as I remember it, red was closest to the sun rather than away. However, my memory could be playing tricks with me. I am going to have to learn how to take pictures with my cell phone.
EDIT
I previously misread the description at the atoptics site. It says:
Each 'dog' is red coloured towards the sun.​
So what I saw was probably a sundog.
Regards,
Buzz
Now it is my turn to thank you. I missed sun dogs in the Insights article, so I just went back and added a new passage and a new picture to the article.
Very bright sun dogs in Fargo, North Dakota. Also visible are parts of the 22° halo (the arcs passing through each sundog), a sun pillar (the vertical line) and the parhelic circle (the horizontal line).
Likes Buzz Bloom and Andy Resnick
Here's a lunar version:
The 22° halo is clearly visible, there's also a moondog (paraselene) and a bit of the paraselenic circle.
Related to What caused a rainbow near the setting sun?
1. What is the scientific explanation for a rainbow near the setting sun?
The scientific explanation for a rainbow near the setting sun is the same as any other rainbow - it is caused by the refraction and reflection of sunlight through water droplets in the atmosphere.
2. Why does a rainbow only appear near the setting sun?
A rainbow only appears near the setting sun because the angle of the sunlight hitting the water droplets is lower, making it easier to create a rainbow. The sun's position also plays a role in the location of the rainbow in the sky.
3. Can a rainbow form near the setting sun without rain?
Yes, a rainbow can form near the setting sun without rain. The water droplets needed for a rainbow can also be present in the form of mist, fog, or even dew.
4. Are the colors of a rainbow near the setting sun different from a regular rainbow?
No, the colors of a rainbow near the setting sun are the same as a regular rainbow. The colors are determined by the wavelength of light and the angle of refraction, which is consistent regardless of the location of the rainbow in the sky.
5. How rare is it to see a rainbow near the setting sun?
It is relatively rare to see a rainbow near the setting sun because it requires specific conditions of water droplets and sunlight at a certain angle. However, it is not impossible and can occur occasionally in certain locations and weather conditions.
  • Other Physics Topics
  • Astronomy and Astrophysics
  • General Discussion
  • Earth Sciences
12K
