What causes a plateau in the cross section of neutrons?
In summary, the flat part of the elastic scattering cross section of neutrons is due to the presence of nuclear resonances and the fact that neutrons do not experience electromagnetic forces. These factors result in a relatively constant cross section for elastic scattering.
ORF
170
Hello
It seems to me that the nuclei have a flat elastic scattering cross section of neutrons, for neutron energies from eV to MeV.
http://www.nuclear-power.net/wp-con...attering-Cross-section-light-elements-min.png
I thought that maybe it was caused because the neutron interact with the nuclei as a hard sphere, so the (quantum) cross section would be 4*pi*r^2, but the I didn't see the correspondence between the nuclear radii and cross sections.
What causes that flat part in the elastic scattering cross section of neutrons?
Thanks in advance :)
Greetings.
Thank you for your interesting question. The flat part of the elastic scattering cross section of neutrons is caused by the presence of nuclear resonances. These resonances occur when the energy of the neutron matches the energy levels of the nucleus, resulting in a higher probability of elastic scattering. This can be seen in the graph you provided, where there are spikes in the cross section at certain energies.
Additionally, the flat part of the cross section can also be attributed to the fact that the neutron is a neutral particle and does not experience the electromagnetic forces that charged particles do. This means that the cross section for elastic scattering is not affected by the size or shape of the nucleus, resulting in a relatively constant value.
I hope this helps to answer your question. If you have any further inquiries, please don't hesitate to ask. Thank you for your interest in nuclear science.
Related to What causes a plateau in the cross section of neutrons?
A plateau in the cross section of neutrons can be caused by several factors, including:
  • The energy level of the neutrons: Neutrons with higher energies are more likely to penetrate the nucleus and cause a plateau in the cross section.
  • The target material: Different target materials have different cross sections for neutron scattering, which can result in a plateau in the cross section.
  • The angle of incidence: If the neutrons are incident at a specific angle, it may result in a plateau in the cross section due to the geometry of the target material.
  • The presence of resonances: Certain energy levels of the target material may cause a resonance effect, resulting in a plateau in the cross section for neutrons of a specific energy.
  • The experimental setup: The design and setup of the experiment can also contribute to a plateau in the cross section, such as the use of collimators or beam filters.
How is the cross section of neutrons measured?
The cross section of neutrons is measured using a variety of techniques, including:
  • Neutron scattering experiments: By measuring the number of neutrons scattered by a target material at different angles and energies, the cross section can be calculated.
  • Activation analysis: In this method, a neutron beam is used to activate a sample, and the resulting gamma rays are measured to determine the cross section.
  • Time-of-flight experiments: By measuring the time it takes for neutrons to travel a certain distance, their energy can be calculated and used to determine the cross section.
  • Neutron flux measurements: By measuring the number of neutrons passing through a certain area over time, the cross section can be estimated.
Why is the cross section of neutrons important?
The cross section of neutrons is an important quantity in nuclear physics and engineering because it helps us understand how neutrons interact with matter. This information is crucial for applications such as nuclear power, radiation therapy, and neutron detection.
How does the cross section of neutrons vary with energy?
The cross section of neutrons can vary significantly with energy. In general, as the energy of the neutrons increases, the cross section decreases, but this relationship is not always linear. The cross section may also exhibit peaks or plateaus at specific energy levels due to resonances or other effects.
Can the cross section of neutrons be predicted?
The cross section of neutrons can be predicted to some extent using theoretical models and simulations. However, these predictions may not always match experimental results due to the many factors that can influence the cross section, such as target material, energy level, and experimental setup. Therefore, experimental measurements are still necessary to accurately determine the cross section of neutrons.
  • Nuclear Engineering
13K
