What causes radioactive decay?
In summary, radioactive decay occurs when the nucleus of an atom has an unstable proton-neutron configuration. At the instant of decay, it is triggered by the strong and electro-weak forces, which are quantum mechanical in nature. The consistency of half lives is due to the law of large numbers and the random nature of decay. The uncertainty principle also plays a role in this process. The cause of decay at any given instant depends on the type of decay and is constantly rearranging itself due to quantum actions.
JDude13
95
So... I know that decay occurs when the nucleus of an atom has an unstable proton-neutron configuration.
My question is, at the instant that decay occurs, what triggers it? Is it quantum mechanical in nature? If so, why are half lives so consistent?
We don't know.
Yes.
For a particular decay process in a particular isotope, the probability of a decay occurring in the next time interval is a constant. For example, say a nucleus of a particular isotope has a 10% probability of decaying in the next minute via beta decay. If it survives for one minute, it now has a probability of 10% of surviving for the next minute. And so on. No matter how long it survives, the probability of it decaying in the next minute is still 10%. We can use this property to derive the exponential decay law and the half-life.
jtbell:
I think I heard somewhere (which makes me very uncomfortable with placing any value in it) that the uncertainty principle has a role in this. Is it that there is a finite possibility that the emitted particle be far enough from the nucleus that the net forces acting on it propel it away?
Thanks for considering what might be an uninformed question. I take some consolation in Eleanor Ducksworth defining learning as a process of making increasingly subtle mistakes.
The quantum field theoretical explanation for the radioactive decay of nuclei are the strong and electro-weak forces which are responsible for alpha decay and beta-decay, respectively.
In all cases there is no reason why THIS nucleus decays NOW.
Look at qm tunneling through a potential barrier: you can only talk about the tunneling amplitude or probability, not about the time WHEN a certain particle will tunnel through the barrier.
We call decay spontaneous because it is not triggered by anything we know of.
The reliability of measurements of the half-life comes from the law of large numbers.
I know what causes radioactive decay. And I REALLY understand quantum actions.
Actually an unstable nucleus is constantly rearranging itself.since we cannot observe what goes on in the nucleus,decay is a random process.To answer your question more exactly,the cause of decay at that instant depends on the type of decay.in alpha decay the nucleons get arranged in such a way that the repulsion is high on particular protons.
its is of course quantum mechanical in nature.half lives are consistent because of the law of large numbers.Consider a single die.u roll it many times and the average will approach (1+2+3+4+5+6).the same case applies to the calculation and consistency of half lives.
Related to What causes radioactive decay?
1. What is radioactive decay?
Radioactive decay is the process by which unstable atoms lose energy and emit radiation in the form of alpha particles, beta particles, or gamma rays. This process results in the transformation of the original atom into a different element or isotope.
2. How does radioactive decay occur?
Radioactive decay occurs when an atom has an unstable nucleus, meaning that the number of protons and neutrons in the nucleus is not balanced. In order to become more stable, the atom releases energy in the form of radiation, which causes the nucleus to change into a more stable configuration.
3. What causes atoms to become unstable?
Atoms become unstable when the forces that hold the nucleus together, known as the strong nuclear force, are not strong enough to overcome the repulsive forces between protons. This can happen if the atom has too many or too few neutrons in relation to the number of protons.
4. Can we predict when radioactive decay will occur?
No, we cannot predict exactly when an atom will undergo radioactive decay. It is a random process, but we can calculate the probability of an atom decaying within a certain period of time, known as its half-life.
5. What factors can affect the rate of radioactive decay?
The rate of radioactive decay is affected by the type of element or isotope, as well as external factors such as temperature and pressure. However, the rate of decay remains constant for a particular isotope and is not affected by external factors.
