meloettakawaii
- 17
- 1
What causes rebounding?
is my reasoning correct? :
I've come to conclude that when things collide with one another, the force is absorbed by the molecular bonds of the material and depending on the material, either the force causes molecular 'crumpling' like when cars collide, or the force 'stretches' the molecular bonds, which 'snaps back' like a rubber band causing an opposite force that causes the rebound.
http://www.physicsclassroom.com/class/momentum/Lesson-1/Real-World-Applications
The Effect of Rebounding
Occasionally when objects collide, they bounce off each other as opposed to sticking to each other and traveling with the same speed after the collision. Bouncing off each other is known as rebounding. Rebounding involves a change in the direction of an object; the before- and after-collision direction is different. Rebounding was pictured and discussed earlier in Lesson 1. At that time, it was said that rebounding situations are characterized by a large velocity change and a large momentum change.
thanks
thanks
