What Causes Spacetime to Return to Uniformity?
In summary: If you release the masses at the poles, they will travel on the geodesics and reach the other side faster than if they had stayed at the equator. The reason they reach the other side faster is because their velocity vector has a shorter length.
cosmonium
so i am somewhat new to the theory of general relativity but in none of the papers i have read does anyone seem to explain what causes matter to attract... for example, the moon and the Earth are attracted to each other because each of them warps spacetime around themselves. these warped pockets could be thought of as low density areas in spacetime. Einstein says they attract because they are following the curvature of spacetime but what drives that motion? the only thing i can think of that would cause objects to want to clump together in a spacetime field is if spacetime is somehow elastic. it is as if for whatever reason there is a pressure-like force causing spacetime to want to return to a uniform distribution. is there a term for such a force and if so what causes it?
Inertia. GR says that gravitational motion is inertial motion.
interesting... could you expand on that? assuming 2 perfectly stationary objects in space that have are held in place for a long period of time (so any gravitational waves have already passed by) and then released, what about their inertia causes them to slope down the spacetime curvature?
You need to generalise velocity to the four-dimensional equivalent, the four-velocity. This is never zero; it always has length 1 in geometric units. For the case of a stationary (in the 3d sense) mass, you can interpret this (probably slightly loosely) as saying that it is only moving through time. But spacetime is curved. So once your masses are released, their inertial paths are curves - which is to say that their velocity vectors rotate and the masses acquire spatial motion.
You'll need to learn up to connection coefficients and the geodesic equation to get a rigorous explanation of that.
Likes Dale
Are you aware that on a sphere a great circle forms a "straight line" aka "a geodesic". If so, consider two nearby longitude lines. They are geodesics, and they are parallel at the equator but intersect at the poles.
Likes cosmonium
Related to What Causes Spacetime to Return to Uniformity?
1. What is spacetime and why does it need to return to uniformity?
Spacetime is the fabric of the universe that combines space and time. It is affected by the presence of mass and energy, which causes it to curve and bend. The concept of spacetime returning to uniformity refers to how it appears smooth and regular on a large scale, despite the presence of various celestial bodies and their gravitational effects.
2. What causes spacetime to become non-uniform in the first place?
The presence of mass and energy in the universe creates gravitational fields that cause spacetime to warp and stretch. This distortion can become more pronounced when there are large concentrations of mass, such as planets, stars, and black holes.
3. How does spacetime return to uniformity after being distorted?
The concept of spacetime returning to uniformity is based on the theory of cosmic inflation. This theory suggests that in the early stages of the universe, there was a rapid expansion that smoothed out any irregularities in the fabric of spacetime.
4. Can spacetime ever fully return to uniformity?
It is currently unknown if spacetime can ever truly return to a completely uniform state. The presence of mass and the ongoing expansion of the universe may continue to cause some level of distortion. However, on a large scale, spacetime appears to be fairly uniform and smooth.
5. How do scientists study the uniformity of spacetime?
Scientists study the uniformity of spacetime through observations and measurements of the cosmic microwave background radiation (CMB). This is the leftover radiation from the early stages of the universe and provides valuable information about the uniformity and structure of spacetime.
