What causes things to BEGIN moving in a field?
  • Thread starter yaje
  • Tags
    Field
In summary, the initial movement of objects in a field, such as gravity, is due to a change in velocity over time caused by a non-zero force. This change in velocity is known as acceleration and is responsible for objects moving from areas of higher potential energy to lower potential energy, gaining kinetic energy and speed in the process. Even if an object has no initial velocity, a force will cause it to start moving due to its acceleration.
yaje
so i know that things accelerate in a field (like gravity) because they move through a potential gradiant, gaining energy as they go. but why do they start moving in the first place? Bear with me.
Ok so i throw an apple up in the air. It has motion and energy that i gave it. It travels up away from the Earth and against the potential gradient until its kinetic energy is "used up" and it is motionless at a time t. Since it has absolutly no motion at this time t, up or down, what gives the apple the innitial nudge back toward the earth. At the time of motionlessness it is not crossing the equipotental lines and therefore it is not gaining or loosing energy. therefore its speed should remain the same, zero.
this confuses me. Things accelerate in a field because they are passing from places of higher potential energy to lower potential energy and the difference in pot. energies is converted into k. energies. if an object has no kinetic energy it is without motion. if it is without motion it cannot pass from a point of higher potential energy to a point of lower potential energy, thereby ganing k. energy and speed.
Ok so that's my question. i said it a couple of different ways trying to avoid confusion.
Acceleration is the change in velocity with time. So, it doesn't really matter what the initial velocity is; if there is a non-zero force on a particle, then it will have a non-zero acceleration, and thus its velocity will change over time. So, if a particle at rest (zero velocity) feels a force, it will start to move, because its acceleration dictates that its velocity must change at a certain rate. Clear?
FAQ: What causes things to BEGIN moving in a field?
What is a field?
A field is a region of space where a physical quantity, such as gravity or electromagnetism, can be measured.
How do things begin moving in a field?
Things begin moving in a field due to interactions between particles within the field. For example, in a gravitational field, objects will begin moving towards each other due to the force of gravity between them.
What causes a field to exist?
A field is caused by the presence of a source object or particle. For example, a magnetic field is created by the presence of a magnet, and an electric field is created by the presence of an electric charge.
Can a field cause movement in the absence of a source object?
No, a field cannot cause movement in the absence of a source object. The field itself does not have any physical substance or energy, it is simply a way to describe the interactions between objects.
Are all fields the same?
No, there are various types of fields such as gravitational, electric, magnetic, and more. Each type of field is associated with a specific physical quantity and has its own set of rules and behaviors.
