What Chemical Properties Affect Young's Modulus?
In summary, the modulus of a polymer is largely determined by its intermolecular forces. Poly(cis-isoprene) is elastomeric due to the way carbon-carbon bonds can rotate, while poly(trans-isoprene) is stiff due to the lack of rotation.
jkmiller
TL;DR Summary
Which chemical properties effect the physical property Young's Modulus? I know the answer is not as simple as intermolecular force
I can't seem to figure out which chemical properties govern the physical property that is young's modulus. For example, any linear (or with a low degree of branching) polyethylene with no crosslinking is still a somewhat rigid and solid substance (higher ym), whereas the most linear possible silicone with lots of crosslinking (VMQ) is super rubbery in the same temperature range (really really low ym) .
At their core, silicone and hydrocarbon plastics are chemically different on so many levels, but which differences are the ones that determine the modulus? I would assume it would be intermolecular force (so LDFs for both unless silicone can create temporary dipoles in that case I would predict them to be less fluid), which would make sense that silicones were more fluid because they are less linear, but there are plastics a whole lot less linear than VMQ that are way more rigid.
Help me physics friends I am but a lowly biochemist very lost in the realm of materials physics.
Likes atyy
Silicone is kind of like an elastomer, right?
Fundamentally, Young's Modulus is largely determined by intermolecular forces. At equilibrium, atoms sit (or, more correctly vibrate around) a point a certain distance from their nearest neighbours at which potential energy is minimised. You can think of it as sitting at the bottom of an energy well. Young's Modulus represents the force required to increase that distance from the unstressed equilibrium value.
In a simple, crystalline material, the Lennard-Jones function gives a pretty good approximation of potential energy versus interatomic distance, so you can do an order of magnitude calculation for Young's Modulus from just the binding energy.
With polymers, the potential energy curve is affected by microstructural features that need not be chemical in nature. For example, long linear molecules can be folded back on one another, so different atoms can be influenced by a varying number of near neighbours.
Perhaps the most dramatic example is the rubber-like elasticity of poly(cis-isoprene), in which rotation of carbon-carbon bonds allows the molecule to "unwind" under tension. By contrast, poly(trans-isoprene) is a stiff, relatively hard polymer going under the name of gutta-percha. It is the same chemistry, but completely different Young's Modulus
Likes atyy
Related to What Chemical Properties Affect Young's Modulus?
1. What is Young's Modulus?
Young's Modulus, also known as the modulus of elasticity, is a measure of the stiffness of a material. It is defined as the ratio of stress (force per unit area) to strain (change in length per unit length) in a material under tension or compression.
2. How is Young's Modulus related to chemical properties?
The chemical properties of a material can affect its Young's Modulus by influencing the strength and arrangement of its molecular bonds. Materials with strong and well-organized bonds tend to have a higher Young's Modulus, while materials with weaker or disordered bonds have a lower Young's Modulus.
3. Which chemical properties have the greatest impact on Young's Modulus?
The chemical properties that have the greatest impact on Young's Modulus are the type of chemical bonds present in a material, the strength of these bonds, and the degree of crystallinity of the material. Other factors such as temperature and external stresses can also affect Young's Modulus.
4. How do changes in chemical properties affect Young's Modulus?
Changes in chemical properties can cause variations in the strength and organization of molecular bonds, which in turn can alter the stiffness of a material. For example, increasing the strength of bonds can increase Young's Modulus, while introducing defects or impurities can decrease it.
5. Can Young's Modulus be predicted based on a material's chemical properties?
While there are some general trends between a material's chemical properties and its Young's Modulus, it is not possible to accurately predict Young's Modulus solely based on chemical properties. Other factors such as the material's microstructure, manufacturing process, and external conditions also play a significant role in determining Young's Modulus.
  • Thermodynamics
17K
  • Materials and Chemical Engineering
