What constant p.d. should be used in a potentiometer?
In summary, the use of a slide wire potentiometer and a galvanometer to find the electromotive force of an unknown cell involves finding the balance point, which should ideally be towards the center of the slide wire to reduce uncertainty. However, this would require a constant potential difference source that is twice that of the unknown cell, resulting in a higher sensitivity (worse) compared to using a lower constant potential difference source towards one end of the slide wire. This would also decrease uncertainty in the length measurement. Additionally, it is recommended to avoid taking readings towards the end of the wire to minimize errors and to take multiple readings for better accuracy. The sensitivity of the instrument can also be improved by using a longer wire.
andrew700andrew
I am trying to use a slide wire potentiometer and a galvanometer to find the electromotive force of an unknown cell. I have heard that the balance point at which the galvanometer needle has zero deflection should be towards the centre of the slide wire as this reduces uncertainty, however this would mean using a constant potential difference source which is twice that of the unknown cell. This would mean that the sensitivity of the instrument (in volts per centimeter) would be much higher (i.e. worse) than if the balance point was towards one end of the slide wire, meaning a lower constant p.d. source could be used and so the sensitivity would be a lower value (i.e. better). This would also decrease uncertainty in the length measurement because let's say a 1m slide wire was used and the measurement was 99 +/- 0.1cm that would give a lower percentage uncertainty than if the balance point was at 50 +/- 0.1cm . Please could someone tell me if my thinking is correct?
Equation for a galvanometer:
l1/l2 = E1/E2
As this is more of a discussion than a specific question I have discussed my thoughts in the first section.
Image of circuit:
Normally in a potentiometer arrangement done with meter bridge ,we advise not to take readings towards the end to avoid the end correction
/minimize error due to joints at the end ,
moreover the random error of observation is to be minimized by taking multiple readings and finally an average.
Multiple readings are taken by varying the current through a variable resistance.
Regarding sensitivity -it is fixed by the drop of voltage per unit length of the wire and to have more sensitivity one replaces the wire of 1 meter by say a 10 meter wire .
i do not think the measurements taken at the sides(end point) will be better as the end correction will start playing a dominant role.
Adding to what drvrm said, you cannot know the total length of the wire exactly so both your l1 and l2 will have measurement errors associated with them. The lowest overall percentage error in those measurements will occur near the center of the wire.
Likes drvrm
Related to What constant p.d. should be used in a potentiometer?
1. What is a potentiometer and how does it work?A potentiometer is a type of electrical component that is used to measure potential difference (p.d.) in a circuit. It works by using a sliding contact, known as a wiper, to make contact with a resistive track, which varies the amount of resistance in the circuit and therefore changes the p.d. that is measured.2. Why is a constant p.d. important in a potentiometer?A constant p.d. is important in a potentiometer because it allows for accurate measurements to be taken. If the p.d. changes, the measurements will also change, making it difficult to determine the accurate value.3. What is the standard constant p.d. used in a potentiometer?The standard constant p.d. used in a potentiometer is 1 volt. This value was chosen because it provides a good balance between sensitivity and accuracy.4. Can a different constant p.d. be used in a potentiometer?Yes, a different constant p.d. can be used in a potentiometer. However, it is important to ensure that the p.d. is stable and accurate in order to obtain reliable measurements.5. How do I determine the appropriate constant p.d. for my potentiometer?The appropriate constant p.d. for a potentiometer depends on the specific circuit and application. It is recommended to consult a reference guide or consult with an expert to determine the best value for your specific needs.
