What constitutes a body of mass?
  • B
  • Thread starter cjs94
  • Tags
    Body Mass
In summary, the concept of a single mass is dependent on the equipment used for measurement and the usefulness of single-mass models in predicting behavior. The Chandrasekhar limit is a factor in determining when a star becomes unstable, but it also requires a system to be spherically symmetric and stable before any added mass can cause collapse.
cjs94
How close do objects have to be to be considered a single mass? On Earth, with solid objects, the answer would seem to be intuitive: if an object can't fall any further then it is 'connected' to, or part of Earth's mass. But what about something like a gas giant, or a star?
I started thinking about this after learning of the Chandrasekhar limit. If there was a stable white dwarf whose mass was right on the limit and I threw an object at it, how close would it have to get before the star becomes unstable?
Chris
When is a composite body a single mass?
Depends on the equipment you are using to do the measurement ... if the composite object is close enough that the equipment sees a point source within accuracy, it's a single mass. From an optical telescope, solar systems about other stars are a single mass.
Another way of looking at it: an object is a single mass if single-mass models are more useful at predicting it's behaviour than multimass models.
For instance, all solids are collections of atoms vibrating in a lattice: however the multi-atom model of the solid (requires quantum mechanics) is a lot less convenient for designing a go-cart than Newton's laws applied to rigid bodies.
For the chandrasakar limit dwarf .. it is already unstable: it is like a pin balanced on it's point.
Try looking more at two stars approaching each other ... see what happens.
Thanks, but I was asking more about the natural effects of mass rather than its perception by an observer. My understanding of the Chandrasekhar limit is that if a star is below the limit then it will remain a white dwarf indefinitely, but if it is over the limit then it will start to collapse. My question is, if I throw at a star below the limit an object of sufficient mass to make it exceed the limit, how close does the object have to get to the star before it is considered 'part of' it and causes it to start collapsing?
The derivation of the Chandrasekhar limit assumes spherical symmetry and stability. So you couldn't just throw a mass, you have to wait until the system becomes spherically symmetric and stable.
Related to What constitutes a body of mass?
1. What is a body of mass?
A body of mass refers to any physical object that has mass and takes up space. This includes everything from tiny particles to massive planets and stars.
2. How is mass different from weight?
Mass is a measure of the amount of matter in an object, while weight is a measure of the gravitational force acting on an object. Mass is constant, while weight can change depending on the strength of gravity.
3. What are the SI units for mass?
The SI (International System of Units) unit for mass is the kilogram (kg). Other commonly used units for mass include grams (g) and metric tons (t).
4. Can an object have zero mass?
No, all physical objects have some amount of mass. Even objects that appear to have no mass, such as light, have a small amount of mass according to Einstein's theory of relativity.
5. How is mass measured?
Mass is typically measured using a balance or scale, which compares the mass of an object to a known mass. In scientific experiments, mass can also be calculated by measuring an object's density and volume.
  • Astronomy and Astrophysics
  • Classical Physics
  • Quantum Interpretations and Foundations
