What controls the Steam Pressure inside a boiler?
In summary, a boiler is designed with features that determine the maximum allowable steam pressure that it can produce. These features include the type of fuel, the size and shape of the boiler, and the design of the safety valve.
rollingstein
I've seen various types of boilers in industries e.g. 7 bar, 10 bar, 30 bar etc. What exactly in the operations / design of these boilers sets the steam pressure that will be produced?
For simplicity let us restrict ourselves to fire tube coal fired boilers that produce saturated steam. Something like in the sketch below.
https://commons.wikimedia.org/wiki/...media/File:Steam_Boiler_2_English_version.png
Is the pressure set by just the balance between the heat input rate & the steam removal rate? i.e. If you stoke a boiler fast enough you raise the Pressure so long as you have enough area & the shell can take the Pressure? Conversely if you consume steam fast enough every boiler becomes a low pressure boiler?
Is my understanding correct? Or is there another mechanism?
As for saturated steam, it's the temperature of water/steam that matters.
You can look up saturated steam pressure as a function of temperature in a "steam-table".
If you suddenly use a huge amount of steam in a boiler, thereby lowering the pressure, the boiling water will boil explosively, thereby lowering the temperature accordingly.
Indeed but that wasn't what I was asking.
Ok, let me rephrase: How is a 30 bar boiler different in design than a 10 bar boiler. Other than thicker walls. Assume both are rated for producing 2 tons / hr of steam.
The 30 bar boiler needs more heat input than the 10 bar boiler . Therefore bigger fire and greater heating surfaces .
Also as pressure gets higher so does the steam temperature so better materials become necessary for construction .
For old boilers, it's a guy reading a pressure gauge attached to the boiler. When the needle on the gauge shows the pressure is too high, then the guy (who is usually called the 'engineer'), cuts down on the rate of firing of the boiler, let's off steam (get it?), or both.
Newer boilers are fitted with automatic controls, where a set pressure is entered into the system, and it does the monitoring of the boiler's operation to make sure this set pressure is maintained.
http://www.nationalboard.org/Index.aspx?pageID=134
Now, they got codes and stuff to make sure you have some way to control the boiler so it doesn't, you know, go BOOM!
In any event, the boiler should be equipped with a safety valve which is designed to open if the boiler approaches its max. allowable working pressure. Ironically, the safety valve should never open, or a lot of people get into trouble, automatic controls or no.
Trouble with their bosses or trouble with the law?
Depending on the type of boiler and the situation, possibly both.
Things like ASME codes tend to get written into or referenced by local laws and operating regulations. You don't keep your equipment operating according to code, you often get a citation and a fine (or worse) if an inspector catches you, or unfortunately, an accident of some sort. Things like exploding boilers (admittedly an extremely unlikely occurrence) tend to bring unwanted publicity, even today.
It's a mystery to me how they explode even today. With the number of redundant protections I see even on a small sized boiler it ought to be really hard to make one explode even if you wanted to.
Tying down the safety valve will do the trick. Fortunately, such casualties are rare.
Which is why boilers and other pressure vessels are stamped with things like ASME markings during manufacture and inspected while in service.
Related to What controls the Steam Pressure inside a boiler?
1. What is the purpose of steam pressure in a boiler?
The steam pressure in a boiler is responsible for creating the necessary force to drive the steam through the system to power machinery, heat buildings, or perform other tasks. It is a crucial component in the functioning of a boiler.
2. What factors control the steam pressure inside a boiler?
The main factors that control the steam pressure in a boiler are the heat input, fuel type, and the size and design of the boiler. Other factors such as boiler load, steam demand, and external temperature also play a role.
3. How is the steam pressure regulated in a boiler?
The steam pressure is regulated by a device called a pressure regulator or pressure controller. This device monitors the pressure inside the boiler and adjusts the fuel and air supply to maintain a consistent pressure.
4. What happens if the steam pressure in a boiler is too high?
If the steam pressure in a boiler is too high, it can lead to a dangerous situation known as a boiler explosion. To prevent this, boilers are equipped with safety valves that release excess pressure when it reaches a certain level.
5. Can the steam pressure in a boiler be manually adjusted?
Yes, the steam pressure in a boiler can be manually adjusted by changing the settings on the pressure regulator or pressure controller. However, this should only be done by trained professionals as incorrect adjustments can lead to safety hazards and damage to the boiler.
  • General Engineering
  • Mechanical Engineering
10K
