What could cause a discrepancy in the Bias of a CCD
In summary, there is a discrepancy between the bias levels stated in the manual for the CCD and the values obtained through plotting and calculations. Possible explanations for this could be the effect of binning and the temperature at which the data was taken. The manual does not specify a temperature for the measurements. Without knowing the camera used and the steps taken to calculate the bias, it is difficult to determine the cause of the discrepancy. However, it is suggested to take some bias frames when the camera is unbinned to compare the values. The bias is an offset in the signal per pixel and is not affected by temperature unlike dark current. The manual for the CCD lists the bias as a feature and defines it as an offset in the signal per pixel.
starstruck_
185
This is assignment related, however it’s not really a problem solving question.
So we were to take darks from our school’s CCD. The manual for the CCD says there should be ~1000 ADUs/pixel for the bias, my graph (as well as many other people- they had similar numbers) says that the bias should be about 520 ADUs/pixel. I need to explain this discrepancy between the bias I found and the manual.
Here are some ideas I had, and I have no clue if they’re right or not:
The bias in the manual is the maximum possible
Maybe the binning might effect it? Although I don’t see why- the binning was set to 3x3 The temperature that the plots for my graph were taken at was at -10 degrees Celsius, so when the line of best fit and it’s function was used to determine the bias, it was in a linear relationship with data points in -10 degrees temperature. Perhaps it could be that the actual bias doesn’t have a linear relationship to this plot as it would have been taken at a different temperature?
Astronomy news on Phys.org
Does the manual specify a temperature for the measurements?
Without knowing which camera you were using and the steps you took to calculate the bias it's difficult to say where the discrepancy comes from. Did you do any processing, such as dark subtraction or apply any flats?
My understanding was that bias was unaffected by temperature, but I'm not sure about binning.
The manual does not, it only specifies a temperature for the dark current.
We only took 0.4 s exposure pics and did not process any data- the telescope was capped, we were only taking darks. All we did was plot the average of ADUs/pixel that was given in the side panel of the software we used for every pic.
The camera is the SBIG STLX-6303E
I unfortunately did have to hand in the assignment so I’m hoping for the best, so you don’t have to answer, but if you do, thank you!
I use the same camera for the research I do and haven’t ever been put in a position where I had to think about the bias discrepancy.
Try taking some bias frames unbinned and seeing what the bias is. If it's about 1000, then I would guess that the binning is the cause of the problem. Other than that I don't have any tips for you.
This turned out to have more questions than answers, but here goes. :oldsmile:
The general rule-of-thumb is that both chemical reactions and electronic device leakage currents double for every 10°C rise in temperature. That's why imaging chips are often cooled, as is yours. And the spec sheet for the camera lists values at 0°C, so that could account for the factor of two discrepancy.
I just checked the operating manual on-line (http://diffractionlimited.com/wp-content/uploads/2016/12/operating_manual_for_stx.pdf) and it does not have the word "bias" in it. So the above may not be applicable. Where did you find the word "bias"? Can you at least define it as used in the manual? What are the variables you are graphing?
Obviously, I'm not very familiar with telescope cameras but I hope the above is a little bit of help.
Likes starstruck_
In a CCD the bias or offset is a feature of the output electronics to ensure you don't get negative values from the A to D converter. It is commonly not the exact value specified in the manual as as long as it not too high or too low it does not matter. I
It should not vary significantly with temperature unlike the dark current which is quite sensitive to temperature and is a feature of the CC'D light sensitive pixels.
Regards Andrew
Likes starstruck_
For the project we’re required to purchase Project Manuals (specific to my Uni) which include all of our assignments and important stuff pertaining to the project and one of the things it includes is the Manual for the CCD which lists its Bias. As defined in the manual, the Bias is an offset in the signal per pixel. It exists because charge exists before the CCD is turned on or being used.
Like I mentioned before, I would find the bias level for the CCD when it is unbinned and see if it is different from what you are getting when the camera is binned.
Related to What could cause a discrepancy in the Bias of a CCD
1. What is a CCD and why is it used in science?
A CCD, or charge-coupled device, is a type of image sensor used in scientific research to capture and record images of objects or phenomena. It works by converting light into electrical signals, which can then be processed and analyzed by scientists. CCDs are often used in astronomy, microscopy, and other fields where high-resolution imaging is necessary.
2. What is bias in the context of CCDs?
Bias refers to a constant electrical signal that is present in all pixels of a CCD image, regardless of whether or not light is hitting the sensor. This signal is introduced during the image capture process and can affect the accuracy of the image data. It is important for scientists to understand and account for bias in order to accurately interpret their data.
3. How can a discrepancy in the bias of a CCD occur?
There are several factors that can cause a discrepancy in the bias of a CCD, including variations in temperature, exposure time, and electronic noise. Additionally, defects in the CCD itself, such as hot pixels or dark current, can also contribute to bias discrepancies. These factors can be caused by environmental conditions, equipment malfunctions, or other technical issues.
4. What are the potential consequences of a discrepancy in CCD bias?
A discrepancy in CCD bias can lead to inaccuracies in the resulting image data, which can affect the overall reliability and validity of scientific research. If bias is not properly accounted for and corrected, it can introduce errors and artifacts into the image, making it difficult to accurately interpret the data and draw meaningful conclusions.
5. How can scientists address discrepancies in CCD bias?
To address discrepancies in CCD bias, scientists may use techniques such as dark frame subtraction, where a dark image is taken with the same exposure time and settings as the actual image and then subtracted from the final image to remove bias. Other methods include cooling the CCD to reduce electronic noise and calibrating the sensor regularly to account for any variations. It is also important for scientists to carefully analyze and understand the sources of bias in their specific imaging setup in order to effectively address any discrepancies.
  • Astronomy and Astrophysics
  • Mechanical Engineering
  • Classical Physics
