What defines a deviation vector
In summary, Wald states that a Jacobi field that vanishes at a point on a timelike geodesic is a deviation field for the congruence of geodesics passing through that point. This is because a deviation field is a vector field that measures the deviation of nearby geodesics from a given geodesic, and a Jacobi field satisfies this condition by definition.
center o bass
560
In the last paragraph in Wald p. 224, he states that if one considers a timelike geodesic ##\gamma## with tangent field ##\xi## and ##p \in \gamma## and now looks at the congruence of geodesics passing through ##p##, then every Jacobi field which vanishes at ##p## is a deviation field for this congruence.
Questions:
1. What properties actually defines a deviation field?
2. Why is the statement above true?
1. A deviation field is a vector field that describes the deviation of nearby geodesics from a given geodesic. It can be thought of as a measure of how much the geodesics in a congruence diverge from each other.
2. The statement is true because a Jacobi field, by definition, is a vector field that satisfies the Jacobi equation along a geodesic. This means that it measures the deviation of nearby geodesics from the given geodesic. Since the tangent field of a timelike geodesic is also a Jacobi field, any other Jacobi field that vanishes at a point on the geodesic must also be a deviation field for that congruence of geodesics passing through that point.
FAQ: What defines a deviation vector
What defines a deviation vector?
A deviation vector is a mathematical concept used to describe the difference between a given point and a reference point. It is represented by the displacement between the two points in a specific direction and magnitude.
How is a deviation vector calculated?
To calculate a deviation vector, the coordinates of the two points (reference point and given point) are subtracted from each other. This results in a vector with direction and magnitude.
What is the purpose of a deviation vector?
Deviation vectors are commonly used in physics, engineering, and other sciences to quantify the difference between a measured value and an expected or theoretical value. They can also be used to determine the direction and magnitude of error in a measurement or experiment.
Can a deviation vector be negative?
Yes, a deviation vector can be negative. The direction of a deviation vector is determined by the reference point and given point. If the direction of the vector is opposite to the reference point, it will be considered negative.
How is a deviation vector represented?
A deviation vector is typically represented by an arrow pointing from the reference point to the given point. The length of the arrow represents the magnitude of the deviation, and the direction of the arrow represents the direction of the deviation.
