- 893
- 483
- TL;DR Summary
- Consider a simple atomizing spray nozzle: just a circular hole with liquid being atomized by a choked air flow. Can you use first principles to make a rough estimate of the particle size of liquid swept up in the gas jet? Where does the shear force that atomizes the drop come from?
Hi all
Another random, kinda open-ended question here. Sorry for that. I found myself reading about atomizing nozzles in oil burners, and got curious about the physics of atomized sprays. I didn't have much luck researching this on my own, so I'm turning to you all. It was the kind of situation where I either found resources that were super hand-wavy or super specialized.
Specifically, what forces are involved in breaking a macroscopic body of liquid into a mist of fine droplets? How does the gas flow generate these forces? What are the parameters of the gas flow that influence the particle size of the mist? Can you estimate the particle size, even crudely?
Just to show that I've made some effort, here's what I think I understand so far. I think that the force of surface tension resists atomization, since the spray of tiny particles has more surface area than a bulk liquid. My gut feeling says that it takes a shear force to break apart big drops into little drops, as opposed to a uniform force (like drag on the droplet due to the gas flow) which would only accelerate the droplet's center of mass. So I figure that the flow of air (I figure the air flow would be choked at the orifice) somehow causes a shear force on the liquid that splits it up into a mist of tiny drops. I feel like the magnitude of that shear force is what determines the final particle size, since the force of surface tension depends on the diameter of a drop in the mist, and since those forces should balance for the final particle size. But I have no idea what this shear force would be. How does a one-dimensional flow of gas induce a large shear force? It can't be the pressure of the gas on the drop, because that would be uniform over the cross-sectional area of a droplet, so it wouldn't shear the droplet. Are there just really high pressure gradients over small length scales? I'm pretty confused on this point.
Any kind of help is appreciated here, be it direct explanation or just pointing me to resources. Thanks all!
