What determines the direction of a reaction under standard state conditions?
In summary, the conversation discusses the determination of the direction of a reaction based on ΔG and ΔG° values. The first speaker got the correct answer of 28.76kj/mol for part 1. In part 2, they discuss how the reaction proceeds to the left if ΔG > 0, and clarify that "standard state" means a concentration of 1M. They also mention that ΔG° being positive indicates that the reverse reaction is spontaneous when everything is in the standard state. Finally, they remind the other person to distinguish between ΔG and ΔG° in part 3.
daphnelee-mh
66
If reactants and products were mixed in their standard-state concentrations,which direction would the reaction proceed?
Δ G = Δ H − T Δ S
Δ G = -RT ln K
For (1), I got the correct answer which is 28.76kj/mol.
For (2), the answer given is since Δ G > 0, the reaction proceed to left. I understand the meaning but what means by ' If reactants and products were mixed in their standard-state concentrations', is it indicate it is under standard state therefore just using the Δ G (standard) to determine the direction? As my first thought relates to the increasing in volume or concentration.
You can do it two ways; standard state here means concentration = 1M, so if you plug this value into al the concentrations in the expression for Q, the reaction quotient, you will find that Q >> K, so reaction has to proceed to the left to reduce product concentrations and increase reagent concentrations until Q = K. Alternatively, if you have already calculated ΔG°, which you have, observing that ΔG° is positive means that the reverse reaction is spontaneous when everything is in the standard state.
(Note: be careful to distinguish between ΔG and ΔG°; you need to do this for part 3.)
Likes daphnelee-mh
Related to What determines the direction of a reaction under standard state conditions?
What is the direction of a chemical reaction?
The direction of a chemical reaction refers to the movement of reactants to products or vice versa. This is determined by the relative energies of the reactants and products, as well as other factors such as temperature and concentration.
How is the direction of a reaction determined?
The direction of a reaction is determined by the law of thermodynamics, specifically the principle of energy conservation. The reaction will proceed in a direction that results in a decrease in free energy.
Can the direction of a reaction be reversed?
Yes, the direction of a reaction can be reversed by changing the conditions of the reaction, such as increasing the temperature or altering the concentrations of reactants and products. This can result in a change in the relative energies and favor the formation of either reactants or products.
What is the role of catalysts in determining the direction of a reaction?
Catalysts do not affect the direction of a reaction, but they can increase the rate at which a reaction occurs by lowering the activation energy required for the reaction to take place. This can make a reaction more favorable in a particular direction, but ultimately the direction is still determined by thermodynamics.
How does equilibrium impact the direction of a reaction?
Equilibrium is a state in which the rate of the forward reaction is equal to the rate of the reverse reaction. In this state, the concentrations of reactants and products will remain constant, indicating that the reaction is proceeding in both directions. The direction of a reaction at equilibrium is determined by the relative free energies of the reactants and products, and can be shifted by changing the conditions of the reaction.
13K
