What do all the useless engineering graduates do for work?
nnjoo
Apart from digging ditches and qa testing what jobs is one supposed to do?
Only the ones with bad attitudes get bad jobs.
Likes DrSteve, russ_watters, WWGD and 3 others
So your proposal is: bad attitude -> good attitude. Problem solved. /s.
It definitely helps.
Likes russ_watters and phinds
Sure it does. /s.
OP: Not sure how to parse your question. Is it (1) the "engineering degrees" per se that are useless; or is it (2) the "engineering graduates" who are useless? If you mean (2), then, well, useless persons are useless persons, regardless of whether they are engineering graduates or not; and by definition, useless persons have no use; so what's your point?
Likes DrSteve, vela, russ_watters and 1 other person
If you have an engineering degree from a good program with good grades then you should be able to find a job with a reasonable amount of effort. If that isn't happening then it is important to diagnose the actual issue.
1) Availability of positions in your area (can you relocate)
2) Rate of application (should be submitting multiple per day, spending several hours)
3) Interviewing skills (practice and training)
4) ...
There has to be an actual reason.
Likes russ_watters, Choppy, DaveE and 1 other person
My experience is we usually take low paying jobs in industry/design and struggle...I gave up. I'm a stay at home dad now(bad attitude). If you want money then you must constantly change jobs (usually for increased salary - and not really increased knowledge/skill). Learn how to talk a big game...by the time you are figured out you are already on to the next job with a raise. I've seen many others do it, it's not unique to engineering. There is a balance though, if you rise too high your wax wings will be melted by the sun...be careful of the investment bankers. Good luck.
Then don't reply if you're that confused. It's not rocket science.
  • Skeptical
Likes berkeman
No, it's not rocket science. It's a matter of good communication skills ... which (along with the aforementioned good attitude and other factors) are also key to landing good jobs.
Likes russ_watters, berkeman and renormalize
Thread closed for Moderation and troll patrol...
This thread got some surprisingly good answers and has run its course so it will remain closed.
