What do the atomic orbitals of Helium look like?
In summary, the conversation discusses the difficulty of finding graphs for more complex atoms, such as helium, due to the complexity of the Schrodinger equation and the large amount of data needed to plot the results. It is also mentioned that the psi-function's dependence on two position parameters may make it impossible to talk about individual orbitals for each electron.
sshai45
86
Hi.
I am wondering about this. I have been able to find many graphs showing what the atomic orbitals look like for hydrogen, but nothing for more complex atoms, like helium. Why is this? Now I know the Schrodinger equation for helium cannot be solved exactly, but you don't need an exact solution to plot a graph, which will be approximate anyways. Can't you just throw the Schrodinger equation into some kind of numerical differential equations algorithm and plot the results?
ADD: I just remembered that the equation has a psi-function which depends on TWO 3D position parameters, not 1 (1 parameter for each electron), which means it has a 6-dimensional parameter set. So using a grid of 100 points on a side in your numerical algorithm you would need one trillion (10^12) points, which would be several TB of data on a computer. Is this the reason? Even then, couldn't you exploit some kind of symmetry or use a more compact representation like a series expansion or something to cut it down to a more manageable data set?
Also, does the psi-function's dependence on two position parameters mean you cannot really talk of orbitals for each electron after all?
The "orbitals" are usually thought of as the sum of the two single electron states...
Related to What do the atomic orbitals of Helium look like?
1. What is an atomic orbital?
An atomic orbital is a region in space around the nucleus of an atom where there is a high probability of finding an electron. It is represented by a three-dimensional shape and describes the behavior and energy of an electron in an atom.
2. How many atomic orbitals does Helium have?
Helium has two atomic orbitals, specifically the 1s orbital. This means that there are two possible locations in space where an electron in a helium atom can be found.
3. What is the shape of the atomic orbitals of Helium?
The atomic orbitals of Helium are spherical in shape. This means that the electrons in Helium are most likely to be found in a spherical region around the nucleus.
4. What do the atomic orbitals of Helium tell us about its properties?
The atomic orbitals of Helium provide information about the energy levels of its electrons and how they are arranged around the nucleus. This helps us understand the stability and reactivity of Helium, as well as its bonding behavior with other elements.
5. How are the atomic orbitals of Helium different from other elements?
The atomic orbitals of Helium, as well as other noble gases, have a completely filled outermost energy level. This makes them more stable and less likely to form chemical bonds with other elements compared to elements with unfilled outer energy levels. Additionally, Helium only has two electrons, compared to other elements which have more, resulting in a simpler orbital structure.
  • Atomic and Condensed Matter
