Undergrad What do the Roman Numerals mean in Spectroscopic Data?
  • Thread starter Thread starter arthurhaythornthwait
    Data Mean
Roman numerals in spectroscopic data indicate the level of ionization of elements, with I representing neutral atoms, II for singly ionized atoms, and so forth. For example, Ar I denotes neutral argon, while Ar II refers to argon that has lost one electron. The discussion raises the question of how to denote negatively ionized species, as the Roman numeral system primarily addresses positive ionization. The conversation also touches on the historical context of Roman numerals and their limitations regarding zero and negative numbers. Overall, the thread clarifies the meaning of Roman numerals in spectroscopy while prompting further inquiry into negative ions.
TL;DR
What exactly does each roman numeral mean?
A basic question. Looking at the NIST spectroscopic data, what exactly is, for example, Ar I vs Ar II vs Ar III? If Ar I is unionised Argon, then is Ar II an Ar- ion or an Ar+ ion? (and whichever way around it works, how do we denote the opposite ionisation? If they are all ionized, is there such a thing as Ar 0 (plain argon)? I'm not aware that the romans understood zero or negative numbers...
arthurhaythornthwait said:
TL;DR Summary: What exactly does each roman numeral mean?
Welcome to PF. A quick Google search on Roman numerals in spectroscopy gives this as the first hit:
http://legacy.ifa.hawaii.edu/newsletters/article.cfm?a=517
Spectral lines are designated according to the level of ionization by adding a Roman numeral to the symbol of the chemical element. Neutral atoms are denoted by I, singly ionized atoms (those missing one electron) with II, and so on. For example, Fe IX represents an iron atom that is missing eight electrons.
Likes jim mcnamara
Who was it that said "you can tell the difference between a chemist and an economist by how they pronounce 'unionised'"?
  • Haha
Likes Twigg, DrJohn, arthurhaythornthwait and 1 other person
Thanks for this. It answers the question, but as always raises the other - what about negatively ionised species (Cl-, etc.) ?
A chef might say you're spelling it wrong.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
