What do we know about the formula for air drag force?
In summary, the formula for drag force is often simplified by using a constant value for drag coefficient, but at high speeds, this becomes more complicated and requires interpolation from a table. The underlying rules and equations, such as the Navier-Stokes equations, are well understood but do not always have analytic solutions. This remains a significant challenge in the field of external ballistics and could potentially lead to a Nobel prize for the solution.
victorhugo
127
Is it the typical "get some results and stack the maths together and chuck in some constants to make it fit to get some approximation" or do we understand the rules behind it to derive the formula, such as how the molecules repel each other and how energy is transferred depending on temperature, velocity, etc
If you're considering speeds greater than Mach 0.3, it gets complicated. In order to use the simple formula where drag force = Cd v2, Cd becomes a function of v, interpolated from measured or calculated values in a table. Wiki article, note table showing how drag coefficient varies with Mach (speed). In the wiki example, Cd is near constant until Mach 0.4 (it's also possible that when the table was generated, values of Cd for speed less than Mach 0.4 weren't important, so a constant Cd was chosen, not measured).
http://en.wikipedia.org/wiki/External_ballistics#Doppler_radar-measurements
Likes victorhugo
It is both.
We do understand the rules quite well, see Navier-Stokes Equations, unfortunately most of the time they do not have analytic solutions (*) so it's either heavy-duty number crunching CFD or back to method #1.
(*) And we don't even know if solutions exist. It is quite literally a million-dollar question, see http://www.claymath.org/millennium-problems
Probably. Sure worth a try :rolleyes: ... twice therefore !
Related to What do we know about the formula for air drag force?
1. What is air drag force?
Air drag force, also known as air resistance, is a force that opposes the motion of an object through air. It is caused by the friction between the air and the surface of the object.
2. How is air drag force calculated?
The formula for air drag force is Fd = 0.5 * ρ * v2 * A * Cd, where ρ is the density of air, v is the velocity of the object, A is the surface area of the object, and Cd is the drag coefficient.
3. What factors affect the air drag force?
The air drag force is affected by several factors, including the density of air, the velocity of the object, the surface area of the object, and the shape of the object. The drag coefficient also plays a significant role in determining the magnitude of the air drag force.
4. How does air drag force affect the motion of an object?
Air drag force acts in the opposite direction of the motion of an object, which means it slows down the object. The faster the object moves, the greater the air drag force will be. This can result in a decrease in acceleration and a change in the direction of motion.
5. Can air drag force be reduced?
Yes, air drag force can be reduced by changing the shape of the object, decreasing its surface area, or increasing its velocity. Certain objects, such as airplanes, are designed to minimize air drag force to improve their efficiency and performance.
  • Mechanics
  • Mechanics
  • Mechanical Engineering
