What do we mean by the charge on a body is denoted by "q"?
In summary, the conversation discusses the concept of electric charge and how it is a characteristic property of subatomic particles and can be transferred to a body by the transfer of electrons. The charge on a body is denoted by q, which is the numeric value of the charge measured. This value can be positive or negative, with the fundamental unit of charge being |e|, the electronic charge. The line "the charge on a body" refers to the amount of excess charge on a body, which can be measured and denoted by q.
SHASHWAT PRATAP SING
119
I am sorry if this is a silly question,
we know that-
Electric Charge is a characteristic property of a Subatomic particle.
And, a body is electrically charged by the transfer of electrons.
Then, what does it mean by this the charge on a body is denoted by q.What are we talking here.
Are we deoting this property by q ?
Also, what does it mean when we say a body has charge +2 ? what this +2 has to do with the property electric charge ?
It is expression of charge quantity as you use x in equation of math. It has unit Coulomb in SI Unit.
Charge has minimum unit called |e|, e is for electron. I guess +2 means charge +2|e|.
If it doesn't come with units or context defining the units, "charge +2" is meaningless. +2C is well defined.
Likes Dale
anuttarasammyak please tell me am I correct ?
This means that suppose a body has the property of electric charge and we measure it and it was found out to be +2C. So, we denote this +2C by q. Thus, this equation q=+2C is the mathematical representation of the above statement.
Likes anuttarasammyak
Electric charge is a slightly odd case. There is apparently a fundamental unit of charge denoted by |e|, the electronic charge of ##1.6x10^{-19}C##. If someone says "the charge is +3" they mean +3|e|. This is analogous to saying "the speed is 0.5" which means 0.5c. Just shorthand notation everyone agrees to use when convenient.
What does this line mean "the charge on a body".
Does this mean suppose a body has the property of Electric Charge and here we are talking about the magnitude of this charge.
It really means the excess charge a body. Macroscopic bodies are filled with +/- charges of nearly equal magnitude. The preponderance of one will lead to an excess.
Likes PeroK
hutchphd please tell me am I right ?
So, Basically this line-->"the charge on a body" means the amount of charge on a body or the numeric value of charge on a body. Right ?
Suppose a body has the property of Electric Charge and we intend to measure this property.So, by saying this line-->"the charge on a body" we mean that we are talking about the amount of charge on a body or the numeric value of charge on a body.
And after measuring this propety ,We denote this amount of charge(numeric value) by q. Which would be of the form q = ± ne.
So, Basically this line-->"the charge on a body" means the amount of charge on a body or the magnitude of charge on a body. Right ?
Suppose a body has the property of Electric Charge and we intend to measure this property.So, by saying this line-->"the charge on a body" we mean that we are talking about the amount of charge on a body or the magnitude of charge on a body.
We denote this amount of charge(magnitude) by q .
https://en.wikipedia.org/wiki/Electric_charge
You are ignoring the key emphasis (bold) in the response you got. And what do you mean by magnitude? Charge can be negative.
A.T. I know that charge can be negative.By saying magnitude I am taking about the numeric value of charge or amount of the charge.
I am just saying that in this line-->"the charge on a body" means the amount of charge on a body or the numeric value of charge.
Please help me
PeroK said:
PeroK, please tell me am I right here ?
I don't know that there is a difference between "amount" and "numeric value" in this case. If ##q## is the charge, then ##q## can be positive or negative. Those being the two types of charge found in nature.
This is one way electromagnetism is different from gravity: there is only positive mass; whereas, there are positive and negative charges.
PeroK I think you didn't understand my question.
My question is What does this line mean "the charge on a body" ?
for which I am asking that have I understood the concept ?
which would be of the form q = ± ne.
I know that charge can be positive and negative. For that I have also edited my question.
Yes, but most people would be happy with "Let ##q## be the charge on a body." You don't have to measure it because ##q## can be a variable. The same as any other variable, like mass and velocity and length.
Likes SHASHWAT PRATAP SING
PeroK, then what does this line mean -->the charge on a body is denoted by "q"?
I believe you're expected to understand a statement like that without a more fundamental analysis - certainly a physics textbook author would expect that statement to be self-explanatory.
Likes vela and Vanadium 50
"The charge on a body"...
In principle, this is a number, a signed integer equal to the number of positive charged particles in the body minus the number of negatively charged particles in the body.
In practice, for bodies larger than tiny atomized drops of oil the charge will be a large number. Large enough that we can divide by about 6 x 1018 to get a much more usable number -- the number of Coulombs of charge the body has.
So a body with an excess of 6 x 1018 positive elementary charges will have a charge of approximately one Coulomb.
When we say that this is "denoted by 'q'" we just mean that we are going to use the variable name "q" to denote the charge on the object. So for the above object, q would be 1 Coulomb.
There is nothing physically meaningful about the choice of the letter q. It is just a handy conventional choice. As long as everyone uses "q" to denote an amount of charge, it is easy to read equations and not get confused worrying that "q" might instead be used to denote time, distance, mass or temperature.
jbriggs444 Please tell me am I correct here -
So, when we say this line--> "charge on the object" means thatwe are talking about the amount of charge on a body. It is this Which we denote by q.
That's why we say this line that -->The charge on a body denoted by 'q' .
"The body's charge".
"The numeric value of charge on a body".
All are synonymous. They mean the same thing. [Though one might quibble that the last one needs units to make it truly synonymous].
Like mass, height, volume, density, length, temperature, location or velocity, charge is a value that quantifies some aspect of an object. It is a property of the object.
I do not know what you mean to say here. The variable q will have a numeric value. That value may be positive, negative or zero. We would probably choose to express that value as a number and a unit of measure.
For instance "q = 1 elementary charge"
or "q = -0.3 Coulomb".
We say that because it establishes an abbreviation. We can then use the letter q because it is clumsy to fill in equations with "the charge on the body" when we could put in "q" instead.
$$\text{The Force of the first body on the second body} = \text{Coulomb's Constant}\frac{\text{The charge of the first body} \times \text{The charge of the second body}} {\text{The distance between the two bodies}^2}$$
jbriggs444 my question is this only I want to know that what does this line -->The charge on a body denoted by q mean ?
and as you said-
Ok, so this line--> The charge on a body denoted by q means here we are talking about the amount of charge on a body.
So, q denotes the amount of charge on a body which is of the form --> q= ± ne
and we can choose to express that value as a number and a unit of measure.
Suppose If we are given this equation q=+2C , so this means that a body has the property of electric charge and the amount of electric charge this body has is +2C, Which is represented by q.
so, we write q= +2C
Am I correct now ?
I do not agree with this. One would never write "q= ± ne"
The ± symbol means that there are two possibilities. Either q = +ne or q = -ne. But if "ne" is the number of excess elementary charges on the object then there is only one possibility: q=ne [elementary charge units].
ne might be positive or it might be negative. But there is no need to indicate this with a leading ±. Doing so is erroneous.
so, we write q= +2C
Am I correct now ?
Yes, I think I agree with this. But we started with "q=+2C" and we ended with "q=+2C". That's a tautology.
jbriggs444 by q= ± ne
I mean that if a body is positively charged we will write q=ne
and if the body is negatively charged we will write q=-ne
But , yes you are right we will write q=ne and proper signs will be used while taking the values as ne might be positive or it might be negative. There is no need to indicate this with a leading ±
As it seems you realize now,
If the body is positively charged then ne is positive and q=ne.
If the body is negatively charged then ne is negative and q=ne.
If the body has zero charge then ne is zero and q=ne.
So jbriggs444, tell me have I now understood the concept correctly ?
Ok, so this line--> "The charge on a body is denoted by q" means here we are talking about the amount of charge on a body.
So, q denotes the amount of charge on a body which is of the form --> q= ne
so, we write q= +2C
so, we write q= +2C
What is "ne" supposed to mean? You keep using the term without definition.
Also, if we are given that q=+2C then we do not need any physical reasoning whatsoever to conclude that q=+2C.
here, n means the number of electrons transferred and e is the elementary charge. So, q = ne tells us about the quantisation of charge.
Number transferred? That has little to do with the number that are there now. "q" conventionally denotes the net charge that is there now.
If n is the excess number of electrons currently on an object and e is the unit of one [positive] elementary charge then then the correct formulation would be q=-ne
Sorry, jbriggs444 I have written wrong. So, I have deleted that post.
q=ne this means that the charge on a body(q) is integral multiple of a basic unit of charge (e).
jbriggs444 here I am just telling that what does q= +2C mean.
Here "q" is the charge on the body, "n" is the net excess of positive elementary charges on the body and "e" is a unit of charge equal to one elementary charge (i.e. the charge of one proton).
Yes.
So, for instance, a pith ball with deficit of 6 x 1017 electrons would have charge q equal to +6 x 1017 e or approximately +0.1 Coulombs.
[I suspect that is a rather enormous charge for a pith ball]
so, we write q= +2C
  • #31
Sorry, jbriggs444
What does the m=10kg mean?
The charge of "something" (say a body) is physical property in the same way that mass or volume are properties.
It is pointless to try to "explain" this by thinking about the number of charged elementary particles. You would presumably not try to "explain" the mass of a body by saying that it is the number of atoms multiplied by some constant, or?
Also, there is not need for the total charge to be a multiple of e, there are lots of situations where this is not tru; for example because of screening or because you are measuring say the average value of a dynamic process.
See e.g. single electron transistors (SETs) or Coloumb blockade.
Likes Vanadium 50, nasu, jbriggs444 and 1 other person
  • #32
I now this that-
Electric Charge is a characteristic property of Subatomic particles.
My question was this-
what does it mean by this line--> the charge on a body is denoted by q.
and for this I have written-
  • #33
I observe your statement is clear. I have no other interpretation.
  • #34
I now this that-
Electric Charge is a characteristic property of Subatomic particles.]
That depends on what you mean . It is of course true that charge ultimately comes from subatomic particles, but there are -as was mentioned above- many situation where the charge you can detect and measure comes from for example quasiparticles and exctions and since these are many-body effects you shouldn't (and mostly can't) relate their charge to subatomic particles (this is the reason for why quasiparticles can have fractional charges less than that of a single electron)
Again, this is not usually correct. Charge is usually a continuous variable (it is actually quite difficult to experimentally realize a situation where charge is quantised ) and can take any value, not just multiples of e.
See e.g. the spectrum of a Cooper pair box or a charge qubit if you want to see some experimental data.
  • #35
Would it have helped to introduce the idea of 'Net Charge'. Any body will have a huge number of equal and opposite charges in it but it is the imbalance or Net Charge that is often what matters. A Carbon and a Gold ball of equal dimensions will both cary the same (net) charge when charged to the same potential, although their total number of protons and electrons will be very different.
Likes nasu and hutchphd
