What does a helium balloon do on the ISS vs in open space?
In summary, according to the author, a helium balloon on the ISS behaves the same as if in space without a spacecraft.
zanick
383
23
What does a helium balloon do on the ISS . most say, its a 0 g environment, but is it really the same as intercosmos travel "0g"?
I saw a video of helium ballons on the vomit comet, where during the "0 g phase" the helium balloons went to the floor, while all other things floated. I would think for the same reasons, on the ISS space station, the artificial "0g" environment due to the centripetal force from gravity, canceling out the Earth's force on the ISS due to gravity, that the helium balloons would hit the floor as well.
I would then think in open space, all balloons would float with near equal characteristics.
true?
In the ISS, they have 'microgravity' rather than none at all. The floor is going 'slower' than if it were in its own orbit and the ceiling is going 'faster' than it would naturally. So there is actually a gradient of apparent gravity for things that are fixed and floating things will actually drift about (slightly) as they would naturally follow the orbit at which they were let go of.
It's something the crew seem to get accustomed to pretty easily, I believe. It is not good to go to sleep unless you are tethered in a sleeping bag.
zanick said:
I saw a video of helium ballons on the vomit comet, where during the "0 g phase" the helium balloons went to the floor, while all other things floated.due to gravity, that the helium balloons would hit the floor as well.
It is much easier to think of what a helium balloon will do if you remember that all the air around it is trying to do the same thing. If the vomit comet goes into negative g, then the mass of air will rise, forcing the lighter balloon down. Same thing with a balloon in an accelerating car.
In the ISS, first think about what the mass of air will do, then figure that the balloon will do the opposite.
Likes Klystron, phinds and anorlunda
The situation in the Vomit Comet is a bit difficult to analyse because the 'zero g' situation doesn't last long and there will be some transitory air currents to upset the situation. ISS is a better model to use, I think; with a 90 minute orbit time and a circular orbit there would be time to observe some more subtle effects.
But, of course, the bottom line is that everything in theory will be subjected to zero g so there would be no 'weight forces') A 10kg mass in one hand and the balloon in the other . . . . weird.
zanick said:
...during the "0 g phase" the helium balloons went to the floor...
Then it wasn't exactly 0g, or the balloons had an initial velocity from before the 0g phase.
zanick said:
...due to the centripetal force from gravity, canceling out the Earth's force on the ISS due to gravity...
That makes zero sense.
I've been on the vomit comet many times and this doesn't make sense since bouyancy forces are absent in free-fall. That said, the transition to free-fall is neither instantaneous nor perfect (in spite of the excellent pilots). Can you please post a link to this video?
Likes russ_watters and Ibix
I think that is the real answer. The balloon is just a visual marker telling us what the air is doing. It is illustrated in this video.
Likes sysprog
My expectation would be that the g force is zero in both the ISS and the vomit comet (@Andy Resnick's caveats aside), so there would be only tidal forces. These would make air slightly (very, very, slightly) denser at the highest and lowest altitude parts of the station/plane and minimum at the middle. Consequently I'd expect Archimedes' Principle to lead to the balloon floating around half way "up" the cabin.
The tidal forces are tiny for the Earth, so I'd actually expect the balloon to be moving hither and yon as air currents take it. And in the not-quite-free-falling vomit comet, I'd expect it to move opposite to dense objects, as in @anorlunda's video.
I like that even better.
It puts the focus on the air; the balloon only reacts.
(As evidenced by the fact that, if you removed the air, the balloon would plummet to the ground.)
I've always wondered about this zero-G thing, but never had anyone to ask till now:
Isn't the effect indistinguishable from simply plummeting in freefall? How do you get from 'the plane has dropped out from under me and I'm going to plummet to the ground' to 'I am comfortably floating'?
I mean, it's the same hair-raising effect as a plane take-off when it throttles back at altitude, and you feel like you're going to slide backward into the ground, right?
Does it take a while to make that mental leap? Does it stay once you've got it? or do you have to get used to it every time?
When you push off a trampoline, you are also in free fall for a few moments. It's not that "hair-raising".
Did you ever drop off a ten metre diving board? Hair raising or what?
The transition from 1g to 0g is the same regardless of the jump height. So the fact that a 10m jump is more scary than a 1m jump is not because the change in g-forces.
as was quoted, the 'hair rasing effect" is due to free fall. you get launched from a big tieter tauter , as soon as you are ejected, you are decelerating at 1g and at the apex height, you start to fall downward with a 1g acceleration. (correct?). the only reason your hair falls or floats is due to air drag.
my question is during a freefall, why don't you feel the acceleration, after all you have a force due to gravity acting on you, which means you are accelerating, but you feel like you are floating. of course as you fall from an airplane, you accelerate, ONLY to the point you reach terminal velocity.. (where you are not accelerating).. at this point do you now have weight? like on an elevator that has reached top downward speed, it is not accelerating anymore so you have weight based on 1g with respect to the floor of the elevator.
A.T. said:
The transition from 1g to 0g is the same regardless of the jump height. So the fact that a 10m jump is more scary than a 1m jump is not because the g-forces.
but jumping from an airplane, what happens at terminal velocity, when the force due to gravity is matched by the drag force and you are no longer accelerating... do you feel your weight again?... doesn't the vomit comet, in order to create zero g have curved parabolic flight path which basically is like a vertical launching of you in a container, which has no acceleration force after the launch, so you experience free fall on the way up and on the way down. in this example, the horizontal component is missing (the airplane horizontal velocity) . am i thinking of this correctly?
Sorry, by 'hair-raising effect' I meant 'poop my pants for fear of falling to my death' - not literally raising my hair.
Likes Nik_2213
Sure, but that isn't really the same sensation as being in an elevator that suddenly plummets. There's panic there. Partly because it lasts significantly longer than jumping off a trampoline. And you're aware you're picking up speed that whole time.
Well, you'd have a tough time feeling weight while spread-eagled and moving in a 180mph wind. How would you test that you have weight?
But you can do it. Imagine you are plummeting feet-first, and you've deployed a skateboard ahead of you. The skateboard, when aligned properly, will be braked by the wind. You will (in theory) be able to stand on it, and keep it pressed to the bottom of your feet. If you replaced the skateboard with bathroom weigh scale, it would display a measurable weight.
Einstein answered this question by saying that you aren't accelerating in any meaningful sense when you are in free-fall. Instead you are moving in the nearest thing one can have to a straight line in curved spacetime. People standing on the floor are the ones accelerating at 1g under a force from the floor (which, in curved spacetime, turns out not to necessarily entail moving anywhere).
It's like laying on an airbed. You feel pressure all over your lower surface.
yes, that's the reason and I agree.. its because of the things you see around you , but its still a rate of change of velocity that stays constant, correct?
A.T. said:
Then it wasn't exactly 0g, or the balloons had an initial velocity from before the 0g phase.That makes zero sense.
sorry, I misspoke. I was thinking and wanted to say that the ISS has centrifugal force equaling the centripetal force, canceling them out so there is weightlessness. ……..
as far as the balloons sinking (helium on the vomit comet), I think what could have happened is that the air in the cabin had a pressure gradient... agreed... then, as the plane does the parabola, the gradient disperses…. meaning, during the initiation of 0g, the higher density floor air goes up toward the ceiling to equalize and through this initial movement , the helium balloons react to this air movement in a negative way, similar to the balloon going forward in a car when decelerating. I guess the test would be when it stabilized, the helium balloons should then continue to move in the direction they are moving until slowed by air resistance or hitting an object in the plane.
If the air in the car is uniform temperature, it shouldn't move as the car accelerates. The balloon should move back and forth due to it's own buoyancy in the air. E.G., as the air accelerates forward, the gravity vector angles backwards, so the balloon leans forward. It does the opposite of a pendulum hanging from the ceiling.
And on the vomit comet you are aware that you are on a plane, not on an elevator that will crush into the basement.
That seems contrary to what I've read. the air in the car is at a constant speed or at rest, so with the velocity change of the car showing acceleration, the air mass in the car would compress toward the rear making the air more dense. this makes the helium balloon move toward the front of the car . this is why the gravity vector angling rearward, causes the balloon to move forward.
2 paris of forces.. opposing pressures and opposing forces. the balloon creates a pressure on the air and the air creates a pressure on the balloon and the vector angle of gravity pulls the balloon rear ward with a force that is less than the air mass being pulled rearward, which is its buoyancy force. the force on the balloon (its weight) is less than the force on the mass/volume of air .
its a misnomer to think that helium balloons work "opposite" to gravity, because in a vacuum, a helium balloon will fall like a rock! ;) buoyant force is just the volume and the density of the displaced fluid/gas x gravity. do I have this right? If so, the buoyant force is the force of how much of a fluid has been displaced. whether it floats, sinks or rises, depends on that weight (force due to gravity on the object)
another example of this, is a jar of water in a car with an air pocket in the jar on top. you accelerate the car, the liquid shifts to the rear facing of the jar in the car, and the air pocket is moved forward. buoyancy and gravity vector in action.
You got it exactly- the sensation is that you simply float. It almost feels like that gut sensation as you begin the main descent on a roller coaster. Now, it's a very noisy (sound) environment from the engines, there is a flight commander announcing each dive, 2-g climb, and turn; the nose-down maneuver is not instantaneous, and there are a couple of small windows so you can see the horizon go weird:
242469
But yes, it feels like the floor simply falls away.
FWIW, 'partials'- 0.16-g ('Lunars') and 0.4-g ('Martians') dives are *way* more disorienting. And everyone who barfs, barfs on the climb- not the dive.
Likes sophiecentaur
The air still has momentum. It will compress slightly in response to the acceleration - enough to push the balloon forward.
And that balloon would easily fall like a rock in a vacuum. so it has to be a buoyancy force /gravity creating a force (weight) that causes the balloon to move one way or another. the inertia of the air will raise the pressure in the back of the car upon acceleration. to say it acts "opposite to gravity" is a little too simplistic, as it really depends on the characteristics of the medium it is in.
Likes russ_watters
Observation of balloon in ISS will be complicated by all ventilation being 'forced' to prevent stagnant pockets developing...
  • #31
Here is the video. I condend that the balloons initially drop slightly due to the pressure gradient being neutralized due to the 0g condition, which causes a pressure change around the balloons for a brief period of time causing it to move .
  • #32
No, that will be negligible. There's at most about 4kg of air in a car. Even for a car accelerating at 1g, that would add about a hundredth of a percent to the density...plus the balloon is not rigid, so if the density of the air increased(it would be a gradient and increase on one side and decrease on the other) it would reduce the balloon's buoyancy, not increase it. Helium, on the other hand, is more than 90% lighter than air.
Either way, the balloon doesn't move without buoyancy.
The way you said that sounds funny. Yes, the balloon feels a force from gravity pulling down. But yes, buoyancy is the force due to the difference in density, pushing up. A helium balloon has a net force "up", and will move in whichever direction the local apparent gravity vector says is "up".
  • #33
Every air molecule would move toward the rear of the car under acceleration (or to the front under deceleration) But, you might be right here. (again) ;)
again, it is no different than the jar of water and a ping pong ball under the same conditions. buoyancy, yes, would change the position of the pingpong ball in the jar. I think this would or (could )be the psysdo force , analogous to Coriolis making the balloon appear to move forward or rearward.
either way, buoyancy, depends on the volume /density of the medium displaced AND gravity.. so, if the gravity changed its direction, then the balloon changes direction too because the buoyancy has a force opposite in direction to gravity... so I think you are right. I just had to say it out loud , and it makes more sense. the air has more weight than the balloon , as it faces the front of the car, the balloon goes the opposite direction .
  • #34
I believe the the Vomit Comet balloons are tethered and their downward motion is the direct result of the elastic nature of that restraint (cord + rubber nipple). They spring down...not particularly interesting in my view
Also WRT other discussion the fluid medium does not need to be compressible in order to create buoyancy. Water works very well.
If I am given a Mylar helium balloon for any reason, I always make it neutrally buoyant (plasti-tack adhesive gum !) and allow it to wander the premises. (The Mylar is remarkably impervious and you can learn stuff). It seems to me that the balloon is attracted horizontally to areas of higher humidity (which implies lower mass density at relatively fixed T). Theories?
Likes russ_watters
  • #35
good point about the compressibility not being a factor. so, let's use a car filled with water , with a floating helium balloon tied to a string...…. … the direction of gravity changes, so there for the direction of buoyancy force. just did an experiment with a large bottle of water and a little floaty... no question, it moves forward under acceleration , rearward on deceleration and inside if in a spincycle……. Russ is right, its based on the direction of the force due to gravity
  • Astronomy and Astrophysics
10K
  • Mechanics
9K
