What does a Wolpert's machine do?
  • Thread starter tarekatpf
  • Tags
    Machine
In summary, a Wolpert machine is a type of smart machine that can make predictions about the behavior of other smart machines. It was first described by Wolpert and built upon previous work by Alan Turing. The concept of "strong inference" was introduced, which refers to a machine's ability to predict the totality of conclusions made by another machine. Wolpert proved that no matter how smart a machine is, there will always be another machine that cannot be predicted by it.
tarekatpf
140
Here is a description of Wolpert's machine from an article published on livescience.com, but I did not understand anything. Would you please care to explain it for me?
"Basically, Wolpert — building on previous work by Alan Turing — formalized a description of "inference machines," i.e. machines capable of arriving at inferences about the world (human beings are one example of such machines). Wolpert focused on what he calls strong inference, the ability of one machine to predict the totality of conclusions arrived at by another similar machine. Wolpert then logically proved the following two conclusions: a) For every machine capable of conducting strong inferences on the totality of the laws of physics there will be a second machine that cannot be strongly inferred from the first one; b) Given any pair of such machines, they cannot be strongly inferred from each other."
Source: http://www.livescience.com/2995-theory.html
Pardon me if the question is not in right category, since I couldn't figure out which category the question should be placed in.
The description is clear. A Wolpert machine is a smart machine that tries to predict the behavior of other smart machines. Wolpert proved that no matter how smart you are, it is always possible to find another smart machine that is too complex in order to be predicted (even if you're smart enough to comprehend the totality of physical laws).
Likes 1 person
Thank you very much.
Related to What does a Wolpert's machine do?
1. What is a Wolpert's machine?
A Wolpert's machine is a theoretical concept proposed by mathematician and theoretical physicist William Wolpert. It is a hypothetical machine that can perform tasks without any external input or pre-programming, by continuously learning and adapting to its environment.
2. How does a Wolpert's machine work?
A Wolpert's machine works by using reinforcement learning algorithms, which allow it to learn from its environment and make decisions based on positive or negative feedback. It also utilizes Bayesian inference, allowing it to update its beliefs and actions based on new information.
3. What are the potential applications of a Wolpert's machine?
There are many potential applications for a Wolpert's machine, including artificial intelligence, robotics, and autonomous systems. It could also have uses in fields such as finance, healthcare, and transportation, where adaptive decision-making is crucial.
4. How is a Wolpert's machine different from other AI systems?
A Wolpert's machine differs from other AI systems in that it does not require pre-programmed rules or external input to make decisions. Instead, it uses learning and adaptation to continuously improve its performance in a given task.
5. Is a Wolpert's machine possible to create?
Currently, a Wolpert's machine is only a theoretical concept and has not been created in reality. However, with advancements in technology and artificial intelligence, it is possible that we may one day be able to create a functioning Wolpert's machine.
  • Quantum Interpretations and Foundations
  • Biology and Medical
  • General Discussion
