What does All but finitely many n mean?
  • Thread starter kntsy
  • Tags
    Mean
In summary: Therefore, the statement "all but finitely many n" means that the statement in question holds true for all infinite series, but may not hold true for some finite series.
kntsy
82
what does "All but finitely many n" mean?
Let [itex]\left(s_n\right)[/itex] be a convergent sequence.
If [itex]s_n\geq a[/itex] for all but finitely many n, then [itex]\lim s_n\geq a[/itex].
all n?(all the natural number? but natural number is infinite so why use "but finite"?)
Infinite?
Or finite?
What does it mean actually?
Mathematics news on Phys.org
Suppose you have an infinite number of light switches. An infinite number of them are in the off position. What do you know about the number in the on position?
Answer: nothing.
It might be that all the lights are off.
It might be that every other light is on. In this case, there are an infinite number of switches on and and infinite number off.
If might be that only the first five switches are on. In this case, there are only a finite number of switches on.
(This is similar to the concept of a Set of Measure Zero in Measure Theory).
"All but finitely many" says exactly what it means. If a statement is true for "all but finitely many" things (integers, triangles, whatever) then the set of all such things for which it is NOT true is finite.
The statement "n is larger than 10000000000000000" is true for "all but finitely many" positive integers precisely because it if not true for exactly 10000000000000000 positive integers, a finite number. The statement "n is even" is NOT true for "all but finitely many" positive integers because it is not true for all odd positive integers, an infinite set.
Likes DenisGi98
One more: in relation to a sequence, the statement [itex] s_n \ge a [/itex] for all but finitely many n means that there is some postive integer N such that [itex] s_k \ge a [/itex] for all integers [itex] k \ge N [/itex] (so, eventually, infinitely many terms of the sequence are at least as big as the number [itex] a [/itex].
Thanks hallsofivy and others.
but I do not quite understand your statement.
It IS true for "infinite" positive integers(2,4,6,8,10,...100,...1000,...).
Admittedly, it is NOT true for "infinite" positive integers(1,3,......1001...)but why this reason is enough refute the statement?
The clause "for all but finitely many" means that the statement in question fails to be true for only finitely many objects. Since there are infinitely many integers that are not even, "n is even for all but finitely many positive integers" is not correct.
English must be your second language I guess. Well, I don't really know, but it's the case for me. And for this very reason, it took some time to get this 'all but finitely many' clearly.
You know.. you should notice that 'all but finitely many' here in this context means not 'all and finitely many' but 'all except finitely many'. And if you interpret that this way, all the explanations should make sense now.
Could it be that it means that the statement holds true for any infinite series but not for a finite series? Since in an infinite series you always have the possibility of 'S' being greater than or equal to 'a' whereas in a finite series 'S' may be less than 'a'?
For example:
Let (Sn) [itex]\geq[/itex]a
If (Sn) [itex]\geq[/itex]a AND 'n' is infinite we can say that
Limn->[itex]\infty[/itex]Sn [itex]\geq[/itex] a
For example:
Let Sn = [itex]\sum[/itex]1/xn AND a=2
For an infinite series there is always a possibility for Sn to be [itex]\geq[/itex]a but this does not necesarily hold true for a finite series (i.e. n=5,10,1000...etc.)
Related to What does All but finitely many n mean?
1. What does "All but finitely many n" mean?
"All but finitely many n" means that for any given number n, there are only a finite number of exceptions or values that do not follow a certain rule or pattern.
2. How is "All but finitely many n" used in scientific research?
In scientific research, "All but finitely many n" is often used to describe a trend or pattern that is consistent for a large majority of cases, with only a small number of exceptions. This can help scientists make generalizations and predictions about a particular phenomenon.
3. Can you give an example of "All but finitely many n" in action?
For example, if we say "All but finitely many n" prime numbers are odd, we are acknowledging that there are a few prime numbers that are exceptions to this rule (2 being the only even prime number), but the vast majority of prime numbers follow the pattern of being odd.
4. How is "All but finitely many n" different from "All n"?
"All but finitely many n" differs from "All n" in that it allows for a small number of exceptions, whereas "All n" implies that every single case follows a certain rule or pattern with no exceptions.
5. Why is it important for scientists to understand the concept of "All but finitely many n"?
Understanding "All but finitely many n" is important for scientists because it allows them to make more accurate and meaningful conclusions about a particular phenomenon. By acknowledging that there may be a few exceptions to a certain rule or pattern, scientists can avoid making overgeneralizations and can better understand the complexities of the natural world.
  • General Math
  • General Math
