What does cold hydrogen gas emit at 1420 MHz?
In summary, The Eerie Silence by Paul Davies asserts that the radio astronomers looking for radio signals from extraterrestrial civilizations search for radio signals at the frequency 1420 MHz because that is the emission frequency for cold hydrogen gas.
bluemoonKY
131
I just read Paul Davies book The Eerie Silence. In The Eerie Silence, Paul Davies asserts that the radio astronomers looking for radio signals from extraterrestrial civilizations search for radio signals at the frequency 1420 MHz because that is the emission frequency for cold hydrogen gas. What does cold hydrogen gas emit at 1420 Mhz?
Chemistry news on Phys.org
What hydrogen gas emits at 1420 MHz is electromagnetic radiation at 1420 MHz.
This frequency corresponds to the transition between the splitted ground state due to hyperfine structure.
Likes bluemoonKY
Why does hydrogen gas emit electromagnetic radiation at all?
There are three main types of interaction between bound state electrons and photons: absorption, stimulated emission, and spontaneous emission. The first one involves annihilation of a photon to raise the electron state to a higher level. The last two, opposite to the first one, involve creation of a photon by decreasing the state of an electron to a lower level, and eventually to end up in the ground state.
When an atom is already in the ground state it won't emit photons/EM radiation no matter how. If it's not in the ground state, it will emit EM radiation through spontaneous or stimulated emission. Spontaneous emission is actually a quantum electrodynamics effect which describes the interaction between electron and the vacuum field. Stimulated emission is a form of perturbation experienced by an atom when an already existing EM radiation disturbs an atom in an excited state.
Likes bluemoonKY
So is the electromagnetic radiation that cold hydrogen gas emits a stream of photons, or is the electromagnetic radiation that cold hydrogen gas emits an electromagnetic wave?
First, in the loose sense, a "stream" of photons is kind of equivalent to an electromagnetic radiation. Second, the thing which is emitting is the hydrogen atom, not the electromagnetic radiation. Electromagnetic radiation, which is the synonym of electromagnetic wave, is what the atom emits.
Likes bluemoonKY
Both. Have you heard about https://en.wikipedia.org/wiki/Wave–particle_duality?
Likes bluemoonKY
Blueleaf and Borek, your posts are very informative.
Does 1420 MHz mean a frequency 1420 cycles per second?
When cold hydrogen gas emits electromagnetic radiation at 1420 MHz, how are the cycles measured? Do they measure the frequency from the crest of one electromagnetic wave to the next crest?
Yes.
I guess astronomers use radio telescope to detect 21 cm line. I don't really know how this equipment exactly works though, so you should probably google this term or start another thread in astronomy and cosmology section of this forum.
Blueleaf, what is the significance of 21 cm?
That's the wavelength of EM radiation of frequency 1420 MHz. As far as I know it's used to map the distribution of hydrogen-rich area with low to moderate density in space.
Likes blue_leaf77
Ah, I was careless in post #9. Yeah, it should be what scanvas said.
Is 1420 MHz the same as 1.42 billion cycles per second?
M stands for million, G stands for billion (at least in some languages :rolleyes:). So yes, that's correct (in some languages at least).
Hz is the unit Herz, which is cycles per second. The M stands for "mega", which means million.
I sure learn a lot of new stuff at physicsforums. God bless this website!
Related to What does cold hydrogen gas emit at 1420 MHz?
1. What is the significance of 1420 MHz in relation to cold hydrogen gas?
1420 MHz is the frequency at which cold hydrogen gas emits radiation, also known as the hydrogen line. This emission is a key characteristic of hydrogen gas and is used in various astronomical and scientific studies.
2. How is the radiation from cold hydrogen gas at 1420 MHz detected?
The radiation emitted by cold hydrogen gas at 1420 MHz can be detected using a radio telescope. This specialized instrument is designed to capture and measure radio waves, including the specific frequency emitted by hydrogen gas.
3. What causes cold hydrogen gas to emit radiation at 1420 MHz?
The emission of radiation at 1420 MHz is caused by a phenomenon known as hyperfine splitting. This occurs when the energy levels of the electrons in a hydrogen atom change, resulting in the emission of radiation at a specific frequency.
4. How is the emission of radiation at 1420 MHz used in scientific research?
The emission of radiation at 1420 MHz is used in a variety of scientific research, including studies of the structure and composition of the Milky Way galaxy, as well as in the search for extraterrestrial life. It is also used in studies of the early universe and the formation of stars and galaxies.
5. Can other elements emit radiation at 1420 MHz?
No, only hydrogen gas emits radiation at 1420 MHz. This is due to the unique energy levels of hydrogen atoms that result in the hyperfine splitting phenomenon and the emission of radiation at this specific frequency.
  • Astronomy and Astrophysics
9K
