What does cross section area mean when dealing with stress/strain?
In summary, the cross section area is the area of the loaded object perpendicular to the plane of the load.
Jay520
What does "cross section area" mean when dealing with stress/strain?
For clarification, here is an example problem:
A circular steel wire 2 m long must stretch no more than 0.25 cm when a tensile force of 400 N is applied to each end of the wire. What minimum diameter is required for the wire?
Relevant equations
FL = YA(ΔL)Apparently, the cross section area for this object is simply pi*r^2 (as for any circle). Can someone tell me exactly what the cross section area is supposed to refer to? I thought it was the area of the plane of the object perpendicular to the applied force, but apparently I'm wrong or not understanding something properly.
Why do you feel that you are wrong or not understanding something properly?
Chet
I don't know what the definition of "cross section area" is. At least not well enough to apply it to the context of elasticity physics problems.
When you put the wire in tension, the tensile stress is calculated using the circular cross-section of the wire.
The tensile stress σ = F/A, where F is the tensile load (Newtons) and A is the cross section area (m^2), and the stress σ has units of pascals (N/m^2)
For a circular wire, A = πR[itex]^{2}[/itex] or πD[itex]^{2}[/itex]/4, where R (radius) or D (diameter) of the wire are measured in meters.
The elongation of an object undergoing a tensile load is
δ = FL/AE
where
F = tensile load (Newtons)
L = unloaded length of the object (meters)
A = cross sectional area of the object (m^2)
E = modulus of elasticity of the material (Pa)
The cross section just refers to the shape of the loaded object which results from its intersection with a plane oriented normal to the applied load.
For a long cylindrical body (not necessary a circular cylinder), the cross sectional area is obtained by cutting the cylinder with a knife perpendicular to its axis and looking in at the exposed area. The area that is exposed is the cross sectional area of the cylinder.
Chet
Related to What does cross section area mean when dealing with stress/strain?
1. What is the definition of cross section area?
The cross section area refers to the area of a material that is perpendicular to the direction of the applied force or stress.
2. How is cross section area related to stress and strain?
The cross section area is directly related to the stress and strain of a material. As the area decreases, the stress and strain experienced by the material increases.
3. Why is cross section area important in understanding stress and strain?
Cross section area is important because it helps determine the amount of force that a material can withstand before experiencing stress and strain. It also affects the magnitude of the stress and strain experienced by the material.
4. How is cross section area measured?
Cross section area is typically measured using a ruler or caliper to determine the dimensions of the material that are perpendicular to the applied force. These measurements are then used to calculate the area using the appropriate formula.
5. Can cross section area be changed?
Yes, cross section area can be changed by altering the dimensions of the material. Increasing the area can help reduce the stress and strain experienced by the material, while decreasing the area can increase the stress and strain.
