What does flux of electric field physically signify?
In summary, the flux of the electric field is a measure of the amount of field passing through a given surface and is directly related to the amount of charge enclosed by that surface. The concept of field lines can be used as an analogy to understand this concept, but it should be noted that there are actually an infinite number of field lines due to the field being defined everywhere in space.
gandharva_23
61
What does flux of electric field physically signify ? What are we actually calculating by calculating flux . i read somewhere that it is the number of lines of electric lines passing normal to a given area . if we have a charge q then arent there infinite electric lines possible ?
The flux of the electric field is essentially the amount of field going through a surface. It may help to think in terms of a fluid analogy where the flux does have the meaning of number of particles flowing across the surface in unit time. Note that this is only an analogy, however.
In electrical systems, the flux of the electric field through a surface is a measure of the charge enclosed by that surface. More charge inside produces a larger field and a greater flux.
This notion of counting of field lines is another helpful analogy, but as you have realized, the field line concept can be misleading. There are an infinite number of such lines since the field is defined everywhere in space.
The way to use field line diagrams is that the "density of field lines" is proportional to the strength of the field. The idea can be made more precise (and possibly more intuitive with sufficient motivation) using a different pictorial representation ("flux tubes") http://www.ee.byu.edu/forms/forms-home.html
FAQ: What does flux of electric field physically signify?
What is meant by flux of electric field?
The flux of electric field is a measure of the flow of an electric field through a surface. It represents the total number of electric field lines passing through a given area.
How is the flux of electric field calculated?
The flux of electric field is calculated by taking the dot product of the electric field vector and the surface normal vector, and then multiplying it by the surface area. This can be expressed mathematically as Φ = E * A * cos(θ), where Φ is the flux, E is the electric field, A is the surface area, and θ is the angle between the electric field and the surface normal.
What does a positive or negative flux value indicate?
A positive flux value indicates that the electric field lines are passing through the surface in the direction of the surface normal, while a negative flux value indicates that the electric field lines are passing through the surface in the opposite direction of the surface normal.
What is the unit of flux of electric field?
The unit of flux of electric field is volt-meters (V•m) or newton-meters squared per coulomb (N•m2/C).
How does flux of electric field physically signify the strength of an electric field?
The flux of electric field is directly proportional to the strength of the electric field. A larger flux value indicates a stronger electric field, while a smaller flux value indicates a weaker electric field. This relationship is described by Gauss's law, which states that the flux of electric field through a closed surface is equal to the total charge enclosed by that surface divided by the permittivity of free space.
