What Does It Mean For A Force To Act On A Particle?
In summary, The conversation discusses whether a force must do work on a particle in order for it to be considered as acting on the particle. One person argues that even if the particle does not move, the force still affects the equilibrium state and can be considered as acting on the particle. They give an example of a hydrogen atom in a magnetic field. Another person adds that this can also be seen in a simple example of a hanging body and an elastic thread.
iScience
466
I know this is kind of a dumb question but please forgive me it's been awhile.
Is it enough for a particle to merely "feel" an external force F to state that "F is acting on the particle"?
ie if the particle was confined in a potential well and experiences F but does not move.
or does $$\vec{F} \cdot d\vec{s}$$ have to be non-zero? ie does force have to do work on the particle to state that "F is acting on the particle"?
Yes, I would say that a force 'acts' on a particle even if it doesn't move. It still affects the equilibrium state, meaning that the energy level, orbit, or whatever of the particle and its surrounding environment is different when the force is applied versus when it is not applied. Force example, if you place a hydrogen atom in a magnetic field the atomic energy levels shift slightly even though the electron is still in a stationary state and isn't being ripped from its atom and accelerated away.
Likes Dale
Thank you!
Another simple example: hang a heavy body at the roof with an elastic thread; at equilibrium you can verify and measure the existence of the thread's force on the body with its elongation; cut the thread and the body falls down.
lightarrow
Related to What Does It Mean For A Force To Act On A Particle?
1. What is a force?
A force is a push or pull that can cause an object to accelerate or change its motion.
2. How does a force act on a particle?
A force acts on a particle by exerting a push or pull on the particle. This can cause the particle to accelerate in the direction of the force.
3. What is the difference between a contact force and a non-contact force?
A contact force is a force that requires direct contact between two objects, such as a person pushing a cart. A non-contact force is a force that can act on an object without direct contact, such as gravity or magnetic force.
4. What factors determine the strength of a force on a particle?
The strength of a force on a particle is determined by the magnitude of the force, the direction of the force, and the mass of the particle. The greater the magnitude of the force, the stronger the force will be on the particle.
5. How can we measure the force acting on a particle?
The force acting on a particle can be measured using a device called a force meter or by using mathematical equations, such as Newton's Second Law of Motion (F=ma).
