MHB What Does It Mean for Expressions to Be Non-Integral and Non-Rational?
  • Thread starter Thread starter Drain Brain
    Integral Rational
Expressions are considered non-integral when they do not consistently yield integer values, as seen in the example $\frac{4y}{x}$, which fails to be integral in x unless x is specifically 1 or a common factor. Non-rational expressions, like $3x\sqrt{y}z^3$, do not always produce rational values; in this case, y must be a perfect square of a rational number for the expression to be rational. The distinction between integral and rational is crucial in understanding the behavior of algebraic expressions. Non-integral and non-rational expressions can lead to undefined or non-standard results in mathematical contexts. Understanding these concepts is essential for accurate mathematical analysis and problem-solving.
Drain Brain
can you explain what it means when they are not "Integral" and not "Rational"?
$\frac{4y}{x} = 4yx^{-1 }$ is not integral in x
$3x\sqrt{y}z^3$ not rational in y
Mathematics news on Phys.org
To be integral, your expression needs to always give an integer value. If x is anything but 1 or a common factor of the top, then your first expression will not be integral.
To be rational, your expression needs to always give a rational (fractional) value. If y is anything but a perfect square of a rational number, then the second expression will not be rational.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
