Graduate What does it mean to model the distribution of galaxies as cosmic dust?
Modeling the distribution of galaxies as cosmic dust treats galaxies as small perturbations within a continuous medium, allowing for a fluid-like representation of matter in the universe. This approach suggests that the intrinsic angular momentum and torsion observed in cosmic dust emerge from the collective motion of galaxies, rather than from individual structures. The galaxy rotation curve problem, which highlights discrepancies in observed versus predicted rotational speeds, can be reinterpreted through this cosmic dust framework, potentially linking it to broader issues like the spin crisis in particle physics. Additionally, incorporating Einstein–Cartan theory allows for the inclusion of torsion in spacetime geometry, offering a new perspective on galactic dynamics without relying on dark matter. Overall, this modeling provides a novel way to understand the large-scale structure and behavior of the universe.
Jerome Wang
I read a paper published in General Relativity and Gravitation:
On the local geometry of rotating matter
Some of the content in Section 5 raised my doubts, and the content is as follows:
In cosmology it is customary to model the distribution of galaxies as a dust where each galaxy is a small object, relative to the scales of interest in cosmology. If neighboring galaxies and gas clouds have orbital angular momentum which are correlated with each other, then the resulting cosmic dust will appear to have intrinsic angular momentum, when modeled on a sufficiently large scale.
and
The intrinsic angular momentum density and torsion of the macroscopic model are average moments of finer pseudo-Riemannian structures (like rotating galaxies) which have no intrinsic angular momentum and no torsion.
There are two aspects to my doubts, one is about the structure and the other is about the rotation curve:
On galaxy structure
In astronomy, C.C. Lin and Frank Shu proposed the density wave theory to explain the spiral arm structure of spiral galaxies.
If according to the paper:
, then modeling the distribution of galaxies as cosmic dust seems to be combining the concepts of mean-field and quasiparticle with Lin–Shu density wave theory and effectively reformulate it in terms of Einstein–Cartan theory.
About galaxy rotation curve
It is well known that the galaxy rotation problem is an unsolved problem in current astrophysics, while the proton spin crisis is an unsolved problem in current particle physics.
According to the paper:
, then modeling the distribution of galaxies as cosmic dust also seems to transform the rotation problem into a spin crisis.
Including the above doubts, I would like to ask:
Likes AlexB23 and berkeman
Space news on Phys.org
1. Cosmic Dust in Cosmology:​
  • In cosmology, "cosmic dust" is not literal dust but rather a conceptual tool used to describe the matter content in the universe on large scales. It refers to the continuous, diffuse matter that fills space, similar to how dust would spread throughout an area.
  • This cosmic dust is modeled as a continuous, fluid-like substance that represents the average density of matter (galaxies, gas, dark matter, etc.) spread across vast scales.
  • Galaxies and other structures (such as gas clouds) are treated as small perturbations or localized regions within this "dust." These perturbations, when looked at on a large enough scale, give rise to the collective behavior of matter in the universe.
2. Intrinsic Angular Momentum in Galaxies:​
  • Galaxies themselves rotate and have their own angular momentum due to the movement of stars, gas, and other matter. However, when we look at the large-scale structure of the universe (the distribution of galaxies on cosmological scales), the focus shifts to the average properties rather than the detailed specifics of individual galaxies.
  • The intrinsic angular momentum of cosmic dust comes from the collective motion of galaxies. The idea is that neighboring galaxies and gas clouds have orbital angular momentum (spin) that is correlated on large scales. This correlation of motion can result in an apparent, macroscopic angular momentum of the "cosmic dust."
  • The torsion mentioned refers to a geometric property in general relativity related to the curvature of spacetime in the presence of spinning matter. In this cosmic dust framework, the torsion and angular momentum are seen as emergent properties from averaging over smaller, finer-scale structures (like galaxies).
3. Galactic Rotation Curves and Spin Crisis:​
  • The rotation curve problem refers to the observation that galaxies do not rotate as predicted by the visible mass alone. According to Newtonian mechanics, or even more refined models using general relativity, stars in the outer parts of galaxies should be moving slower than what is observed. This discrepancy is often attributed to dark matter or modifications to gravity (such as MOND, Modified Newtonian Dynamics).
  • By modeling the universe as cosmic dust, the rotation curve problem can be interpreted in a different way. The large-scale average motion of galaxies might be influenced by the collective angular momentum of the dust, leading to this apparent rotation.
  • The spin crisis in particle physics refers to the unresolved issue of understanding how proton spins emerge. Similarly, the apparent large-scale rotational effects of galaxies could point to underlying collective effects, such as spin correlations in cosmic dust.
4. Link to Einstein–Cartan Theory:​
  • The reference to Einstein–Cartan theory suggests that this approach goes beyond traditional general relativity by incorporating torsion into spacetime, which is linked to spinning objects.
  • In this framework, galaxies and other structures contribute to the pseudo-Riemannian geometry of spacetime through their spin, and the average moments of these finer structures (galaxies) shape the macroscopic properties of the universe.
  • This theory may help explain phenomena like galaxy rotation curves without needing dark matter, by considering the emergent effects of spinning matter on spacetime geometry.
Conclusion:​
To model the distribution of galaxies as cosmic dust means to treat galaxies as localized, small perturbations within a continuous medium, much like how dust would spread throughout space. On large scales, the matter appears as a fluid-like "dust" with properties such as angular momentum and torsion that emerge from the collective behavior of galaxies. This approach aligns with ideas from Einstein–Cartan theory, where the macroscopic geometry of the universe reflects the average properties of finer structures.
Likes timmdeeg and PeroK
Conclusion:​
You do know that fluid-like "dust" is made up of dust particles that are highly idealized models of galaxies, right?
But your response mention nothing about what happens to the geometry inside of the dust particles, that is the difference between Einstein–Cartan theory and general relativity.
There is also no mention of how the galaxies rotation curve problem transforms when galaxies are modeled as dust particles.
Conclusion:​
To model the distribution of galaxies as cosmic dust means to treat galaxies as localized, small perturbations within a continuous medium, much like how dust would spread throughout space. This approach aligns with ideas from Einstein–Cartan theory, where the macroscopic geometry of the universe reflects the average properties of finer structures.
I quote Milky Way could invalidate the hypothesis of exotic matter and favor a gravitomagnetic solution to explain dark matter published in Scientific Reports (Clarivate MJL: 2045-2322) here, hoping it will help you understand my question.
In Milky Way could invalidate the hypothesis of exotic matter and favor a gravitomagnetic solution to explain dark matter, galaxy is modeled as point particle in order to evaluate the contribution of frame-dragging and surprisingly become a strong point of the solution.
Although the purpose of modeling galaxy as point particle in Milky Way could invalidate the hypothesis of exotic matter and favor a gravitomagnetic solution to explain dark matter is to deal with the dark matter problem, the related issues of modeling galaxy as point particle do not seem to be limited to the dark matter problem discussed in Milky Way could invalidate the hypothesis of exotic matter and favor a gravitomagnetic solution to explain dark matter.
As mentioned above, modeling galaxies as dust particles will turn the galaxy rotation problem into a particle problem, which will be similar to the proton spin crisis.
Besides this, modeling galaxies as point particles should have a way of preserving the spiral structure to some extent, since the spiral structure is not a microscopic detail relative to the galaxy as a whole.
General relativity may not be able to do this, and may need torsion in Einstein–Cartan theory to correspond to the spiral structure in Lin–Shu density wave theory.
No, this is not correct. In FRW models of the universe as a whole, the "dust" that models matter (positive energy density, zero pressure) is not a model in which galaxies are point particles. It is a model where the average distribution of matter in the universe is a continuous fluid.
Galaxies are not modeled as dust particles. See above.
The galaxy rotation curve issue arises from different models based on GR, models of a single isolated galaxy. These models are of course approximations, as are the FRW models of the universe as a whole. You do not appear to understand what that actually means.
This is not what the paper you reference is doing. You do not appear to understand what you are reading.
This is nonsense.
This is even more nonsense, since of course a point particle cannot have any "spiral structure", and the physicists who construct models of galaxies know this, so they don't model galaxies as point particles.
Since you don't appear to understand how the GR models actually work, I don't see what basis you have for any such claim. It is true that models adding torsion have appeared in the literature, but none of them have led anywhere useful.
From what I can see from the Wikipedia article, this theory uses standard models of gravity (GR and its Newtonian approximation), with no torsion anywhere. So again you do not appear to understand what you are reading.
Likes PeroK
The original poster's misconceptions have been pointed out and corrected, so this thread will remain closed.
Likes Trysse
  • · Replies 72 ·
10K
  • · Replies 264 ·
22K
  • · Replies 105 ·
15K
10K
