What does it mean to solve a problem 'analytically'?
  • Thread starter autodidude
  • Tags
    Mean
In summary, the conversation discusses the use of visuals and geometry in problem-solving and proof techniques. It is mentioned that geometry involves measuring distance and angles, and has evolved to include objects with curvature. The use of computers has made solving difficult equations easier through numerical approximations. It is also noted that visuals are often used to clarify proofs, but the proof itself does not rely on visuals. Finally, an example is given of a graphical method for solving equilibrium problems, but an analytical solution may be simpler to work with.
autodidude
333
Also, when you solve a problem or prove something without the usual of pictures/visuals, what's that called? Is it called 'geometrical' if you DO use visuals?
Mathematics news on Phys.org
Of the field of geometry, two of the most important attributes are distance and angle.
Lots of people do associate geometry with something that is more or less a visual representation, but the word geometry actually means 'measure of the earth' and it has evolved to the point where we can measure things (metric, norm) in terms of distance on objects that are not flat, but instead have positive or negative curvature (like the surface of a circle or a horse saddle).
Distance relates to metrics and norms, and angles relate to inner products and the two of them can be related to each other by using standard definitions of inner products and norms.
Solving something analytically usually means finding an explicit equation without making approximations. When solving differential equations, analytic solutions can be difficult and some times impossible. The power of computers have made even the most difficult differential equations (that relate to reality) a lot easier to approximate numerically. The classic example is the three body problem in physics.
Do you know Newton's Method for finding roots to polynomial equations? That is an example of a numerical approximation method that can be used if there is no good formula for finding the root (analytic solution).
In my experience (only undergrad) there is no such thing as a proof of anything significant by using visuals. Often diagrams are used to clarify an explicit proof, but the proof would stand on its own. Of course there are problems that concern a physical question, but even then, the proofs rely on non-visual arguments.
Second Chiro's response. Geometry go far beyond what can be visualized or drawn.
Thanks
I just found an example in my physics textbook, 'the construction in fig. 2-2 provides a satisfactory graphical method for the solution of problems in equilibrium. For an analytical solution,, it is usually simpler to deal with the rectangular components of the forces.'
That was on the equilibrium of particle, fig. 2.2 is a picture of a blob with three vectors acting on it
FAQ: What does it mean to solve a problem 'analytically'?
What is the definition of solving a problem analytically?
Solving a problem analytically means using logical reasoning and systematic methods to break down a complex problem into smaller, more manageable parts in order to find a solution.
How is solving a problem analytically different from other problem-solving methods?
Analytical problem-solving involves a more structured and step-by-step approach, while other methods such as trial and error or intuition may rely more on instinct and creativity.
What are some benefits of using analytical problem-solving?
Analytical problem-solving allows for a more organized and efficient approach to finding a solution. It also helps to eliminate bias and subjectivity, as decisions are based on data and evidence.
Can anyone learn to solve problems analytically?
Yes, anyone can learn and develop the skills needed for analytical problem-solving. It takes practice and patience, but with dedication, anyone can improve their analytical thinking abilities.
What is the general process for solving a problem analytically?
The general process for solving a problem analytically involves identifying the problem, gathering relevant information and data, breaking down the problem into smaller parts, analyzing the data and information, and using logical reasoning to come up with a solution. This process may vary slightly depending on the specific problem and individual problem-solving approaches.
